Orchestrating agents is coordinating several AI agents so they work together on a task, and agentic orchestration is the enterprise layer that runs, governs, and records work done by agents, tools, systems, and people. The first is a design pattern inside an application. The second is an operating layer across applications. Workato provides the second: Agents, called Genies, built in Agent Studio can coordinate with other agents, and the platform runs the processes and controls around them with a 99.99% SLA.
The two terms get mixed up because both contain the words “agent” and “orchestration.” The real difference is scope. One coordinates agents, and the other coordinates the work those agents do.
What does orchestrating agents mean?
Orchestrating agents means one component directs several agents. A planner agent might split a goal into subtasks, hand each one to a specialist agent, and stitch the results back together. The scope is the agents themselves and the messages they pass to each other. That makes it a good way to break up a complicated task, but its boundary is the application that hosts the agents, so it says nothing about who the agents act as, which business systems they may change, or who can see what they did.
What does agentic orchestration mean?
Agentic orchestration means coordinating agents together with the enterprise processes, systems, and people they work with. It starts work from business events, runs multi-step processes, calls governed tools, routes approvals, and records every step. In Workato, agentic orchestration is what the Execution Plane does when agents are in the loop, and the Control Plane governs it.
How do the two compare?
The two differ in scope, ownership, and what they govern.
| Dimension | Orchestrating agents | Agentic orchestration |
| What is coordinated | Agents and their messages | Agents, tools, systems, and people |
| Where it lives | Inside an agent application or framework | Across the enterprise on a platform |
| Triggers | A user prompt or a parent agent | Prompts, business events, and schedules |
| Identity | Defined by the app | End user’s own connection |
| Governance | Application-level | Platform-level policy, approvals, and audit |
| Workato component | Agent-to-agent collaboration | Agent Studio, Enterprise Skills, recipes, Enterprise MCP |
Read the table row by row and one pattern shows up. Orchestrating agents lives where the agents live, and agentic orchestration lives where the work lives. That is why the first calls for a framework and the second calls for a platform. It is also why the hard governance questions land on the second.
Where does agent-to-agent coordination fit in Workato?
It fits as one capability inside agentic orchestration. Workato’s Agent Gateway covers agent-to-agent collaboration through open protocols such as A2A. Calls that end at a tool pass through the MCP Gateway, and LLM calls made during an agent conversation pass through the Model Gateway. The payoff is that Workato’s policies, registry, and audit trail apply to both flows, with no separate configuration surface to maintain.
Why does the distinction matter to buyers?
It matters because a framework for orchestrating agents does not answer enterprise questions. You still have to ask who the agent acts as, what it may write, how errors get handled, and what an auditor can see. A design that coordinates ten agents but gives each one a shared service account has scaled the problem, not solved it. Agentic orchestration answers those questions once, at the platform layer, so every new agent inherits the answers.
When do you use each, and do they work together?
Orchestrating agents solves task decomposition, and agentic orchestration solves production operation. Use agent coordination when one problem needs several specialists, such as research, drafting, and review. Use agentic orchestration when the result has to change records in Salesforce, ServiceNow, or Workday, with identity, approvals, and audit.
Most production deployments need both. In a combined design, a coordinating Genie receives the request and decides which specialist to involve, and each specialist calls Enterprise Skills to do the actual work. Skills return deterministic output, handle errors inside the skill, and write job history for every invocation, while Verified User Access runs each one as the real user. Workato shows delegation patterns like this in Agent Studio demonstrations.
How do you decide which one you need?
Ask whether the work leaves the application. If your agents only read and reason inside one app, a coordination pattern may be enough. If they write to business systems, run on events, or need approvals and audit, you need agentic orchestration.
Start with the controls. Ask any vendor to show an agent acting under a named user’s permissions, along with the log of that call. Workato’s customer base is 25,000+ organizations running 1 trillion+ tasks, and that is the execution layer your agents would sit on.
Summary: Agentic Orchestration vs Orchestrating Agents
Orchestrating agents coordinates agents, and agentic orchestration runs and governs the enterprise work they do. Agent coordination is a pattern inside an application, while agentic orchestration is a platform layer across systems, people, and events. Workato’s Agent Gateway covers agent-to-agent calls under shared policy, and production deployments need identity, approvals, and audit either way.
FAQ
What is multi-agent orchestration?
Multi-agent orchestration is coordinating several agents on one task. It is a subset of agentic orchestration.
Is agentic orchestration the same as workflow orchestration?
No. Workflow orchestration runs fixed processes. Agentic orchestration includes agents that choose steps.
Do I need a framework to orchestrate agents?
Frameworks help build agents. They do not supply enterprise identity, governance, or execution.
Does Workato support agent-to-agent communication?
Where do humans fit?
Approval steps pause a Genie until a person responds.
![[External] ai-gateway-vs-api-gateway](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-ai-gateway-vs-api-gateway-1-768x307.png)
![[External] switch-llm-providers-without-changing-code](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-switch-llm-providers-without-changing-code-1-768x307.png)
