The RPA Tax: What Screen Automation Is Really Costing You
Kim Galant
Professional Services Practice Manager
Sep 1, 2026
Another bot down. Another late-night fix because a vendor tweaked a UI. Another ticket asking why the “automated” process still needs a human to babysit it. If that sounds familiar, you’re paying what a lot of automation teams don’t realise they’re paying: an RPA tax, charged quietly in maintenance hours, fragile bots, and a roadmap that keeps slipping to fix what’s already built.
None of this means RPA was the wrong call. Screen-scraping a legacy system with no API. Logging into a supplier portal that will never modernise. Copying data between two apps that were never built to talk to each other. RPA earned its place in the stack by solving problems nothing else could.
But the program that got you this far is starting to slow you down. Every new process means another bot to build, test, and maintain. Scale the program and you scale the tax right along with it. And when leadership asks what automation is doing for the business beyond cost savings on a handful of back-office tasks, the answer gets harder to give.
The fastest gain when you move from RPA-only to integration-first is stability. A process automated through an API, a file export, or a database connection stops being fragile. It’s no longer at the mercy of a UI redesign or a portal update that breaks your bot overnight. Fewer late-night fixes. Fewer tickets. Fewer “the bot’s down again” conversations with the business. It also changes delivery speed: building against structured data and defined logic is faster than reverse-engineering what a bot sees on screen. Teams making this shift often go from weeks to stand up a process to days.
The bigger case is what happens over the next two or three years. An RPA-only estate scales in a straight line: more processes, more bots, more infrastructure, more credentials, more things that break quietly until a customer complains. Governance gets harder as the estate grows, because every bot is its own point of failure with its own maintenance tail. An integration-first estate scales differently. New automations get built on a governed foundation instead of from scratch, and that same foundation is what you’ll lean on as automation extends into AI-driven and agentic workflows, which is where most roadmaps are heading next. RPA alone doesn’t give you that runway.
I saw this play out directly on a global distributor account. I led the first rounds of requirements gathering and solutioning, then stepped back into an executive sponsor role as the engagement scaled. The estate we inherited was built almost entirely on screen automation across multiple markets: order processing, data extraction, system updates. Once we mapped it against what actually had an API, a file export, or database access, the picture changed fast. Only a small slice, tied to supplier and customer portals with genuinely no programmatic way in, needed to stay as RPA. We went from roughly 180 bots to 11 (full story here).
Before and After workato ads a governed integration foundation layer
What changed wasn’t just uptime. It was visibility. With integrations, when something failed we could see where and why. With the old bots, a failure was often just a red status and a guess.
Allens, an international law firm, took a different but related approach: instead of replacing their RPA estate, they built a self-healing health check automation that continuously monitors the bots supporting finance functions, alerts on issues, and automates support ticket creation. Same underlying problem, a different point of intervention.
This isn’t rip-and-replace. It’s rebalancing: keep RPA for the narrow slice of work with no API, no file export, no programmatic way in, and move everything else onto integrations that are faster to build and far more reliable in production.
If you’re running RPA today, the questions worth asking aren’t about the bots you already have. They’re about what you build next. For every process on your roadmap, does the target system have an API, a file export, or database access? If it does, that’s a signal it doesn’t belong on a screen bot, regardless of how your team has historically built things. How much of your current maintenance effort goes to keeping existing bots alive versus shipping new automation? If that answer skews heavily toward upkeep, your program has hit the ceiling of what pure RPA can support. And where does the program need to be in two years, not this quarter? If AI-driven or agentic workflows are anywhere on that horizon, it’s worth checking whether your current foundation gets you there or was only ever built to solve yesterday’s problem.
So take the next process on your roadmap and run it through the test before a single bot gets built: does the target system have an API, a file export, or database access? If it does, you already have your answer. If your team can’t tell you, that’s worth finding out before you pay the RPA tax on one more process.
About the Author
Kim Galant
More on AI Agents & Orchestration
Oct 14, 2026
Oct 14, 2026
Oct 14, 2026
