The Integration Decision Behind AI-Ready SaaS Platforms
Takeaways from WOW 2026 Embedded sessions: What ClickUp, ORO Labs, and CYPHER Learning built first, and what it made possible for AI.
Haillie Parker
Oct 13, 2026
From Embed to AI Featured Blog Image
Three SaaS platform leaders made the same integration decision early on: treat connectivity as part of the platform architecture, not a feature to rebuild for each customer. Today, that’s the layer they’re building AI on top of.
At World of Workato (WOW) 2026, the annual user conference for enterprise orchestration and AI, Workato Embedded customers took the stage to explain how they got there in the session From Embed to AI: The Architecture Decision That Changes Everything, moderated by Matthew Pflughoeft, Embedded Sales Manager at Workato.
On stage were:
Here’s what led each team to that call, and where AI fits now.
Why not keep integrations in-house?
The trigger was different at each company.
At CYPHER Learning, it was demand. Customers couldn’t use CYPHER without a Salesforce integration, and the company was losing money over it. Reuse mattered too: although each customer’s systems were configured differently, the use cases were similar. The company ultimately chose Workato because non-technical users could build on it alongside engineers. Plus, it was reliable, the team loved its UI, and the price was right.
At ORO Labs, it was a build-or-buy call. Procurement touches a long list of enterprise applications. “We had to make a call whether our engineers spend their time building integrations into all of these applications,” Shashidhar explained. Ultimately, they chose to venture outside the company for a solution. “We were looking for a platform that was flexible, mature, and actually had built-in integrations,” he continued.
At ClickUp, Jason’s team compared several platforms and similarly chose Workato for its flexibility and scalability. For Jason, flexibility meant managing many customers in their own environments and writing complex logic, including JavaScript libraries, inside the recipe builder. “Initially, we were starting with some customers that were pretty small, and then we got into the Fortune 100 companies,” he shared. “We needed to scale from maybe a few thousand tasks to hundreds of millions of tasks in individual instances.”
What ClickUp, CYPHER, and ORO achieved with Workato
The integration decision that changed everything panel discussion
Shashidhar Kamath, Joelle Johnson, Jason Foley, and Matthew Pflughoeft at WOW 2026
Standardizing the connectivity layer paid off in how fast – and affordably – each team could deliver.
ClickUp shipped its first integration to a paid customer 30 days after buying Workato. Repeatable templates then took an implementation that started at 60 to 80 hours down to about 10. That let Jason’s team build maintenance into customer contracts and run integrations as a profitable managed service, now with many hundreds of customers.
CYPHER got the same leverage from reuse. Joelle’s team built standard templates for the most common CRM and HRIS platforms. A change gets made once, in one place, instead of being repeated across every customer’s workspace.
“We were able to deliver integrations at speed, integrations that we trusted, integrations that our customers trusted. It was predictable.”
— Joelle Johnson, CYPHER Learning
At ORO, the biggest difference was how contained a change became. Shashidhar said that before orchestration, altering one thing meant touching every integration connected to it. Now policy changes happen in a single layer.
AI needs context, not just access
The reusable connectivity layer also gave each company a foundation for AI. But connecting systems is only the first step; an agent also needs context to interpret what it finds.
Shashidhar used a procurement request to show the difference. An employee wants to know whether they can use a supplier, Acme, for a $300,000 consulting project. Answering that means checking the ERP, contracts, risk, and compliance, and the data is fragmented – there could be ten suppliers called Acme in the ERP and twenty accounts in the contracting system, none of them matching. Each system’s AI can read its own data, but even together they probably can’t answer the question.
ORO’s answer was a context layer that connects the records, the relationships between them, and the customer’s policies. AI uses that context to recommend a route, such as steering the request away from Acme toward a preferred supplier. Deterministic orchestration, with Workato’s integrations connecting each system, then carries it out inside the rules the customer’s IT team has set. For some ORO customers, onboarding a supplier that used to take days now takes 15 minutes.
“Deterministic orchestration doesn’t have to be predetermined. Our AI can say, ‘this is the best thing to do in this scenario.’ But then that deterministic orchestration underlying it can make sure these things happen according to the rules IT has set up for you.”
— Shashidhar Kamath, ORO Labs
Jason described a similar idea from the integration side. A few years back, ClickUp made a bet that context had to be in the system for the AI to be worth anything. With Workato pulling in Salesforce data and customer tickets, ClickUp’s AI can work across them, including through MCP servers. In one example, it compared accounts against tickets and recommended which customers to contact first.
Joelle’s example was role context. In Salesforce, a user might look like any other user while another record lists them as someone’s manager. Because CYPHER’s standard Workato recipes connect those records, the AI can recognize the manager relationship and answer questions about their direct reports’ enrollment and training.
In all three cases, the AI does the reasoning, and Workato’s connectivity underneath gives it connected systems to work with.
Winning in the agentic era
Asked where their AI efforts go next, each panelist described less manual work, for their own teams and for their customers:
  • ClickUp wants to couple orchestration with its native offerings and bring in more data, so customers can stay in one place. Its mantra has been saving users a day a week, and Jason expects AI to save more.
  • At CYPHER, Joelle wants integrations that set themselves up with far less manual effort, so her engineers review what’s been assembled instead of building it.
  • ORO is aiming for a procurement team that spends its time on strategy, with the system carrying out their decisions.
“We were building an Iron Man suit with superpowers for the procurement department, through orchestration. Then along came AI. Now we can put Jarvis inside this Iron Man suit and automate a lot of this stuff. But not everything – we still have someone in the suit, overseeing things.”
Integrate, govern, and scale with Workato
What these three SaaS platforms share is the order they worked in. They built reusable, rule-driven connectivity underneath the product first, so AI has something dependable to run on.
Integration and orchestration are how your product executes. Governance is how you stay in control of what it does. Your AI needs both underneath it.
Workato ONE for SaaS Platforms gives product teams one place to build integrations, orchestration, and agent connectivity once and reuse them across every customer, with identity and audit built in.
Become the platform your customers can’t live without with Workato ONE for SaaS platforms.
More on AI Agents & Orchestration, Customer Stories, Embedded Integration
A rounded rectangular loop of gradient flow line with small nodes and a central ring, with a yellow diamond at one corner, on a deep navy field.
What Are Agentic Workflows?
An agentic workflow is a business process in which an AI agent decides what to…
Nov 11, 2026
[External] ai-gateway-vs-api-gateway
What Does an AI Control Plane Include?
An AI control plane includes six components: a gateway layer, a registry and catalog, identity,…
Nov 11, 2026
[External] switch-llm-providers-without-changing-code
How Do You Switch LLM Providers Without Code Changes?
You switch LLM providers without changing application code by placing a gateway between your applications…
Nov 11, 2026
