A traditional workflow follows a path a person designed in advance, and an agentic workflow lets an AI agent choose the path at run time within limits the enterprise sets. Traditional workflows are predictable and brittle when inputs vary. Agentic workflows handle variation but need identity, guardrails, and deterministic execution so a flexible agent does not produce inconsistent results. Workato supports both on one platform: recipes for fixed paths, and agents, called “Genies”, built in Agent Studio for decisions, with Enterprise Skills joining the two.
Most enterprises will run both. The design question is which decisions belong to a person’s diagram and which belong to an agent.
What is a traditional workflow?
A traditional workflow is a defined sequence of steps with fixed rules: when X happens, do Y, then Z. A Workato recipe is the standard example, where a trigger fires, conditions branch, and actions run in order across connected applications. Its strength is repeatability, because the same input produces the same output, which makes the workflow easy to test and audit. Its weakness is variation. Every new case needs a new branch, and unstructured input such as an email or a free-text request needs custom parsing.
What is an agentic workflow?
An agentic workflow is a process in which an agent reads the situation and chooses the next step. The agent interprets intent, selects tools, handles exceptions, and asks for help when it cannot proceed. Its strength is flexibility with unstructured input, and its risk is variability, since the agent can choose differently on different runs. That is why production agentic workflows pair the agent with governed tools.
How do they compare side by side?
The two differ in who decides, how they handle variation, and what controls they need.
| Dimension | Traditional workflow | Agentic workflow |
| Path | Fixed, drawn in advance | Chosen by the agent at run time |
| Input | Structured | Structured or free text |
| Decision logic | Rules and branches | Model reasoning within limits |
| Variation | Needs a new branch per case | Handled by the agent |
| Repeatability | High | Lower unless steps are deterministic |
| Key controls | Testing, error handling | Identity, guardrails, approvals, traces |
| Workato component | Recipe | Genie plus Enterprise Skills |
The table hides one important point. These are not rival camps, because the last row shows them working as a pair. The agent supplies judgment, and the recipe supplies the repeatable action.
What changes in how you design and govern them?
Design shifts from drawing every path to defining goals, tools, and limits. In a traditional workflow you write each branch. In an agentic workflow you decide what the agent may do, which tools it can call, and where a person must approve. The tools are often the traditional workflows themselves: a recipe becomes a skill the agent can invoke, which is the practical link between the two. Agentic workflows do not replace recipes, they call them.
Governance moves from the diagram to the runtime. You govern a fixed workflow by reviewing its design, but an agent’s choices cannot be fully reviewed in advance, so controls apply while it runs. Those controls are per-user identity, data masking, content safety, approvals, and a trace of every decision. Workato Genies offer content-safety screening, 31 default PII types plus custom types, and actions to tokenize, redact, or refuse. Tools run under the end user’s own connection through Verified User Access, and conversation traces show each guardrail check, LLM call, and tool call.
What changes in cost?
Cost shifts from build time to run time. A traditional workflow takes effort to build and costs little to run. An agentic workflow costs less to extend but spends model tokens on every run, especially when the agent assembles a process from raw API calls.
Putting the execution into skills limits that spend. In a Workato-run test on one Jira scenario, one Workato server call used 31,000 tokens against 164,000 tokens and 3 calls through Atlassian’s hosted MCP server. Workato Model Gateway reports token usage by model, provider, and route, so the run-time cost stays visible.
When should you choose each?
Choose a traditional workflow when the input is structured, the path is stable, and the outcome must be identical every time. Choose an agentic workflow when the input is free text, the cases vary widely, or the work needs judgment. Many processes need both: an agent to interpret the request and a recipe to carry out the approved action. Intake and triage lean agentic, while posting, provisioning, and payment lean deterministic.
How do you move from one to the other?
Move gradually. Start by wrapping an existing recipe as a skill, expose it to a Genie, and keep a person in the approval step. Review every run at first, then relax review as false-positive and false-negative rates fall, which is the rollout Workato recommends.
Because the same platform runs recipes and Genies, the move does not require replatforming. Workato’s has the enterprise experience here: 25,000+ customers and 1 trillion+ tasks processed.
Summary: Agentic vs Traditional Workflows
Traditional workflows follow a fixed path, and agentic workflows choose the path within limits. The first are repeatable but need a branch per case, and the second handle variation but need runtime governance. In practice the two work together: agentic workflows call traditional workflows as skills, so use deterministic steps for writes and agentic steps for interpretation.
FAQ
Do agentic workflows replace traditional workflows?
No. Agents call governed workflows as skills.
Which is cheaper to run?
Traditional workflows cost less per run. Agentic workflows spend tokens on every run.
Is an agentic workflow riskier?
It can be, because choices vary. Identity, guardrails, approvals, and traces reduce the risk.
What is the difference between a recipe and a Genie?
A recipe is a fixed workflow. A Genie is an agent that decides which tools and skills to use.
Can I mix both in one process?
Yes. Most production processes do.
![[External] ai-gateway-vs-api-gateway](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-ai-gateway-vs-api-gateway-1-768x307.png)
![[External] switch-llm-providers-without-changing-code](https://www.workato.com/the-connector/wp-content/uploads/2026/11/External-switch-llm-providers-without-changing-code-1-768x307.png)
