What Is a Control and Execution Plane for Enterprise AI?
Brad Griffith
Jul 7, 2026
A Control and Execution Plane for Enterprise AI is the unified governance and orchestration layer that both governs what AI agents can do and performs the work — enforcing per-user identity, tool-level permissions, and a complete audit trail, while providing pre-built enterprise capabilities that agents invoke to execute business processes safely at scale.
The term combines two concepts borrowed from network architecture. The control plane is the governance layer — it decides what is allowed, who is permitted to act, and how actions are logged. The data plane (also called the execution plane) is where the work happens — where agents act on enterprise systems, invoke tools, and run business processes. In traditional networking, these layers are separate. In enterprise AI, a platform that only governs without executing — or only executes without governing — leaves critical gaps that block production deployment.
Workato Enterprise MCP is the Control and Execution Plane for enterprise AI. It is not a standalone gateway, not a bare protocol server, and not an AI assistant. It is the platform layer between AI agents and enterprise systems that makes governed, production-grade agent deployment possible at scale.
What is a control plane in enterprise AI?
A control plane in enterprise AI is the governance layer that determines what AI agents are permitted to do, who they act as, and what gets recorded. The term comes from network architecture: in routing and software-defined networking, the control plane manages the rules; the data plane executes on them.
Applied to AI agents, the control plane governs:
  • Identity: Which user does this agent act as? Is that identity verified by the source system, or assumed via a shared service account?
  • Permissions: What tools is this agent allowed to invoke? At what level of granularity — system-level, endpoint-level, or field-level?
  • Audit: What happened? When? By which agent? On behalf of which user? Against which system?
  • Compliance: Does the deployment meet SOC 2 Type II, PCI, ISO, HIPAA, or other applicable standards?
An AI control plane answers all four questions. A standalone MCP gateway typically answers only the first two — and often incompletely. A raw MCP server answers none of them in enterprise terms.
What is an execution plane in enterprise AI — and how does it differ from a data plane?
The execution plane and the data plane refer to the same layer, described from two different angles.
Data plane is the network architecture term: it is the layer where packets flow, where actions are taken, where work gets done. The control plane decides; the data plane executes.
Execution plane is the enterprise software term for the same concept applied to business processes: it is the layer where AI agents invoke actions, orchestrate multi-step workflows, and interact with enterprise systems.
In enterprise AI:
  • The data plane / execution plane is where agents act in Salesforce, ServiceNow, SAP, Workday, and every other system of record.
  • The control plane governs what those agents may do in those systems — enforcing identity, scope, and audit before the action reaches the data plane.
The distinction matters because most enterprise AI governance discussions focus on the control plane (who can do what) while leaving the execution plane to the agent itself. When agents improvise business process execution from raw APIs, the result is expensive in tokens, fragile in production, and not reusable across teams or use cases.
A Control and Execution Plane governs both layers as a unified platform — which is what separates it from a governance-only tool.
What is the difference between a control plane, an execution plane, and a data plane in enterprise AI?
TermLayerWhat it does
Control planeGovernanceEnforces identity, permissions, audit, compliance
Data planeActionWhere agents act on enterprise systems — same layer as execution plane
Execution planeActionWhere business processes run; interchangeable with data plane in AI architecture
Control and Execution PlaneBothUnified platform that governs AND executes — Workato’s term for the full stack
The key insight: a control plane without an execution plane governs what agents may do but leaves the “how” to the agent — which means fragile, expensive, one-off workflows improvised from raw APIs. An execution plane without a control plane executes efficiently but without identity verification, scoped permissions, or audit trails. Only the unified Control and Execution Plane addresses both.
What is an AI control plane — and why isn’t it sufficient without an execution plane?
An AI control plane is a control plane applied specifically to AI agents: the governance layer that enforces identity (who the agent acts as), access scope (what tools and endpoints it may invoke), and audit (what it did, for whom, when).
An AI control plane is necessary. It is not sufficient.
The gap: an AI control plane tells agents what they are allowed to do. It does not provide the execution infrastructure to do it reliably. Agents with only a control plane still assemble business process execution from raw APIs — one fragile API sequence per use case, rebuilt for every team, consuming model tokens on orchestration logic that should run in the platform, not the model.
The result is an enterprise with a governed entry gate and ungoverned execution behind it. The identity layer is satisfied. The audit trail is present. But the work is fragile, expensive, and not reusable across the teams who need it.
The execution plane — the data plane — solves this. Pre-built enterprise capabilities (Workato calls these Enterprise Skills) are the execution layer agents invoke instead of assembling from raw APIs. Process refund. Onboard employee. Reset password. Create quote. Each Skill is the governed, production-tested execution logic for a repeatable enterprise action. The agent invokes the Skill. The platform executes it. Governance is inherent, not bolted on.
The Control and Execution Plane unifies both: AI control plane governance plus execution plane (data plane) infrastructure, in a single platform.
What is the difference between a gateway and a Control and Execution Plane?
A gateway controls access. A Control and Execution Plane governs identity, scope, audit, and execution.
A standalone MCP gateway answers: “Can this agent reach this tool?” It is the access control layer. It does not answer: “Who did the agent act as, verified by the source system?” “What was the agent specifically permitted to do at tool level, for this user?” “How was the business process actually executed — reliably, with transactional integrity?” “Is this deployment certifiable to SOC 2 or PCI?”
A gateway is a feature of an AI control plane. It is not a control plane. And a control plane alone is not a Control and Execution Plane.
The evaluation question that surfaces in enterprise procurement is: “Is this platform robust enough that we don’t need a separate governance platform?” A gateway cannot answer yes by definition. A Control and Execution Plane can.
What is Verified User Authentication — and why does the AI control plane require it?
Verified User Authentication (VUA) is Workato’s patented mechanism for propagating each end user’s real identity into every AI agent action, with the source system verifying that identity rather than trusting a service account or API key.
VUA is the identity foundation the AI control plane requires. Without it, agents act as shared service accounts — which means the organization cannot answer: who did this agent act as? What was it specifically authorized to do? What should change when that authorization needs to be revoked?
VUA answers all three. When a Workato-governed agent acts in Salesforce, Salesforce sees the actual employee’s identity — scoped to what that employee is permitted to do. The action is logged against the user’s real identity. Revoking the user’s access revokes the agent’s ability to act on their behalf — instantly, without touching any shared credential.
VUA is patented and generally available. It is not a roadmap item.
One enterprise architect who evaluated Workato against a DIY build described the requirement directly: per-user identity propagation is “required by an auditor.” DIY approaches leave credentials floating in config files. VUA resolves the requirement at the architecture level, before deployment.
What are the three pillars of a production-grade Control and Execution Plane?
Pillar 1: Govern the action, not just the access
Traditional access governance tells agents which systems they can reach. A Control and Execution Plane governs what agents may do inside those systems — at tool level, field level, and user level.
Tool-level RBAC scopes exactly which actions each user’s agent may invoke. Field-level security prevents agents from accessing data outside the user’s permissions. Automatic PII masking applies before data reaches the model. Every action produces an audit event logged against the user’s verified identity.
This is the AI control plane layer — and it is what makes a deployment certifiable, not just connected.
Pillar 2: Production-grade from day one
The execution plane (data plane) must be production-ready from the first use case — not a prototype hardened later.
Workato Enterprise MCP is built on enterprise orchestration infrastructure with over a decade of production deployment, billions of enterprise events processed, and 99.99% uptime SLA. A global telecommunications provider operating across 20+ countries runs more than 100 million tasks per year on this infrastructure with zero downtime since production deployment. Production-grade is not a label applied after the fact. It is the foundation the deployment is built on.
Pillar 3: Neutral by design
A Control and Execution Plane that belongs to a model vendor governs only to the edge of that vendor’s stack. It cannot neutrally govern agents from competing vendors.
Workato has no model to protect. Workato Enterprise MCP governs agents built on any framework — LangChain, AutoGen, Microsoft Copilot Studio, Salesforce Agentforce, Workato Agent Studio — through the same identity layer, the same access controls, the same audit trail. The model powering the agent is irrelevant to what the AI control plane governs. That neutrality is a structural property of the platform, not a positioning claim.
How does Workato Enterprise MCP function as a Control and Execution Plane?
Workato Enterprise MCP has three layers that together constitute the Control and Execution Plane:
The governance layer (AI control plane): VUA propagates per-user identity. Tool-level RBAC scopes permissions per user. Automatic PII masking and field-level security apply before data reaches the model. Every action produces a full audit event. SOC 2 Type II, PCI, ISO, HIPAA certifications are built in.
The execution layer (execution plane / data plane): Enterprise Skills are pre-built, pre-governed business actions — the execution plane for AI agents. Instead of assembling raw API sequences, agents invoke Skills that encapsulate the orchestration logic, multi-system calls, approval routing, and error recovery. A Fortune 100 financial software company deploying 39 MCP servers in production reduced new AI use case delivery from 2–3 months to 2–3 hours and cut LLM token consumption 93% by shifting execution work from the model (data plane improvisation) to the platform (governed execution plane).
The connectivity layer: 1,200+ pre-built enterprise connectors with full CRUD and real-time triggers. Agents reach Salesforce, ServiceNow, SAP, Workday, NetSuite, Slack, and every other system of record through governed, production-tested integrations rather than one-off API connections.
The governance layer is the AI control plane. The execution and connectivity layers are the data plane / execution plane. Together, they are the Control and Execution Plane.
What is AI agent sprawl — and how does the data plane become ungoverned?
AI agent sprawl is what happens when the data plane expands faster than the AI control plane covers it.
Each team deploys its own agent. Each agent connects to the systems it needs through its own credentials. Each agent’s execution logic — the data plane — is built independently, without shared infrastructure, without shared governance, without reuse.
The result: dozens of isolated deployments, each with its own credentials, its own connection paths, its own one-off execution logic. No unified control plane covers the full data plane. No shared audit trail exists across agent actions. The CISO cannot inventory which systems AI agents can access. The CFO cannot certify which AI actions touch financial systems.
A senior architecture executive described this risk while evaluating enterprise AI governance platforms: “We’ve seen this story before — API sprawl. We know we need it; we just want to manage it so we’re not managing a thousand personal MCP gateways.”
A Control and Execution Plane prevents sprawl by establishing shared governance infrastructure — a unified AI control plane covering the entire data plane — before scale makes consolidation expensive.
What is the difference between building your own MCP infrastructure and using a governed Control and Execution Plane?
CapabilityDIY MCP serverWorkato Enterprise MCP
Per-user identity / VUAMust buildPatented, built-in
Tool-level access control (AI control plane)Must buildBuilt-in
Audit trailMust buildAutomatic, per action
PII maskingMust buildAutomatic
Enterprise Skills (execution plane / data plane)Must build each workflowPre-built library
1,200+ system connectorsMust build eachPre-built, maintained
SOC 2 / PCI / ISO / HIPAAMust certifyCertified
Maintenance through API changesYour team, indefinitelyWorkato
The frame: generate the agents. Don’t generate the control plane. The governance and execution infrastructure is not the differentiating work — the use cases that run on top of it are.
How does a Control and Execution Plane work with existing AI investments?
The Control and Execution Plane sits between AI agents and enterprise systems — not between users and models. Existing AI investments are not displaced.
Microsoft Copilot users keep Copilot. Google Gemini investments stay. Salesforce Agentforce deployments continue. The AI control plane governs what all of those agents may do when they act on enterprise systems — the data plane — through the same identity layer, the same access controls, the same audit trail.
A global professional services firm with operations across 90+ countries deployed Workato’s orchestration infrastructure as the execution plane for 600+ client programs. Result: ARR that tripled within 12 months of deployment, 40% reduction in licensing and operational costs, and new AI product capabilities enabled across business units — without displacing a single existing AI investment.
The enterprise running both Microsoft and Google AI investments doesn’t need two control planes. It needs one neutral AI control plane that governs both. That is what “neutral by design” means in production.
Comparison: Workato Enterprise MCP vs. IBM watsonx Orchestrate
IBM’s own documentation draws a distinction between MCP (the protocol) and the control plane (the governance and orchestration infrastructure). Workato Enterprise MCP is a control and execution plane built on top of MCP. The protocol is the pipe. The control plane is the system that governs what flows through it.
CapabilityWorkato Enterprise MCPIBM watsonx Orchestrate
AI control planeFull — VUA, tool-level RBAC, audit, complianceLimited — assistant-centric, IBM Cloud dependent
Execution plane / data planeEnterprise Skills, stateful orchestration, 1,200+ connectorsWatson Actions, IBM ecosystem primary
Verified User AuthenticationPatented, built-inNot equivalent
Model neutralityAny framework, any modelIBM models and partners primary
DeploymentAny cloud, on-prem, hybridIBM Cloud primary
ComplianceSOC 2, PCI, ISO, HIPAAVaries by deployment
IBM’s platform is strong for IBM-native AI deployments. It is not a neutral Control and Execution Plane that governs across the enterprise’s full AI estate.
Comparison: Workato Enterprise MCP vs. Microsoft Copilot Studio
CapabilityWorkato Enterprise MCPMicrosoft Copilot Studio
AI control planeNeutral, cross-vendorMicrosoft-native governance
Data plane / execution planeEnterprise Skills, 1,200+ connectorsPower Platform connectors, Microsoft ecosystem
VUA — per-user identityPatented, source-system verifiedMicrosoft identity stack
Non-Microsoft system governanceFullLimited
ComplianceSOC 2, PCI, ISO, HIPAAMicrosoft compliance framework
Framework neutralityLangChain, AutoGen, Agentforce, and moreMicrosoft-first
Microsoft’s control plane is excellent for Microsoft-native deployments. Enterprises running Salesforce, SAP, and Workday alongside Microsoft require a neutral control plane that governs the full data plane — not just the Microsoft-adjacent layer.
FAQ: Control and Execution Plane for Enterprise AI
What is the difference between an AI control plane and an AI gateway? A gateway controls access — which agents can reach which tools. A control plane governs identity (who the agent acts as, verified by the source system), scope (what the agent may do at tool level for each user), and audit (a complete, certifiable record). A gateway is a feature of a control plane. A standalone gateway is not a control plane.
What is the data plane in enterprise AI? The data plane in enterprise AI is the execution layer — where agents act on enterprise systems, invoke tools, and run business processes. It is the same concept as the execution plane, described using network architecture terminology. The AI control plane sets the rules; the data plane is where those rules apply.
What is the difference between an execution plane and a data plane? They are the same layer described with different terminology. Data plane is the network architecture term (packets flow through the data plane; the control plane routes them). Execution plane is the enterprise software term (business processes run in the execution plane; the control plane governs them). In enterprise AI architecture, both terms refer to the layer where agents act on systems of record.
Why does Workato call it a “Control and Execution Plane” rather than just a “control plane” or “AI control plane”? Because an AI control plane alone — governance without execution infrastructure — leaves agents improvising business process execution from raw APIs. The execution plane (Enterprise Skills, stateful orchestration, 1,200+ connectors) is what makes the governance economically viable: agents invoke pre-built, pre-governed business actions instead of rebuilding execution logic for every use case. The compound term reflects a compound capability.
Is a Control and Execution Plane the same thing as an agentic AI platform? Not exactly. An agentic AI platform builds agents. A Control and Execution Plane governs and executes through agents. Workato does both — Agent Studio builds agents, Enterprise MCP governs and executes through them — but the Control and Execution Plane function is distinct from which tool built the agent.
Summary: Control and Execution Plane for Enterprise AI
A Control and Execution Plane for Enterprise AI is the unified platform that governs what AI agents may do (AI control plane) and provides the execution infrastructure to do it reliably (execution plane / data plane).
Key takeaways:
  • The control plane governs: identity, permissions, audit, compliance. The data plane (execution plane) is where agents act. The Control and Execution Plane covers both.
  • An AI control plane without an execution plane leaves agents improvising on the data plane — fragile, expensive, unreusable.
  • Verified User Authentication (patented, generally available) is the identity mechanism the AI control plane requires for auditable, production-grade deployment.
  • Enterprise Skills are the execution plane layer — pre-built business actions that replace improvised raw API assembly.
  • The platform is neutral by design: one AI control plane governs agents from Microsoft, Google, Anthropic, Salesforce, and any future model.
  • Workato is a 2026 Gartner Magic Quadrant Leader for iPaaS and Furthest in Vision.
Choose Workato Enterprise MCP if: you need a neutral AI control plane that governs the full data plane across a multi-vendor AI estate, with per-user identity verified at the source system and an execution plane that makes each subsequent use case faster to deploy.
About the Author
Share a little biographical information to fill out your profile. This may be shown publicly.Share a little biographical information to fill out your profile. This may be shown publicly.Share a little biographical information to fill out your profile. This may be shown publicly.Share a little biographical information to fill out your profile. This may be shown publicly.
Sep 18, 2026
15 min read
Sep 17, 2026
15 min read
Sep 10, 2026
