If you are an enterprise leader evaluating AI right now, the signal-to-noise ratio is brutal. Every vendor claims agentic capabilities. Every pitch deck promises autonomous agents that will run your business for you. And every week brings a new “best of” list that makes it harder, not easier, to know what is real.
So here is one way to cut through it: look at where customers are actually placing bets, not where vendors say they should.
This spring, Workato earned recognition across two of G2’s most visible programs: Best Software Products of 2026 and the G2 Spring 2026 Reports. These are driven entirely by verified customer reviews and they point to something bigger than category leadership.
They point to platform-level adoption. The kind that signals where enterprises are actually standardizing as AI moves into production.
Enterprises are not buying agentic AI tools. They are buying the infrastructure that makes agentic AI work.
What the numbers say
The headlines worth paying attention to:
- Named to G2’s Best Agentic AI Software Products of 2026, alongside Best Development Software, Best IT Management Software, and Best Global Sellers
- Received 42 #1 rankings across enterprise categories in the G2 Spring 2026 reports
- Featured in 297 G2 Spring 2026 reports spanning integration, orchestration, data, APIs, and AI
G2 rankings are driven entirely by verified user reviews. Customers reporting on whether the software delivers and that distinction matters. When recognition spans this many categories, earned this way, it stops being about winning a label and starts reflecting how enterprises are actually using the platform.
Why the Agentic AI recognition is worth a closer look
Getting named to G2’s Best Agentic AI Software is notable on its own. But the context around it tells a sharper story.
Deploying AI agents inside an enterprise is not a model problem. The models are getting better every quarter.
The problem is everything around the model: secure access to core systems, governed data flows, identity-aware permissions, and reliable orchestration underneath. This is where most agentic AI initiatives stall. The agent works in a demo, but not in production.
Workato’s recognition in this category reflects its role as the infrastructure layer that makes agentic AI enterprise-ready. Enterprise MCP provides identity-aware access, verified actions, and deep process context so agents can operate on core systems with the governance that production environments require.
The fact that this recognition comes from customer reviews, not analyst scoring, signals something specific. Enterprises are not just evaluating Workato for agentic capabilities. They are deploying it.
297 reports, one pattern
G2 categories are intentionally granular. They reflect how buyers evaluate software across different teams, use cases, and levels of maturity.
Showing up in 297 of those reports is not breadth for its own sake. It indicates customers are using Workato across multiple departments, multiple architectural layers, and multiple stages of maturity.
IT, data, GTM, operations. APIs, workflows, automation. Integration, orchestration, AI.
This is how enterprise platforms behave. Not as tools for a single function, but as systems that organizations standardize on.
The specific #1 rankings reinforce the same point. Look at where Workato leads:
- #1 in the Enterprise Grid for iPaaS and the Grid for Process Orchestration, the two foundational layers for enterprise automation
- #1 in the Momentum Grids for API Management, Data Replication, and Reverse ETL, the data and connectivity layers feeding AI
- #1 in the Momentum Grids for Embedded Integration Platforms and Process Orchestration, reflecting adoption by both internal teams and SaaS companies building on Workato
These are not adjacent categories. They are the full stack that enterprise AI runs on: orchestration, data movement, APIs, and embedded infrastructure. Customers are consolidating these capabilities into one platform. They are not managing them separately anymore..
What enterprise AI actually requires
The debate in most organizations right now is about which AI tools to adopt. Which model. Which copilot. Which agent framework. That is the wrong question.
The right question is what sits underneath all of them.
Every enterprise AI deployment succeeds or fails based on three things. Without all three, agents stall at the pilot stage, regardless of how capable the model is.
Context. Agents need unified access to enterprise data, historical activity, and real-time signals across systems. Without shared context, every agent is guessing.
Trust. Agents must operate within enterprise policies. That means identity inheritance, verified actions, permission-aware search, and complete auditability. Without trust, no security team will sign off on production deployment.
Accuracy. Agents must complete business actions reliably. Every action needs to be validated, predictable, and aligned with business rules. Without accuracy, agents create more problems than they solve.
Enterprise MCP provides all three. It is the orchestration layer that governs AI activity across systems, and the G2 data shows that customers are already building on it.
This makes you faster, not slower
The instinct when you hear “infrastructure layer” or “centralized platform” is that it adds overhead. Another thing to set up before you can move.
The opposite is true. Without a shared foundation, every new AI initiative requires its own integrations, its own security review, its own governance model. That is what slows enterprises down. Teams spend months getting a single agent into production because there is no common layer for identity, access, or orchestration.
A centralized infrastructure layer means the next agent, the next copilot, the next AI tool inherits everything that is already in place. Security is solved once. Context is available everywhere. Governance scales with you instead of against you.
The 297 G2 reports reflect this. Customers are not adopting Workato and then staying in one lane. They are expanding across teams and use cases because the platform holds up. That expansion only happens when the foundation accelerates adoption instead of blocking it.
How Workato delivers context, trust, and accuracy
The three requirements outlined above are not abstract. They map directly to what Workato Enterprise MCP provides, built on the #1 iPaaS.
Context: agents need the full picture to act
Most agents fail because they operate blind, without access to data and signals across systems. Workato GO delivers enterprise search and Deep Action, giving agents unified access to your entire stack. They operate with full situational awareness instead of guessing.
Trust: security teams need to say yes
No agent reaches production without governance. Enterprise MCP unifies identity, security, verified actions, and enterprise skills into a single orchestration layer. Every action is permission-aware, auditable, and policy-compliant. That is what gets security sign-off.
Accuracy: business rules cannot be optional
Agents that act unpredictably create more problems than they solve. Agent Studio lets teams build, deploy, and supervise AI agents with composable enterprise skills that enforce validated actions aligned to business rules.
These capabilities share the same context engine and governance model through Workato ONE. Enterprises keep full flexibility to adopt any AI models, agents, and applications. The orchestration, security, and control stay centralized.
The noise will keep coming
The vendor claims will get louder. The “best of” lists will multiply. The signal-to-noise ratio in enterprise AI is not improving anytime soon.
But the signal is already there if you know where to look.
Thousands of enterprise customers, evaluating real-world performance across hundreds of G2 categories, keep landing on the same platform. For integration. For orchestration. For AI. That is not marketing. That is customers telling you what works.
The question is whether you build on that signal now, or discover the gaps when your agents hit production.
