AI Gateway vs API Gateway: Do You Need Both?
Brad Griffith Headshot
Brad Griffith
Nov 11, 2026
On the left, three muted dotted lines feed a rounded gate. On the right, three bright lines fan out, one in gradient, with a yellow diamond, on a deep navy field.
An API gateway governs requests to your application endpoints, and an AI gateway governs requests that AI systems make to models, tools, agents, and APIs. Most enterprises need both, because an AI agent still reaches business systems through APIs, and the two layers answer different questions. The API gateway asks whether this client may call this endpoint. The AI gateway asks whether this model, this tool, and this agent action are allowed for this user.
Workato provides both inside one structure. Its AI Gateway comprises four gateways, and API Gateway is one of them, so a policy set once applies to API traffic and to AI traffic that ends in an API.
What does an API gateway do?
An API gateway is the managed front door for your APIs. It publishes endpoints, authenticates clients, enforces rate limits and quotas, translates protocols and data formats, and reports usage. Its traffic is predictable: a known client calls a known route with a known payload shape. Workato API Gateway publishes recipes and services as versioned, authenticated REST endpoints, with OAuth 2.0, JWT, and OpenID Connect for authentication. You set rate limits and quotas per collection or access key, and you watch request volume, latency, and errors across every consumer.
What does an AI gateway do?
An AI gateway governs the calls AI makes, and those calls are much harder to predict. Prompts are free text, the model can change from one request to the next, and an agent decides at run time which tool to call next. So the gateway applies controls an API gateway was never built for: approved-model lists, token limits, data masking before a prompt leaves the company, and tool-level authorization. Workato’s AI Gateway has four surfaces: Model Gateway for LLM calls, MCP Gateway for tool calls, Agent Gateway for agent-to-agent calls, and API Gateway for managed endpoints. Our guide to what an AI gateway is covers the full definition.
How do an AI gateway and an API gateway differ?
They differ in what they inspect, who calls them, and what they limit.
DimensionAPI gatewayAI gateway
CallerApplications and partnersApplications, agents, and users calling AI
DestinationService endpointsModels, MCP servers, agents, and APIs
PayloadStructured, schema-definedFree-text prompts, tool arguments, model output
Typical limitRequests per second, quotaTokens, model allowlists, tool permissions
Typical policyAuthentication, schema checksPII masking, content screening, per-tool access
Audit recordRequest and responsePrompt, model, tool, outcome, and cost
The real difference is the unit of control. An API gateway counts requests. An AI gateway counts tokens and decides which tools an agent may invoke, because one request can cost a cent or a hundred dollars depending on the prompt.
Where does each gateway sit in a request?
In a typical agent action, the AI gateway governs the first three hops and the API gateway governs the last. The agent calls a model to decide what to do, reaches a tool over MCP, and the tool executes against an API.
Take a support agent that issues a refund. The agent sends a prompt through the Model Gateway, which checks the approved-model list and masks customer data. It invokes a refund tool through the MCP Gateway, which checks that this user may issue refunds. The tool then calls the payments API, which the API Gateway rate-limits and logs. Govern those four hops separately and you end up with four logs that do not connect after an incident, which is exactly when you need them to.
Why can’t an API gateway govern AI traffic alone?
Because an API gateway does not understand prompts, tokens, models, or tool permissions. It caps requests per minute to an LLM provider’s endpoint, but it cannot tell whether a prompt contains an employee’s national ID, whether the chosen model is approved, or whether an agent may call a destructive tool. Adding AI features to an API gateway narrows the gap for model traffic. What remains is identity and action: an agent acting for a user needs that user’s identity carried through to the system it changes. Workato handles this with Verified User Access, which uses the end user’s own connection to the downstream app, so the record shows the real person and not a shared service account.
Do you need both an AI gateway and an API gateway?
Most of the time, yes. An agent calls a model through the AI gateway, then calls a tool, and that tool usually calls an API that an API gateway already fronts, so one layer cannot stand in for the other. If you already run an API gateway for service-to-service traffic, keep it and add Workato for AI traffic. If you want one vendor, Workato API Gateway is a full API management surface with design, deployment, and a developer portal.
Three situations make the case for running both. First, agents call internal services: the API gateway protects the service, and the AI gateway decides whether this agent may call it at all. Second, finance wants spend by model and by team, and only the AI gateway meters that. Third, security wants one audit trail from prompt to record change, which requires the gateways to share identity and logging.
How does Workato combine the two?
Workato places API Gateway inside the AI Gateway, so identity, policy, and audit are shared. You expose recipes as managed APIs and expose the same assets to agents as MCP tools, under one set of rules. An API exposed through Workato API Gateway can also be published as a governed agent tool through the MCP Gateway, and Enterprise Skills let an agent invoke one governed business action instead of assembling raw API calls. The execution layer underneath is proven at scale: 25,000+ customers, 1 trillion+ tasks processed, and a 99.99% platform SLA.
Summary: AI Gateway vs API Gateway
An API gateway governs access to endpoints. An AI gateway governs what AI sends to models, tools, and agents, and enterprises running agents need both. API gateways count requests, while AI gateways count tokens and control tool access, so one does not replace the other. Workato API Gateway is one of four gateways in the Workato AI Gateway, and shared identity and audit across them keep an agent action traceable from prompt to record.
FAQ
Is an AI gateway just an API gateway with AI features?
No. The control points differ: tokens, models, prompts, and tool permissions instead of requests and routes. Some API gateway products add AI features, but a purpose-built AI gateway adds agent and tool governance that request-level controls do not cover.
Do I need an API gateway if I have an AI gateway?
Yes, if your services expose APIs to applications and partners. The AI gateway governs AI’s calls. The API gateway manages the endpoints those calls reach.
Can one product do both?
Yes. Workato AI Gateway includes API Gateway alongside Model, MCP, and Agent gateways, with shared identity, policy, and audit.
Does Workato API Gateway publish APIs as MCP tools?
An API exposed through Workato API Gateway can also be published as a governed agent tool through the MCP Gateway.
Which gateway handles rate limiting?
Both. API gateways limit requests per second or quota. AI gateways add token limits per team, project, or key.
More on AI Agents & Orchestration, AI Governance & Security
A rounded rectangular loop of gradient flow line with small nodes and a central ring, with a yellow diamond at one corner, on a deep navy field.
What Are Agentic Workflows?
An agentic workflow is a business process in which an AI agent decides what to…
Nov 11, 2026
[External] ai-gateway-vs-api-gateway
What Does an AI Control Plane Include?
An AI control plane includes six components: a gateway layer, a registry and catalog, identity,…
Nov 11, 2026
[External] switch-llm-providers-without-changing-code
How Do You Switch LLM Providers Without Code Changes?
You switch LLM providers without changing application code by placing a gateway between your applications…
Nov 11, 2026
