AI token economics is the practice of metering, attributing, and optimizing the tokens an organization spends on AI against the business outcomes they produce. A token is the unit in which language models read and write text, and model providers bill by the token. Token economics asks what each team, model, agent, and task spends, and whether the result was worth it.
The topic moved onto CFO agendas in 2026. The Next Web (TNW) reported in June 2026 that per-token prices had fallen about 98% from late 2022 while enterprise AI bills had risen an estimated 320%, as agentic tools multiplied tokens consumed per task.
What is a token, and how are tokens billed?
A token is a chunk of text, roughly a short word or word fragment, that a model reads or writes. Providers bill separately for input tokens, output tokens, and in many cases cached input, with different prices for each and for each model. That means two prompts of the same length can cost very different amounts depending on the model and the cache.
Workato Model Gateway reports usage along the same lines: token usage by input, output, cache read, and cache write, grouped by model, provider, and route. Those four types matter because a cached read costs less than fresh input, so cache behavior changes the bill.
How is AI token economics different from crypto tokenomics?
AI token economics is about the cost of model inference, and crypto tokenomics is about the supply and incentives of a blockchain token. The two share a word and little else. AI tokens are units of text processing priced by a provider, while crypto tokens are digital assets.
Search results mix the two, so it helps to know which discipline you are reading about. For enterprise AI, the relevant model is closer to cloud FinOps: measure usage, attribute it to owners, and optimize it. The Linux Foundation announced a Tokenomics Foundation in June 2026 to bring that discipline to AI tokens.
What drives AI token cost?
Eight factors drive token cost, according to BCG’s analysis of managing the token meter: prompt length, retrieved context, output length, model choice, reasoning effort, tool choice, cache behavior, and the number of loops an agent runs before it stops.
The last factor is the one that surprises teams. A single request in a chat window costs one model call, but an agent working a task may make dozens. Each of those calls carries the growing conversation as input, so cost climbs faster than the work does.
What are the main levers for controlling token spend?
Five levers control token spend: model choice, routing, limits, caching, and execution design. Most teams reach for model choice first, but execution design often moves the number the most, because it cuts the calls a task needs at all. The table shows each lever next to the Workato control that matches it.
| Lever | What it does | Workato control |
| Model choice | Uses cheaper models for easy tasks | Approved-model list on Model Gateway |
| Routing | Picks the model per request | Rule-based routes on Model Gateway |
| Limits | Caps usage per team or key | Rate and token limit policies per team, project, or automation |
| Caching | Avoids paying twice for repeated input | Cache read and cache write reported separately |
| Execution design | Reduces calls per task | Enterprise Skills package multi-step work as one action |
You rarely need all five on day one. Start with the lever that matches where your spend is concentrated, and add the others as the data shows where the money goes.
What should you measure?
Measure cost per completed outcome, not cost per token. BCG names the key metric as cost per outcome and proposes a ratio it calls return on AI, which divides economic return by the cost of human intelligence plus the cost of tokens.
Cost per token tells you the meter’s rate, and cost per outcome tells you whether the work was worth running. An agent that spends twice the tokens and closes the ticket on the first try may be cheaper than one that spends half and escalates. Our guide to measuring token cost per completed task shows the method.
Where does Workato fit in token economics?
Workato supplies the metering and control at the gateway, and it reduces the number of tokens a task needs by moving execution out of the model. Workato Model Gateway meters usage by type, model, provider, and route, and attaches limits per team, project, or automation. That gives finance the attribution and gives engineering the stop.
In a Workato-run test on one Jira scenario, a Workato server needed 1 call and 31,000 tokens, against 3 calls and 164,000 tokens through Atlassian’s hosted MCP server.
Who owns token economics in a company?
Finance, platform engineering, and the teams running agents each own part of it. Finance sets budgets and wants attribution by team. Platform engineering operates the gateway, routes, and limits, and application teams own the efficiency of their agents.
Workato frames the split by role. IT governance sets one policy across models, tools, and agents, finance sees AI spend in one view, and platform and AI engineering give each team one governed path to models.
How do you start a token economics practice?
Start with visibility, then add limits, then optimize. First, route all model traffic through a gateway so every call is metered. Second, set limits per team so a runaway loop stops on its own, and third, review the highest-token workflows monthly and ask what outcome each produces.
Workato runs its own AIRO agent system on its Model Gateway, with budgets and quotas per period and model switching by task complexity. It is the same practice, applied to its own product.
Summary: What Is AI Token Economics?
AI token economics is metering, attributing, and optimizing token spend against outcomes. Tokens are the billing unit for model inference, and the discipline has nothing to do with crypto tokenomics. Cost per outcome is a better target than cost per token. Gateways meter usage, and skills reduce the calls each task needs.
FAQ
What is a token in AI?
A unit of text a model reads or writes. Providers bill by input and output tokens.
What is the difference between token economics and FinOps?
FinOps manages cloud spend. Token economics applies the same discipline to model usage, where the unit and the drivers differ.
Why do AI bills rise when token prices fall?
Agents use more tokens per task. Our piece on why AI bills rise when token prices fall covers the drivers.
How do I track token spend by team?
Route traffic through a gateway that meters usage and attaches policy per team.
Does caching reduce token cost?
Cached input is priced lower than fresh input at most providers, so cache hit rate affects the bill.
![[External] agentic-orchestration](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-agentic-orchestration-1-768x307.png)
![[External] what-is-an-ai-control-plane](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-what-is-an-ai-control-plane-1-768x307.png)
