Japan’s enterprise automation market is at a structural turning point. The Japan RPA market — dominated by WinActor (NTT DATA) and worth $911 million in 2025 — is growing at a 22.79% CAGR toward $5.78 billion by 2034. At the same time, Japan’s AI agent CAGR of 46.3% is the highest in APAC, Gartner projects that 40% of enterprise applications will feature task-specific AI agents by 2026 (up from less than 5% in 2025), and Japan’s AI Promotion Act (passed May 2025) explicitly names autonomous AI agents as a national strategic priority. The question Japanese enterprise IT and operations leaders are asking is not whether to add agentic AI — it is how to transition from an existing RPA estate to an agentic orchestration model without breaking what already works.
This guide explains the transition architecture, what RPA does that AI agents cannot replace, what agentic AI delivers that RPA cannot scale into, and how Workato Enterprise MCP provides the orchestration layer for Japanese enterprises making this transition.
What Is the Difference Between RPA and Agentic AI?
RPA (Robotic Process Automation) executes predefined tasks by following scripted rules across fixed interfaces. WinActor — Japan’s #1 RPA platform for multiple consecutive years according to Fuji Chimera Research Institute — automates structured, repeatable tasks: data entry, form submission, file transfers, report generation. RPA works reliably when the underlying interface and data structure are stable.
Agentic AI goes beyond scripted execution. An AI agent reasons across context, handles unstructured inputs, makes decisions based on enterprise data, and takes actions through governed connections to business systems. Where RPA follows a script, an AI agent follows a goal — navigating variable conditions to reach an outcome. The practical difference: RPA moves a file from email to a folder; an AI agent reads the email, understands the customer request, extracts the relevant data, routes it to the appropriate system, drafts a response, and flags the edge cases that need human review.
These are not the same tool, and one does not simply replace the other. The productive framing — and the one Hitachi Digital Services has deployed for its enterprise clients — is a three-track approach: retire low-value automations, rebuild stable workflows natively in modern systems, and evolve high-judgment automations into AI agents.
Why Is Japan’s RPA-to-Agentic-AI Transition Different from Other Markets?
Japan’s automation context is shaped by factors that don’t apply the same way in other APAC markets:
The Labor Shortage Is the Primary Driver
Japan is 41% less staffed than North American and European peers and 21% less staffed than the APAC average (Voyen Group). 76.8% of Japanese companies report pursuing DX initiatives, but only approximately one-third have achieved meaningful results (METI survey). The gap between DX intent and DX outcome is a people and capacity problem that automation must close — not a technology preference. AI agents that can operate autonomously on complex, judgment-requiring workflows are not a convenience for Japan — they are a structural necessity.
METI’s Cabinet-approved Integrated Innovation Strategy 2025 explicitly cites “urgent need to improve productivity through automation and labour-saving through AI and robotics” as a response to Japan’s demographic situation. Enterprise agentic AI is government-backed in Japan in a way that has no parallel in Singapore, Australia, or Indonesia.
WinActor’s Market Position Creates a Specific Migration Baseline
WinActor is Japan’s most widely deployed RPA tool. This means the RPA migration starting point for Japanese enterprises is not UiPath, Automation Anywhere, or Blue Prism — it is WinActor. The migration question is specifically: what happens to WinActor automations when an enterprise moves to an agentic orchestration model?
The answer is: most WinActor automations do not need to be replaced. They need to be orchestrated. Task-level automation that WinActor handles reliably continues to run. Workato Enterprise MCP sits above WinActor as the orchestration layer — connecting WinActor’s outputs to the broader enterprise system, triggering agentic workflows when human judgment or cross-system reasoning is required, and governing the full automation stack under enterprise-grade security and audit controls.
Domestic AI Agents Create an Orchestration Layer Problem
Fujitsu, NEC, and Hitachi — Japan’s three largest enterprise technology companies — are all building proprietary AI agents for their vertical markets. Fujitsu has launched its AI-Driven Software Development Platform using the Takane LLM with multiple collaborating agents. NEC has AI agents for procurement workflows. Hitachi Digital Services launched HARC Agents in September 2025: 200+ agents across six domains with 30% faster deployment than previous approaches.
Japanese enterprises evaluating agentic AI are being presented with domain-specific AI agents from their preferred domestic vendors. The question is not whether to adopt these agents — it is how to make them work alongside Salesforce, SAP, Workday, and the rest of the enterprise stack. This is the orchestration layer problem. And it is uniquely Japan’s problem, because no other APAC market has three major domestic enterprises building vertical AI agents at this scale simultaneously.
What Are the Steps for Transitioning from RPA to Agentic AI in Japan?
Step 1: Audit Your Existing RPA Estate
Before transitioning, map what you have. For WinActor deployments, the audit should categorise each automation into three buckets:
Retire: Automations that were built to paper over process problems that have since been resolved. These create maintenance overhead without business value. Transition to agentic AI is the right moment to eliminate them.
Rebuild natively: Stable, high-volume automations that could be implemented directly as integrations or system workflows without the UI automation layer. These are typically cheaper to maintain and more reliable as direct system connections rather than UI-based scripts.
Evolve: Automations that involve judgment, variable inputs, or multi-system context — the ones that require frequent bot maintenance because the workflow logic is too complex for pure scripting. These are the candidates for agentic AI.
Step 2: Define the Governance Requirements
Japan’s AI Promotion Act (passed May 2025) requires enterprises deploying AI agents to maintain records of AI decision-making and ensure human oversight for high-stakes automations. Gartner projects that over 40% of agentic AI projects will be canceled by end of 2027 — with cost, unclear business value, and inadequate risk controls cited as the primary reasons.
Governance before deployment is not optional. For Japanese enterprises, this means: audit trails for every AI action, role-based access controls for what AI agents can do, clear human-in-the-loop triggers for edge cases, and data residency controls that keep agent activity within Japan’s regulatory boundary.
Workato Enterprise MCP addresses all of these through its Trust & Security pillar: every AI action is logged, governed by role-based permissions, and operates through Enterprise Skills (proven business actions) rather than raw API calls that bypass governance controls.
Step 3: Choose the Orchestration Layer
The orchestration layer is the platform that connects AI agents — whether from Fujitsu, NEC, Hitachi, UiPath, or a foundation model provider — to enterprise systems, data, and governance controls. This is not the AI agent itself. It is the infrastructure that makes AI agents enterprise-ready.
Workato Enterprise MCP is this layer. Three pillars:
Orchestrated Context — AI agents receive the right enterprise data at the right time. An agent handling a procurement workflow has access to SAP purchase order data, Workday approval chains, and Slack communication context — without requiring custom connectors for each.
Trust & Security — Every agent action is governed. Role-based access, audit trails, and data masking ensure that AI agents operate within enterprise security and compliance boundaries. For Japanese enterprises subject to FISC guidelines or FSA requirements, this layer is the compliance record.
Enterprise Skills — AI agents act through proven business actions built on 1,200+ enterprise connectors — not raw API calls. Proven actions are more reliable, faster to deploy, and easier to audit than custom API integration.
Step 4: Start with High-ROI, Low-Risk Workflows
The transition from RPA to agentic AI does not need to be a full estate replacement. The highest-return starting points are workflows that meet three criteria: high judgment requirement (current RPA bots need frequent maintenance), multi-system context (the task requires data from more than one system), and high volume (the efficiency gain compounds at scale).
Invoice processing is a documented reference point from Hitachi Digital Services: legacy RPA-based invoice processing achieves 65% accuracy; post-agentic AI transition achieves 92% accuracy with a 10x reduction in cost per invoice. For Japanese enterprises with large accounts payable operations, this is the starting point.
How Does Workato Enterprise MCP Orchestrate AI Agents in Japan?
Workato Enterprise MCP is not a replacement for WinActor, Fujitsu AI agents, or UiPath. It is the platform that makes all of these work together as a governed enterprise system.
The practical architecture: WinActor handles UI-based task automation on stable interfaces. Fujitsu’s Takane LLM agents handle software development workflows. Workato Enterprise MCP sits above both — connecting their outputs to SAP, Workday, and Salesforce, managing the data flow between systems, applying governance controls, and triggering human escalation when an agent reaches the boundary of its authorisation.
For Japanese enterprises, Workato Enterprise MCP delivers this through Hitachi Solutions, RickSoft, and Deloitte as implementation partners — the same SI relationships that manage most of Japan’s large enterprise technology infrastructure. The platform runs in Workato’s Japan data center with 100% in-region data residency, satisfying the PIPA and FISC requirements that apply to enterprise AI data processing in Japan.
Workato Enterprise MCP vs RPA-Only Architecture: What Changes?
| Capability | RPA Only (e.g., WinActor) | Workato Enterprise MCP + AI Agents |
| Task automation | Scripted, UI-based, stable interfaces only | Scripted + goal-directed, handles variable inputs |
| Multi-system orchestration | Limited — one system at a time, sequential | Native — connects SAP, Workday, Salesforce, AI agents simultaneously |
| Handling unstructured data | Cannot process emails, documents, or natural language | AI agent reasoning over unstructured inputs |
| Governance and audit | Limited audit trail, difficult to retroactively review | Full audit log, role-based access, compliance-ready |
| Data residency | On-premise tool (WinActor) — data stays local | Japan data center — in-region processing including AI |
| Maintenance overhead | High — UI changes break bots | Lower — agents adapt to context changes within governed parameters |
| AI agent integration | Limited to scenarios that receive instructions from AI agents via MCP through WinActor Manager on Cloud. | Orchestrates Fujitsu, NEC, Hitachi, and third-party AI agents |
| Connector count | Limited to target application APIs | 1,200+ enterprise connectors with full CRUD |
FAQ
Should Japanese enterprises replace WinActor with Workato?
Not directly. WinActor handles UI-based task automation that Workato’s approach does not replicate in the same form. The productive architecture is: WinActor continues running stable, structured task automations; Workato Enterprise MCP adds the orchestration layer above it — connecting WinActor’s outputs to multi-system workflows, AI agents, and enterprise governance controls.
Is agentic AI ready for production use in Japanese enterprises?
Yes, with appropriate governance. Gartner’s caution — that over 40% of agentic AI projects will be canceled by 2027 due to cost, unclear value, and risk controls — is a warning about deployment without governance, not about the technology itself. Workato Enterprise MCP’s governance layer (Trust & Security, Enterprise Skills) addresses the specific failure modes Gartner identifies. For Japanese enterprises, Japan’s AI Promotion Act additionally requires documented AI governance — which Enterprise MCP provides natively.
How does Japan’s AI Promotion Act affect enterprise AI agent deployment?
Japan’s AI Promotion Act (passed May 2025, enforcement from September 2025) establishes a framework for responsible AI deployment including requirements for: human oversight of high-stakes AI decisions, record-keeping of AI-driven actions, and transparency obligations. Enterprises deploying AI agents in Japan need an orchestration platform that generates audit trails, applies access controls, and documents agent activity. Workato Enterprise MCP addresses these requirements through its Trust & Security pillar.
Which Japanese enterprises are using agentic AI in production?
Mercari — Japan’s leading consumer tech company — uses Workato for enterprise orchestration including AI-powered workflows. Yokogawa Electric uses Workato for OT/IT integration in manufacturing. Japan-specific agentic AI deployments are a fast-moving area; case studies should be verified with Workato Japan’s team for the most current examples.
How long does a WinActor-to-agentic-AI transition take?
Timeline depends on estate size and scope. For a focused pilot — selecting a high-ROI workflow (e.g., invoice processing, HR onboarding, procurement approval) and deploying Workato Enterprise MCP alongside WinActor — typical timelines are 2-6 weeks to first production workflow. Full estate rationalization (retire, rebuild, evolve) is a multi-quarter program. Workato Japan’s team and implementation partners provide Japan-specific scoping.
Summary
Japan’s enterprise automation transition from RPA to agentic AI is not optional — it is the operational response to a 450,000-person IT worker shortage, a national AI mandate, and the arrival of domain-specific AI agents from Fujitsu, NEC, and Hitachi that need enterprise-grade orchestration to become production-ready.
The transition is not about replacing WinActor. It is about adding an orchestration layer above it — one that connects AI agents from any vendor, governs their actions under Japan’s compliance requirements, and connects the full enterprise stack through 1,200+ enterprise connectors.
Choose Workato Enterprise MCP if: your enterprise is deploying multiple AI agents (domestic or global), you need in-region data residency and governance for Japan’s regulatory environment, and you want the transition to run through your SI relationship.
Keep WinActor for: stable, UI-based task automations that are low-maintenance and do not require multi-system context or reasoning.
The enterprises that will win Japan’s “DX by AI” moment are the ones that build the orchestration layer now — before agentic AI proliferates into ungoverned sprawl.
