You set AI token budgets by routing all model traffic through a gateway, issuing keys scoped to teams, attaching rate and token limits to those keys, and reviewing metered usage by model against outcomes. Budgets only hold when they sit in the request path, because a spreadsheet cannot stop a loop that is burning tokens at 2 a.m. Workato Model Gateway attaches rate limit and token limit policies per team, project, or automation, and reports usage by input, output, cache read, and cache write by model, provider, and route.
The sequence matters: meter first, scope second, limit third, review fourth.
Why do token budgets need to live at the gateway?
Because the gateway is the only place every model call passes. Provider invoices arrive monthly and by account, so they show total spend and not which team caused it. Application code can enforce limits, but then every application has to reimplement them. A gateway enforces one limit for every caller, and Workato’s gateway is the point that authenticates the caller, applies the policies an admin owns, and captures the call for audit and observability.
What do you need to attribute spend to a team?
You need an identity on every call that maps to a team, because attribution fails when many teams share one provider key. In Workato Model Gateway, you can scope keys by department, sensitivity, or priority using tags, and assign policies at the user or group level. Each call arrives with a key, so usage reports can group by team and by key. In Workato’s AI Control Plane you can see spend by team, model, and cost center, and by key, agent, and tag, so costs can be charged back.
How do you set a limit for each team?
Choose a unit, an allowance, and a window. The unit can be requests or tokens, and the window can be a minute for rate protection or a month for budget. Workato supports rate limit and token limit policies per team, project, or automation. A reasonable starting design pairs a tight rate limit, which stops loops quickly, with a monthly token allowance sized from the last 30 days of metered use. You can also set budgets that alert well before they’re blown.
How do you budget by model?
Price each model’s tokens separately, and track input, output, and cached tokens per model. A million output tokens from a frontier model and from a small model are different amounts of money. Workato Model Gateway reports token usage by type and model, so the same dashboard that shows a team’s total also shows which models drove it. An approved-model list keeps teams from choosing a model finance hasn’t budgeted. Our guide to what an LLM router is covers routing easy tasks to cheaper models.
What should happen when a team reaches its budget?
Decide in advance, because you have four options: alert, throttle, route to a cheaper model, or block. Alerts suit exploration, while blocks suit production workloads where overspend has a material cost. Choose per workload, not per company. A customer-facing agent probably should degrade to a cheaper model before it fails, whereas an overnight batch job can simply stop.
Confirm how your gateway behaves at the limit before you rely on it. One concrete example is Workato’s AIRO: each workspace has a token budget per model over a rolling 60-second window, and when a workspace exceeds it, requests are throttled and users may see up to a 30-second delay until the budget refreshes.
How do you connect budgets to outcomes and review spend each month?
Track cost per completed task for each workflow. BCG recommends cost per outcome as the key metric, along with a standing review of the highest-token workflows against what they produce. Workato job history records what each run did, so you can set tokens against completed work. Our guide to token cost per completed task covers the method.
Each month, review the top workflows by tokens, the cache share of input, the teams nearest their limits, and the routes with rising errors. For each top workflow, ask what outcome it produced and whether a cheaper route would have done. Workato’s own AIRO runs on its Model Gateway with budgets and quotas per period and model switching by task complexity, which is a first-party example of the cycle.
Summary: Setting AI Token Budgets
Set budgets at the gateway, by key, with limits and metering by model. Route all model traffic through one gateway, scope keys by team, department, or priority, and attach rate and token limits per team, project, or automation. Then meter by model and by token type, and review cost per outcome monthly.
FAQ
How do I track AI spend by team?
Issue each team its own key through a gateway and report usage by key.
What is a token limit?
A cap on tokens a key or team may use in a window.
Can I set budgets by cost center?
Yes. In Workato’s AI Control Plane you can view spend by team, model, and cost center and set budgets with early alerts.
What happens when a team exceeds its budget?
You choose: alert, throttle, route to a cheaper model, or block.
Do budgets cover agents and automations too?
Workato attaches limits per team, project, or automation, so agents and recipes calling the gateway are covered.
![[External] how-to-govern-ai-agents-at-runtime](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-how-to-govern-ai-agents-at-runtime-1-768x307.png)
![[External] mcp-gateway-vs-ai-gateway](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-mcp-gateway-vs-ai-gateway-1-768x307.png)
