AI Control Plane vs AI Gateway: What’s the Difference?
Brad Griffith Headshot
Brad Griffith
Nov 11, 2026
Two stacked rounded bands of thin blue lines linked by dashed gradient connectors, with a yellow diamond on the upper band, on a deep navy field.
An AI gateway is an enforcement point for AI traffic, and an AI control plane is where an organization decides what gets enforced across every enforcement point. A gateway authenticates callers, applies policy, limits usage, and logs calls. A control plane adds the registry of approved models, agents, and tools, plus the policy, identity, cost, and audit layers that span the gateway and any AI built outside it. Workato states it directly: a gateway is a component of the AI Control Plane, and the Workato AI Gateway comprises four gateways.
Vendor marketing often uses the two terms as synonyms. They name different layers, and a product that is only a gateway should not be evaluated as a control plane.
What does an AI gateway do?
An AI gateway sits in the request path and decides whether each call proceeds. It authenticates the caller, applies the policies an administrator owns, and captures the call for audit and observability. Workato describes its gateways as the enforcement point for enterprise AI traffic. The Workato AI Gateway governs four kinds of traffic: model calls through Model Gateway, tool calls through MCP Gateway, agent-to-agent calls through Agent Gateway, and API requests through API Gateway. Our guide to what an AI gateway is covers each one.
What does an AI control plane do?
An AI control plane governs what AI the organization has, what it may do, and what it costs. It owns the registry, the policy model, the identity model, cost views, and the audit trail. Workato’s AI Control Plane has three components: the AI Gateway, the AI Registry and Catalog, and AI Security and Governance. Workato’s documentation draws the line clearly. Gateways handle traffic in flight, while the control plane manages the assets that traffic touches, the identities that authenticate to it, and the policies that govern it.
How do the two compare?
The two differ in scope, role, and what each one knows.
DimensionAI gatewayAI control plane
RoleEnforces policy on calls in flightDecides policy, tracks assets, records results
SeesEach call as it passesThe whole AI estate, including registry and cost
OwnsAuthentication, limits, logging at the callRegistry, policy, identity, cost, audit across gateways
ScopeModel, MCP, agent, and API trafficGateways plus AI built or run outside the platform
Workato productWorkato AI Gateway (four gateways)Workato AI Control Plane
The short version is that a gateway knows about one call at a time, and a control plane knows about everything the calls touch. That gap is why a gateway alone cannot tell you how many agents your company has, or which of them are approved. It is also why a control plane with no enforcement behind it cannot stop any of them.
Can you have one without the other?
You can, but each half has a gap. Many organizations start with a gateway, which enforces limits and logs calls for one traffic type. What it lacks is a registry of approved assets, a shared policy across gateways, and a combined cost and audit view. Workato customers often begin with one gateway and add more, and because the registry, policy model, identity model, and cost view are shared across all four, adding a gateway does not mean a second governance setup.
The reverse is weaker. A control plane without an enforcement point only documents policy. It can inventory assets and define rules, but nothing stops a call that breaks them. The market calls this the gap between “governance documents” and runtime enforcement, and a rule that is not enforced in the request path is a recommendation.
Where does a point gateway fall short?
A point gateway falls short at the second hop. It governs the model call and stops, with no view of what an agent does with the model’s answer or which system a tool call reaches next. Workato sits on the execution path instead. It is the same platform that runs the write, the query, and the update against business systems, so its policy follows the request into the record it changes. Verified User Access carries the real user’s identity to the downstream app, so the log shows a person and not a shared key.
Why isn’t a control plane plus a gateway enough?
Because the pair still leaves the work itself to the agent. Governance tells an agent what it may do, but it does not supply the execution to do it reliably, so each team rebuilds the same multi-step logic from raw APIs. Workato adds the Execution Plane: Enterprise Skills, recipes, and connectors.
The cost difference shows up in tokens. In a Workato-run Jira test, one Workato call used 31,000 tokens, against 164,000 tokens and 3 calls through a vendor MCP server.
How should buyers choose between them?
Write requirements by function, not by product label. List what must be enforced in the request path, then list what must be decided and tracked above it. Ask five questions of any vendor. First, does it enforce at a gateway? Second, does it keep a registry of approved assets? Third, does one policy cover every traffic type? Fourth, does it govern AI built elsewhere? Fifth, does the same platform also do the work?
Summary: AI Control Plane vs AI Gateway
A gateway enforces, and a control plane decides, tracks, and records. An AI gateway is one component of an AI control plane, which adds registry, shared policy, identity, cost, and audit. A control plane without enforcement is documentation, and a gateway without a control plane governs one traffic type at a time. Workato’s Control and Execution Platform adds the plane that does the work.
FAQ
Is an AI control plane the same as an AI gateway?
No. The gateway enforces policy on calls. The control plane decides policy and tracks the whole estate.
Do I need both?
Yes, as AI use grows. The gateway enforces; the control plane keeps policy and inventory consistent across gateways.
What is the difference between a control plane and a data plane?
The control plane governs. The data plane, or execution plane, runs the work.
Can an AI control plane govern third-party agents?
Workato states it can govern AI built elsewhere that routes its calls through it.
Where does the registry fit?
The registry is part of the control plane. It lists approved models, tools, MCP servers, and agents with owners.
About the Author
Brad Griffith
More on AI Agents & Orchestration, AI Governance & Security
A rounded rectangular loop of gradient flow line with small nodes and a central ring, with a yellow diamond at one corner, on a deep navy field.
What Are Agentic Workflows?
An agentic workflow is a business process in which an AI agent decides what to…
Nov 11, 2026
[External] ai-gateway-vs-api-gateway
What Does an AI Control Plane Include?
An AI control plane includes six components: a gateway layer, a registry and catalog, identity,…
Nov 11, 2026
[External] switch-llm-providers-without-changing-code
How Do You Switch LLM Providers Without Code Changes?
You switch LLM providers without changing application code by placing a gateway between your applications…
Nov 11, 2026
