How Do You Switch LLM Providers Without Code Changes?
Brad Griffith Headshot
Brad Griffith
Nov 11, 2026
[External] switch-llm-providers-without-changing-code
You switch LLM providers without changing application code by placing a gateway between your applications and the providers, so applications call a route and the gateway decides which provider and model answers. Re-point the route in configuration, and every application using it changes models at once. Workato Model Gateway works this way: applications connect through an OpenAI-compatible or Anthropic-compatible API, and the gateway resolves each call to a provider and model under the policies an administrator attached.
Most teams feel this problem the first time a model gets deprecated. Each service that calls an LLM tends to hardcode a provider, a model name, and an API key, so replacing one model means editing, testing, and shipping all of those services.
Why is switching LLM providers hard today?
Switching is hard because the model choice lives in client code. A provider SDK, a model string, and a credential sit inside every service, and that setup creates three problems. Nothing enforces the choice, so a team can call any model it likes, including ones that are unreviewed, non-compliant, or too costly. Every change needs a redeploy, and nobody can see in one place which model is being called on whose behalf.
Finance feels it too. Usage lands on separate provider invoices that no one reconciles by team, so the bill arrives long after the decision that caused it.
What is the gateway pattern for model calls?
The gateway pattern puts one governed endpoint in front of every model provider. Your applications send requests to that endpoint in a familiar API format. The gateway authenticates the caller, applies policy, forwards the call to the chosen provider, and logs the result.
The idea that makes it work is indirection. The application never names a provider. It names a route, and the route names the provider and model, so changing the route changes the destination for every caller. DNS did the same thing for hostnames and service meshes did it for service addresses, and this applies the move to model access.
How do routes let you change models by configuration?
A route is a stable ID that resolves to a provider and model, which means your application only ever references the ID. In Workato Model Gateway, an administrator defines routes that point directly at one provider and model, or that use rules matching on tags, keys, parameters, or request complexity. To move traffic off a deprecated model, you edit the route, and no service gets redeployed.
Workato Model Gateway supports three route types, and the rule-based one is the most flexible. In one Workato product demonstration, a rule-based route first applied an employee-safeguards policy to every request. It then picked a model using rules on user balance, quality, and cost.
What does the migration look like step by step?
A migration to a gateway takes four steps, and you can undo the whole thing. First, create a route for each provider and model combination you use today. Second, issue gateway keys scoped by department, sensitivity, or priority using tags. Third, point the application at the gateway endpoint and key instead of the provider’s. Fourth, attach policy such as rate limits and token limits per team, project, or automation.
The application change itself is two lines: point the first call at the gateway base URL and key. If something goes wrong, you point it back, so you can swap providers without touching application code. Applications that already speak an OpenAI-compatible or Anthropic-compatible API need no new SDK.
What stays the same and what changes between providers?
The request and response shape stays the same at the gateway, but model behavior does not. A gateway standardizes the API surface, and it cannot make two models answer identically. Prompts tuned for one model can degrade on another, tool-calling formats differ, and context limits and pricing vary.
So test each route with a fixed prompt set before you move production traffic. A gateway makes that test cheap, because you can send a percentage of traffic to the new route while the rest stays on the old one. Workato Model Gateway also reports success and error views by route, so a regression shows up in the dashboard and not in a support ticket.
How does a gateway handle failover?
When a provider fails, the gateway retries the request against another provider or model you defined for the route. Outages and rate-limit errors are routine at scale, and failover keeps the application running without code that knows about multiple providers. Failover and token metering are built-in Model Gateway capabilities with Workato.
Set the failover target in advance, and check that it sits on your approved-model list. A failover to an unreviewed model quietly defeats the control you set up the gateway to provide.
How do you keep control when models change?
You keep control by treating the approved-model list and the budget as gateway policy, not as team habits. Workato Model Gateway lets an administrator set that list, assign keys and policy at the user or group level, and attach rate and token limits. Token usage reports by input, output, cache read, and cache write, grouped by model, provider, and route, so you can see what each switch did to cost.
Workato runs its own AIRO agent system on its model gateway, with budgets and quotas per period and model switching by task complexity. That is the same switching pattern this article describes, applied to Workato’s own product.
Summary: Switching LLM Providers Without Code Changes
Route model calls through a gateway and switch providers by editing a route. Applications call a route ID instead of a provider and model, and Workato Model Gateway accepts OpenAI-compatible and Anthropic-compatible calls. Re-pointing a route moves every caller at once with no redeploy, but test the new model against a fixed prompt set first, because behavior still differs. Keep the approved-model list and token limits as gateway policy.
FAQ
Can I switch from OpenAI to Anthropic without rewriting my application?
If your application calls through a gateway with a compatible API, yes for the connection. Model behavior still differs, so re-test prompts.
What is a route in a model gateway?
A route maps a stable ID to a provider and model, directly or by rules. Applications use the ID.
Does a model gateway add latency?
A gateway adds a network hop. Measure it on your own traffic. Workato Model Gateway reports success and error views by route.
How do I roll back a model switch?
Edit the route back to the previous provider and model. Because applications reference the route, the rollback also needs no redeploy.
Who should own model routing?
Platform or AI engineering owns the routes. Security owns the approved-model list. Finance sets budgets.
About the Author
Brad Griffith
More on AI Agents & Orchestration
A rounded rectangular loop of gradient flow line with small nodes and a central ring, with a yellow diamond at one corner, on a deep navy field.
What Are Agentic Workflows?
An agentic workflow is a business process in which an AI agent decides what to…
Nov 11, 2026
[External] ai-gateway-vs-api-gateway
What Does an AI Control Plane Include?
An AI control plane includes six components: a gateway layer, a registry and catalog, identity,…
Nov 11, 2026
Concentric thin blue rings carry small nodes of different shapes, with a gradient arc on the middle ring and a yellow diamond, on a deep navy field.
Agentic Orchestration vs Orchestrating Agents
Orchestrating agents is coordinating several AI agents so they work together on a task, and…
Nov 11, 2026
