Executive Summary
Snowflake has become the system of record for enterprise data. But a data warehouse however elastic, however fast is not, by itself, an orchestration layer. It stores and computes; it does not decide when data moves, in what shape, to which system, under what governance, or what happens next when a business event occurs. That job falls to whatever sits around Snowflake, the pipelines that load it, the transformations that clean it, and the workflows that put its insights back to work in the applications people actually use every day.
Most organizations answer that need by stitching together several specialized tools, an ELT tool to move data in, a transformation tool to model it, a reverse-ETL tool to push it back out, and a separate integration platform to connect the business applications that never touch the warehouse at all. Each tool is good at its narrow job. Together, they create the same integration debt, governance gaps, and operational cost that data teams were trying to escape in the first place.
This brief makes the case that Workato, a Gartner Magic Quadrant Leader for iPaaS for eight consecutive years, a Gartner Magic Quadrant Visionary for Data Integration and a certified Snowflake technology partner is the right orchestration layer for Snowflake, for two distinct audiences, organizations standing up a new Snowflake deployment who want to avoid rebuilding this stack piece by piece, and organizations with an existing Snowflake deployment looking to rationalize point tools, activate their data bidirectionally, and get Snowflake ready for agentic AI. It also flags a near-term, concrete forcing function. Snowflake’s move to mandatory strong authentication, rolling out through October 2026, which is already pushing every Snowflake-connected system to be re-architected, making this the moment to decide what that architecture should be, not just how to patch the old one.
1. Snowflake Is Mission-Critical but It Was Never Built to Be an Orchestration Platform
Snowflake’s value proposition is storage, compute, and governance for data at scale. It is deliberately agnostic about how data gets in, how it moves between systems, and how the business consumes what comes out. That agnosticism is a feature for a warehouse. It is also exactly why every serious Snowflake deployment eventually needs a dedicated orchestration layer sitting alongside it.
Without one, three patterns show up almost immediately in growing Snowflake environments:
– One-way pipes. Data flows into Snowflake from source systems, but there is no equally robust path for the insights Snowflake produces to flow back out into Salesforce, NetSuite, ServiceNow, or the dozens of other applications where employees and customers actually work. Analysts end up building dashboards that people have to remember to check.
– Tool sprawl. A typical stack layers an ELT tool for ingestion, a transformation tool for modeling, a reverse-ETL tool for activation, an iPaaS for everything that isn’t warehouse-bound, and often a workflow/RPA tool on top. Each has its own connectors, its own credentials, its own failure modes, and its own bill.
– Governance that doesn’t travel with the data. Access controls inside Snowflake don’t automatically extend to the pipelines and automations feeding it or drawing from it, so shadow IT and ungoverned point-to-point integrations creep back in around the edges of an otherwise well governed warehouse.
None of this is a knock on Snowflake. It is the natural consequence of treating a data platform and an orchestration platform as the same problem, when they are two different layers of the architecture that happen to sit next to each other.
2. Data Movement Is Not the Same Job as Data Orchestration
The modern data stack has produced excellent, narrowly scoped tools for moving data into a warehouse. Fivetran and similar ELT platforms are built to replicate data from a source system into Snowflake reliably, with deep warehouse side connector support. Matillion and similar tools push transformation logic down into Snowflake’s own compute, which is a strong fit for data teams who want business logic to live inside the warehouse. These are legitimate, well built tools for a specific job and getting data into and modeling it within Snowflake.
Orchestration is a broader job. It is the layer that decides what happens across every application, database, and AI agent in the business, not just the ones that touch the warehouse when a record changes, a threshold is crossed, or a person needs an answer. The distinction matters because most Snowflake initiatives don’t fail on ingestion, they fail on activation and on everything that has to happen around the data before and after it sits in a table.
| Dimension | Typical ELT / transformation tool | Workato |
| Primary job | Load and transform data destined for the warehouse | Move and act on data and events across every application, database, agent, and the warehouse itself |
| Directionality | Largely one-way: source → warehouse | Bidirectional by design: source ↔ warehouse ↔ business applications ↔ AI agents |
| Connector breadth | Deep on data sources; shallow on SaaS business workflows | 14,000+ applications, databases, and APIs, spanning SaaS, on-prem, files, and AI models |
| Who can build | Primarily data engineers writing SQL/config | Data engineers and business technologists, via low-code recipes |
| AI-readiness | Not designed to expose data as agent-callable tools | Native Enterprise MCP: existing pipelines become governed, token-efficient AI agent skills |
| Governance model | Warehouse-side RBAC only | Unified governance across every pipeline, workflow, and agent touching the data |
Table: illustrative comparison based on public vendor documentation and Workato product materials, exact capabilities vary by vendor and plan.
This is not an argument to rip out a warehouse native ELT tool that is doing its narrow job well. It is an argument that the layer above it, the one deciding what happens next, across the whole business, not just inside the warehouse needs to be built for orchestration, not bolted on after the fact.
3. Why Workato Is the Right Orchestration Layer for Snowflake
3.1 A certified, deep partnership not a generic connector
Workato and Snowflake have an active technology partnership. Workato has completed Snowflake’s Snowflake Ready technology program, participates in Snowflake’s Snowpark Accelerated program, and its Snowflake connector supports Java user-defined functions for in-database data programmability. This is a maintained, certified integration, not a community built connector that breaks on schema drift.
3.2 Bidirectional by design: data in, insights out
Workato’s Snowflake connector loads and stages data from source applications into Snowflake replicating source schema and auto-creating destination tables where it can be cleansed, enriched, and transformed. Critically, it also works in the other direction, insights computed in Snowflake can be pushed back into Salesforce, NetSuite, ServiceNow, or any of Workato’s 14,000+ supported applications, so that business teams act on data inside the tools they already use, rather than waiting on a BI dashboard someone has to remember to open.
3.3 One platform instead of five
Workato’s Data Orchestration capability, connectivity to enterprise apps, databases, ERPs, files, and LLMs, data pipeline recipes that move data for thousands of objects, built-in DataOps dashboards, job reports, and alerting through Slack or Microsoft Teams and reverse-ETL/data-activation for pushing insights back into business systems sits on the same platform, the same recipe engine, and the same governance model as Workato’s broader integration, automation, and AI-agent orchestration. Instead of running a separate ELT tool, reverse-ETL tool, iPaaS, and automation platform, teams run one control plane. Workato’s own customers report 60–80% reductions in operational cost versus fragmented tool stacks when consolidating onto a single orchestration platform, a Workato wide figure, not Snowflake specific, but directly relevant to anyone counting the line items in a modern data stack budget.
3.4 Governance that travels with the data
Because ingestion, transformation hand-offs, activation, and cross-application workflows all run on the same platform, access controls, audit trails, and monitoring apply consistently across the whole path data takes, not just inside the warehouse. That closes the gap where shadow IT and ungoverned point-to-point integrations tend to accumulate around a well governed data platform.
3.5 AI- and agent-ready, not just warehouse-ready
Snowflake is increasingly where enterprises want their AI agents to find trustworthy data. Workato’s Enterprise MCP turns existing recipes and connectors including Snowflake pipelines into governed, callable skills for AI agents, without months of custom connectivity work per agent. Because Workato’s MCP servers are built on intent-based, scoped-down tool design rather than exposing a full API surface, they are also materially more token efficient in benchmark comparisons Workato has published (for example, 93%+ token reductions in controlled tests against vendor-provided MCP servers) a real cost lever as organizations connect more agents to more Snowflake backed data.
3.6 Speed to value without giving up control
Workato’s low-code recipe builder lets both data engineers and business technologists stand up Snowflake pipelines and activation workflows in hours, not weeks, with governance and observability (RecipeOps, custom dashboards, job-level alerting) built in rather than added on afterward closing the gap between “data is in the warehouse” and “the business is actually using it.”
4. The Case for a New Snowflake Deployment
Organizations standing up a new Snowflake environment have a genuine, time-limited advantage: they can design the orchestration layer in from the start, instead of retrofitting one after three or four point tools are already load-bearing.
– Avoid rebuilding the stack twice. A greenfield deployment that starts with a narrow ELT tool alone will, in most cases, need to add a reverse-ETL tool, an iPaaS, and eventually an AI-agent connectivity layer as the initiative matures. Starting with an orchestration platform that already does all of this avoids that second migration.
– Design governance in, not around. It is far cheaper to define access, audit, and monitoring standards once, across ingestion and activation together, than to reconcile four different tools’ governance models after the fact.
– Build for the AI use cases that are coming, not just the reporting use cases that are already funded. A new deployment is the cheapest point in the lifecycle to make sure the data landing in Snowflake is also immediately usable as context for AI agents.
5. The Case for an Existing Snowflake Deployment
Organizations with a mature Snowflake footprint face a different, equally compelling case of rationalizing an accumulated stack rather than architecting a new one.
– Consolidate point tools without a rip-and-replace. Workato sits alongside an existing Snowflake instance and existing ELT jobs, it does not require displacing a functioning ingestion pipeline to add governed activation, cross-application orchestration and AI-agent connectivity on top.
– Close the activation gap. Many mature Snowflake environments have excellent ingestion and modeling but a thin or missing activation layer, insights that live in a BI tool instead of the applications where decisions get made. Adding Workato’s reverse-ETL and data-activation capability addresses this directly.
– Get ahead of Snowflake’s own security roadmap. Snowflake is rolling out mandatory strong authentication for human users, deprecating single-factor password logins in a phased rollout running from roughly May through October 2026. Every existing integration authenticating to Snowflake with a username and password has to be touched before that window closes. That mandatory re-authentication work is a natural, low-risk moment to also evaluate whether the tools sitting on top of Snowflake are still the right ones rather than simply re-entering new credentials into the same fragmented stack.
6. Recommendation
Snowflake should remain the system of record for enterprise data. Workato should be the layer that decides what happens to that data next, moving it in, transforming it, governing it, and, just as importantly, pushing what Snowflake learns back out into the applications and AI agents where the business actually acts on it.
For a new Snowflake deployment, that means architecting orchestration from day one, rather than assembling it tool by tool over the next two years. For an existing deployment, it means using the current Snowflake authentication migration as the occasion to consolidate a fragmented stack, close the activation gap, and make existing data AI-agent-ready all without displacing the ingestion and modeling work already in place.
Sources
• Workato — Snowflake integration and workflow automation — https://www.workato.com/integrations/snowflake
• Workato — Snowflake Data Integration: Complete Guide & Best Practices — https://www.workato.com/the-connector/snowflake-data-integration/
• Workato — “Workato is Snowflake Ready!” — https://www.workato.com/the-connector/workato-snowflake-ready/
• Workato Docs — Configure Snowflake as your data pipeline destination — https://docs.workato.com/en/data-orchestration/data-pipeline-recipe/connect-to-snowflake.html
• Workato Docs — Data orchestration overview — https://docs.workato.com/data-orchestration.html
• Workato — Partnership announcement with Snowflake for in-context insights — https://www.workato.com/the-connector/workato-partners-with-snowflake-cloud-data-warehouse/
• Workato Product Hub — Building Modern Data Pipeline Architecture for Snowflake with Workato — https://www.workato.com/product-hub/building-modern-data-pipeline-architecture-snowflake/
• Workato Product Hub — Robust Data Pipelines and Automations for Snowflake in Minutes — https://www.workato.com/product-hub/robust-data-pipelines-automations-snowflake/
• Workato — Java UDFs / data programmability for Snowflake automations — https://product2.workato.com/bringing-data-programmability-to-your-snowflake-automations-in-workato/
• BusinessWire — Workato Introduces Comprehensive Data Orchestration Capabilities for the Modern Data Stack (Jul 30, 2024) — https://www.businesswire.com/news/home/20240730651593/en/Workato-Introduces-Comprehensive-Data-Orchestration-Capabilities-for-the-Modern-Data-Stack
• SiliconANGLE — Workato aims to take the work out of data pipeline orchestration — https://siliconangle.com/2024/07/30/automation-software-firm-workato-aims-take-work-data-pipeline-orchestration/
• BusinessWire — Workato Named a Leader in the 2026 Gartner Magic Quadrant for iPaaS (8th consecutive time) — https://www.businesswire.com/news/home/20260318294684/en/Workato-Named-a-Leader-in-the-2026-Gartner-Magic-Quadrant-for-iPaaS-for-the-8th-Consecutive-Time
• Workato — Gartner Magic Quadrant 2026 report page — https://www.workato.com/report/gartner
• Gartner Peer Insights — Fivetran vs. Workato Data Orchestration Platform comparison — https://www.gartner.com/reviews/market/data-integration-tools/compare/product/fivetran-vs-workato-data-orchestration-platform
• Hevo Data — Fivetran vs. Workato: Key Differences & Use Cases — https://hevodata.com/learn/fivetran-vs-workato/
• Peliqan — Top Matillion Alternatives & Competitors — https://peliqan.io/blog/matillion-alternatives/
• Snowflake Documentation — Planning for the deprecation of single-factor password sign-ins — https://docs.snowflake.com/en/user-guide/security-mfa-rollout
• Snowflake Community — FAQ: Snowflake to block password-only logins — https://community.snowflake.com/s/article/FAQ-Snowflake-to-block-password-only-logins
• Snowflake — Streamlining the Transition to Mandatory MFA — https://www.snowflake.com/en/blog/engineering/streamlining-transition-mandatory-mfa-strong-authentication-hub/
