Workato vs Runlayer: Which Fits Enterprise AI?
Brad Griffith Headshot
Brad Griffith
Nov 6, 2026
Runlayer Hero
Workato is the Control and Execution Platform for enterprise AI, and Runlayer is an AI control plane built around MCP. They overlap on governance and split on who does the work. Per its own site, Runlayer governs how agents reach MCP servers, with 200+ in its catalog. Workato governs agents too, through its Control Plane, and it also runs the business processes those agents touch, across more than 17,000 enterprise systems for 25,000+ customers. If you’ve heard Workato described as just a sequential integration tool, that misses its AI governance layer. Here’s what each product does today and how to pick.
How is Runlayer different from Workato?
Runlayer starts at the control layer, while Workato starts with both layers in one platform. Runlayer calls itself “the operating layer for AI” and describes an enterprise AI control plane. It connects agents to MCP servers and applies identity, policy, runtime security and audit logging to each action. Its product splits into Enablement (Runlayer Agents, a catalog, an MCP Gateway) and Control (shadow AI discovery, runtime security, agent identity and governance, observability).
Workato offers one platform with two planes. The Control Plane governs what AI does, and the Execution Plane does the work. It runs API platform, data integration and workflow orchestration with enterprise guarantees like execute-only-once and auditability. The difference shows up on day two of a rollout. Governing an agent’s access to a tool is only half the job, because someone still has to make sure the action it takes inside Salesforce, SAP or ServiceNow is correct, runs once, and leaves a trail. Workato treats that as one problem, while Runlayer centers on the governed path to the tool and the agents built on top of it.
What does Runlayer do well?
Runlayer’s focus does have some benefits. Three things stand out.
First, shadow AI discovery. Runlayer deploys through your existing MDM and scans managed devices for unsanctioned MCP servers, skills, plugins, agents and AI clients, then lets you approve, migrate or block them. Its site says blocking works for Cursor, Claude Code and Codex on macOS today. If your security team’s first question is “what are people already running?”, that’s a strong answer.
Second, runtime scanning. Runlayer’s ToolGuard and AgentGuard check tool definitions when they’re registered and tool calls when they run, looking for tool poisoning, prompt injection, data exfiltration and task drift. Its docs put typical scan time at 50 to 100 ms. Teams can start in alert-only mode before they turn on blocking.
Third, speed to a first governed agent. Runlayer Agents lets employees create agents from Slack, Claude, Cursor, ChatGPT or the web, running on a Runlayer-managed or customer-hosted runtime. It’s a younger, narrower product, and that focus shows.
What does Workato’s Control Plane cover?
Workato’s Control Plane has three parts: the AI Gateway, the AI Registry and Catalog, and AI Security and Governance. Gateways handle traffic in flight, and the Control Plane manages assets, identities and policies.
The AI Gateway is four gateways under one policy, telemetry and identity layer: a Model Gateway for LLM calls, an MCP Gateway for tool traffic, an Agent Gateway for agent-to-agent collaboration over A2A and MCP, and an API Gateway for managed REST endpoints. You can start with one and add the others.
On MCP specifically, Workato’s MCP Gateway signs users in through Workato Identity or SSO, applies rate and concurrency limits, and captures every request and tool call. You can set access at the tool level by group or user, and a user without access doesn’t see the tool in the list at all. One guardrail policy covers PII masking, prompt-injection screening, content moderation and grounding checks. You define it once and it’s enforced at whichever gateway a request hits, in enforce or observe-only mode. Spend is visible by team, model and cost center, with budget alerts before limits are hit. Every interaction is recorded with who invoked it, which model, tool or agent, which policy applied, whether it was allowed or blocked, and the cost, and the records can stream to your SIEM.
Can Workato govern agents it didn’t build?
Yes. Workato’s Control Plane governs AI built on Workato and elsewhere. Agents and AI clients built on other platforms route their model and tool calls through the Control Plane and inherit its access controls, guardrails, limits and audit. Third-party MCP servers are governed by proxy, with one authentication surface, credentials held centrally, tool policy enforced and every call logged. The pitch is that direct MCP scales connections, while the proxy scales control.
This matters because most enterprises don’t standardize on one agent vendor. You’ll have Claude in one team, Copilot in another, and a homegrown agent in a third. Workato positions itself as the neutral platform in the middle.
What does Workato’s Execution Plane do that a control plane can’t?
Workato’s Execution Plane runs the work itself, and that’s where the two products separate most clearly. A control plane decides whether an agent may call a tool. The Execution Plane is the tool: more than 17,000 enterprise systems, an orchestration engine, and over a decade of the #1 iPaaS in the industry behind it.
Here are three examples. Enterprise Skills give agents proven business actions in place of raw API access. A skill carries your organization’s own logic for what “search” or “update” means and handles errors inside the skill, so the agent gets a clean response instead of a stack trace. It’s also deterministic, so the same input produces the same output and you can test it. Workato RPA reaches legacy desktop and browser applications that have no API at all, as one step inside a recipe next to your API and SaaS steps. And human approvals fit inside a skill: a business rule can route a request to a person in Slack or Teams, and the agent resumes after approval.
Deterministic is a key feature here. For anything that moves money, changes a record or touches a customer, it’s what you want underneath a non-deterministic agent.
How do Runlayer and Workato compare on the Control Plane?
Both products govern MCP access, and they differ on breadth and on discovery. This table covers the control side, so read it as a quick scan of who offers what.
CapabilityWorkatoRunlayer
PositioningWorkato: Control and Execution Platform for enterprise AIRunlayer: “operating layer for AI,” enterprise AI control plane
MCP access controlWorkato: MCP Gateway, tool-level access by group or user, Workato Identity or SSO, rate and concurrency limitsRunlayer: MCP Gateway, scoped by user, group, role, agent, client and tool; 20+ AI clients
Third-party MCP serversWorkato: governed by proxyRunlayer: 200+ servers in catalog
LLM trafficWorkato: Model Gateway with OpenAI- and Anthropic-compatible API, approved-model list, routing, failover and token meteringRunlayer: homepage says one gateway governs MCP and LLM calls; routing, failover and token metering not specified
GuardrailsWorkato: PII masking, prompt-injection screening, content moderation, grounding checks; enforce or observe-onlyRunlayer: ToolGuard and AgentGuard scan tool definitions and calls; alert-only, then blocking
Shadow AI discoveryWorkato: not described in its documentation; Workato’s AI Registry is designed to list approved assetsRunlayer: MDM-based discovery of unmanaged MCPs, skills, plugins, agents and clients
Spend controlWorkato: spend by team, model and cost center; budget alertsRunlayer: agent cost by model, tokens and runs, plus agent cost budgets; budgets by team or cost center not specified
AuditWorkato: who, what, which policy, allowed or blocked, cost; streams to a SIEMRunlayer: audit logs, exportable to S3 for SIEM
How do Runlayer and Workato compare on the Execution Plane?
Workato’s Execution Plane is built to run governed work across more than 17,000 enterprise systems. Runlayer’s agents run too, so the comparison turns on what each can reach and how reliably. The table below lines up the execution side.
System reachWorkato: over 17,000 enterprise systemsRunlayer: 200+ MCP servers in catalog; turns any API into a hosted custom MCP
Systems with no APIWorkato: RPA for legacy desktop and browser appsRunlayer: not specified; custom MCPs wrap APIs, no RPA described
Business actionsWorkato: Enterprise Skills, deterministic, errors handled in the skillRunlayer: Runlayer Agents run interactively, on schedules or from webhooks
Workflow engineWorkato: orchestration with execute-only-once and auditabilityRunlayer: agent triggers (schedules, webhooks, events); deterministic workflow engine not specified
Human approvalWorkato: approval step in Slack or Teams inside a skillRunlayer: policy can require human approval for risky actions; approval cards for agent handoffs in chat, Slack and Teams
Agent-to-agentWorkato: Agent Gateway over A2A and MCPRunlayer: agent handoffs and subagents inside Runlayer; A2A protocol support not specified
API publishingWorkato: API Gateway publishes versioned, authenticated REST endpoints; also usable as governed agent toolsRunlayer: not specified; hosts custom MCP servers, and its Platform API manages Runlayer itself
Is Workato just sequential, deterministic iPaaS?
No. Workato’s Enterprise Skills are deterministic by design, and Workato also governs agents that aren’t. Both statements hold, and they belong together. The Execution Plane gives agents reliable actions to call, and the Control Plane watches what the agents decide. It records each interaction with model, tool, policy outcome and cost, and applies guardrails to every call. For agents built in Agent Studio, Workato’s Conversations hub also records each user prompt, guardrail check, LLM call and tool call, with step-level traces in skills.
“AI governance” and “does the work” are not necessarily separate categories. A gateway governs access but can’t do the work, and a script does the work but nobody governs it. Run them as two products and you own the gap between them, including a second audit trail and a second set of identities. Workato has one control surface and one audit trail, with no gaps to exploit. That said, a focused control layer is still a legitimate choice, and which one fits depends on how much of your AI work touches systems of record.
Summary
Workato and Runlayer both govern how enterprise AI reaches tools, and they differ on scope. Runlayer is a focused MCP control plane with strong device-level shadow AI discovery and runtime scanning. Workato is a Control Plane plus an Execution Plane, so governed agents can act on 17,000+ systems under one policy and one audit trail.
Choose Workato if: your agents will change records in systems like ERP, CRM or ITSM; you need approvals, deterministic business actions or access to legacy apps with no API; you run agents from several vendors and want one policy and audit layer; or you want spend control by team, model and cost center.
Consider Runlayer if: your most urgent problem is finding and blocking unsanctioned MCP servers, skills and AI clients on employee devices; your agent use is mostly developer tools; or you want a narrower product focused only on the MCP layer.
If you evaluate both, ask each vendor the same three questions: who does the work, where the audit trail lives, and what happens at the system of record.
Frequently asked questions
What is Runlayer?
Runlayer is an AI control plane from Anysource Inc. that governs how agents connect to MCP servers, with identity, policy, runtime security and audit logging. Its site lists shadow AI discovery, an MCP Gateway, a catalog and governed agent creation among its products.
Is Runlayer a competitor to Workato?
Runlayer competes with Workato’s Control Plane, especially the MCP Gateway and governance features. It does not describe itself as an integration or orchestration platform, so it overlaps with part of Workato rather than the whole.
Does Workato have an MCP gateway?
Yes. Workato’s MCP Gateway is one of four gateways in its AI Gateway. It authenticates users through Workato Identity or SSO, enforces rate and concurrency limits, controls tool-level access, and logs every request and tool call.
Can Workato govern AI agents built outside Workato?
Yes. Workato’s Control Plane governs AI built on Workato and elsewhere. External agents route model and tool calls through it and inherit its access controls, guardrails, limits and audit. Third-party MCP servers are governed by proxy.
About the Author
Brad Griffith
More on Differentiation
AI Agents & Orchestration, AI Governance & Security, Differentiation
Workato vs Boomi: Which Is Stronger for MCP and Agentic AI?
Choosing an iPaaS that can support AI agents is a serious initiative, and third-party research…
Oct 20, 2026
Customer Stories, Differentiation
Workato was Named a Customers’ Choice in 2026 Gartner® Peer Insights™ for iPaaS
Recently Gartner published its "Voice of the Customer for Integration Platform as a Service" research.…
Sep 21, 2026
Sep 1, 2026
14 min read
