Introducing Workato’s Callable Recipes and REST API Connector
Gautham Viswanathan
Jul 27, 2016
Callable Recipes are Workato integration recipes that wait for you to call upon them instead of running in the background. A regular recipe begins doing work when the trigger, an external force, occurs. The Callable Recipe only begins work if it is called by another recipe or a Rest API. They make recipe building less complex and help developers create simple apps faster. There are two kinds of Callable Recipes: 1. Callable Recipes for Recipe Building You can create and save snippets of business logic as a callable recipe, then insert them into a new recipe. These snippets could be the workflow for error handling, approval workflows, or any set of steps in a recipe you use often. It will keep the complexity of your recipes low and only require you to make changes in one place. 2. REST Endpoint You can provide a REST API endpoint to an outside party so they can activate the start of a recipe without logging into Workato or use a REST endpoint to bring data from an outside API into an application. Invoking recipes
Related: A guide to integrating REST APIs
Using Callable Recipes In Other Recipes
There are certain steps in a recipe that are often repeated in other recipes, such as the logic for error handling. Now, instead of building out the same 5 steps in each of your recipes, you can save time and make recipe creation easier with a Callable Recipe for Recipe Building. Think of callable recipes like a library of recipe sections that you can grab and insert into a recipe whenever you want to. Some common recipe sections that make useful Callable Recipes include expense approval, auto-provisioning accounts in your apps, the notification process when things are not working correctly, and error handling to name a few. Making these recipe sections pre-made and readily available to insert into recipes not only makes recipe building faster, but ensures consistency in your business processes while reducing complexity in your recipes. Let’s take a look at an example to see how this works. Say you want to automate the process of creating an invoice in Quickbooks Online (QBO) when an opportunity is closed-won in Salesforce. In order to create a QBO invoice, you’ll need to create a new customer if the customer does not already exist in QBO. Now, this snippet of logic: “creating a customer in QBO when they don’t already exist,” is a process that is necessary not only with your Salesforce to QBO integrations, but also when you have Point Of Sale (POS) transactions flowing into QBO, invoices you receive from your vendors and more. Instead of recreating the logic for “creating a customer in QBO when they don’t already exist,” you can make this snippet of logic into a Callable Recipe. Related: 5 examples of API integration Step 1: Create the Callable Recipe Create a recipe and set the trigger as “Receive request” from the “Callable Recipe” connector. *Originally the app was called “Workato Recipe” it is now called “Callable Recipe.” 1 callable recipe in recipeSetup the action to create the customer in QBO if it does not exist and to reply back with the Customer ID. callable recipe 2 Your Callable Recipe is now ready to go and looks like this: callable recipe section Step 2: Calling the Recipe Created in Step 1 into a New Recipe Now that we have created a Callable Recipe, let’s see how this is used in a new recipe that will create an invoice in QBO when an opportunity is closed-won in Salesforce. call recipe finished You’ll notice that Step 1 in Actions is the callable recipe titled, “Call ‘Create QuickBooks Customer if customer does not exist‘ recipe.” These Callable Recipes make your recipe shorter and easier to read. If you want to make a change to the logic in one of these processes, you would only have to make the change in one place (to the callable recipe) and all of your recipes will automatically be updated, making you and your business more agile.
Calling Recipes from Other Apps with REST API
Enabling a REST endpoint for recipes makes it available to be called by any application, internal or external, as long as they have the API token to do so. The token ensures the security of your API. Choosing to build simple web and mobile apps using Workato and a REST Endpoint takes out a majority of the custom coding that would be involved and ensures a fast turnaround. There are two ways you can use a REST Endpoint:
1. Bring Information Into An App
You can connect any app that has an API available with a REST Endpoint even if Workato doesn’t have a connector for that app. For example, if you want to bring in information from Zillow.com so you know how much a real estate property is worth, you can create a REST Endpoint that will populate your fields in QuickBase every time an employee run the recipe.You can also create a button that will start the REST Endpoint recipe. You can place the button wherever you would like, for example inside of Salesforce, so employees can tell the recipe to run without logging into Workato.
2. Send Information Out Of An App
Another scenario where this is useful is monitoring a supply chain – you could have a business partner call upon the REST endpoint you created to track shipping or generate a report via a link on your internal website. You can embed this anywhere you want. Let’s look at the same example we used previously. To enable REST endpoint for the recipe, all you need to do is set the REST endpoint as true and then provide the additional information as shown below. create rest endpoint To manage the REST endpoints and the API tokens, go to “Service Catalog” under your username on the right hand corner of the screen. Here, you can easily test your REST endpoints and find the specific URL used to call the REST API. These screenshots will show you a more detailed view of REST API management: That’s it! As you can see from the above, creating Callable Recipes is a breeze. These will help you create sections of business logic that you can use with other recipes and applications, expand your automation capabilities, and increase your productivity!
Start Building Your Own Callable Recipe >
Not sure how you can use a callable recipe in your workflow? Contact us at info [at] workato.com and tell us your use case, we’re happy to help!
About the Author
Gautham currently heads Products at Workato, where he was part of the founding team. Previously as an early employee of TIBCO, he led the development of several Integration products that powered TIBCO’s growth from a startup to one of the top names in Enterprise software.
More on Company & Product News
Sep 30, 2026
9 min read
Workato Cheat Sheet: Best Practices for Business IT Teams
In a world where speed wins, the no-code revolution promises agility, cost savings, and democratized…
Jul 24, 2026
Company & Product News, Differentiation
MuleSoft Lost Its Leader Status in Gartner’s Magic Quadrant™
For years, MuleSoft rode high on the strength of its API-led integration model. But in…
Jul 11, 2026
3 min read
