Workato named a Major Player in the 2025 IDC MarketScape for Worldwide Data Integration Software Platforms Vendor Assessment
Workato named Major Player 2025 IDC Data Integration MarketScape
We’re excited to share that IDC MarketScape has named Workato a Major Player in the inaugural Worldwide Data Integration Software Platforms 2025 Vendor Assessment.
We see this position as reinforcement of our belief that data leaders must bring data and AI together in the stack. They now face two inseparable objectives: preparing data for AI and using AI to operate on data. The data integration platform, with its agentic AI capabilities, is at the center of this seismic shift.
As AI becomes part of a business’s everyday operations, these leaders are moving away from fragmented, point-solution architectures and toward unified platforms that can govern data, orchestrate workflows, and activate AI in one place. Platforms like Workato One provide that foundation by connecting systems, enforcing security and governance, and enabling AI-powered automation through a single pane of glass.
“The mission statements of vendors that IDC evaluated within this MarketScape reveal a unifying commitment: enabling trustworthy, governed, and AI-ready data at scale. These alignments signal that AI readiness is no longer an add-on but a core design principle across the market.”
— IDC MarketScape: Worldwide Data Integration Software Platforms 2025 Vendor Assessment, #US53001625, October 2025
What is the 2025 IDC MarketScape for Data Integration?
IDC MarketScape vendor analysis model is designed to provide an overview of the competitive fitness of technology and suppliers in a given market. The research methodology utilizes a rigorous scoring methodology based on both qualitative and quantitative criteria that results in a single graphical illustration of each supplier’s position within a given market. The Capabilities score measures supplier product, go-to-market and business execution in the short-term. The Strategy score measures alignment of supplier strategies with customer requirements in a 3-5-year timeframe. Supplier market share is represented by the size of the icons.
The IDC MarketScape evaluates vendors across two dimensions:
  • Capabilities (y-axis): how well a vendor’s current offering meets customer needs today
  • Strategies (x-axis): how well the vendor’s roadmap aligns with what customers will need in the next three to five years
Why Workato is a Major Player
According to the IDC MarketScape:
“Within data engineering use cases, Workato supports multi-object synchronization with schema drift handling, pushdown SQL, dbt orchestration, language-agnostic (e.g., Python, Ruby, and JavaScript) transformations, and operational analytics through a centralized data orchestration dashboard and insights.
“Workato supports ingestion and transformation of a variety of data from structured, semi-structured (e.g., Kafka streams), and unstructured formats (e.g., text documents, images, and videos).
“Customers use Workato to accelerate cloud data initiatives to warehouses and lakes, coordinate high-volume batch and streaming pipelines, and operationalize analytics via reverse ETL and data services.
“Workato Workbot and AI-agents enable human-in-the loop workflows and data stewardship through custom apps in Slack and Microsoft Teams. Workflow apps extend these experiences to web and mobile.”
The report also noted Workato’s key strengths:
  • Unified low-code paradigm for diverse integration patterns: Workato’s recipe model delivers one builder experience across ETL/ELT, CDC-driven syncs, reverse ETL, data activation, event streaming, and API/data services. This consistency helps teams consolidate tooling and reuse skills, assets, and governance for disparate use cases.
  • Cloud-native, serverless scale with enterprise controls: The platform provides elastic scale, fault tolerance, zero-downtime upgrades, and a consolidated operations layer. This reduces DevOps overhead while maintaining control, traceability, and compliance.
  • Broad connectivity and advanced connector runtime: A vast connector library spans SaaS, on premises, ERP, databases, file stores, streams, and APIs, complemented by SDK-driven extensibility. Runtime behaviors — such as exactly-once delivery patterns, in-order processing, deduplication, and resilient retries — support high reliability for data pipelines.
  • End-to-end data pipeline orchestration with engineering depth: Workato supports multi-object sync with schema drift handling, pushdown SQL, dbt orchestration, and language-agnostic (e.g., Python, JavaScript, and Ruby) transformations. Data teams can operate complex flows from a single pane of glass, with run history, dependency insights, and observability tailored to DataOps, FinOps, and operations stakeholders.
We believe these capabilities accelerate cloud data migrations, help coordinate batch and streaming pipelines, and operationalize analytics with reverse ETL and governed data services. You can also surface data, initiate data processes, or monitor automations directly from tools like Claude or ChatGPT using Enterprise MCP, or in Slack and Microsoft Teams using AI Genies with human-in-the-loop capabilities.
Workato’s data integration platform
Workato Data Orchestration Platform is Workato’s AI-powered unified solution for moving, transforming, and activating data across your entire enterprise, from SaaS and on-prem systems to cloud data warehouses and data lakes. It delivers seamless end-to-end data pipelines with intelligent orchestration that adapts to schema changes, self-heals from errors, and provides complete visibility at every step.
Workato Intelligent Document Processing is Workato’s AI-powered solution for extracting structured data from unstructured documents like PDFs, scanned invoices, and email attachments, then enriching and transforming that data for analytics and automation.
Workato Event Streams lets you build event-driven architectures that decouple workflows and process changes only when they occur, so you can minimize the overhead required to maintain high-throughput, real-time event ingestion and processing. This event-driven approach reduces unnecessary processing and enables a decoupled architecture that delivers greater efficiency, higher scalability, and lower latency.
Workato AIRO™, which stands for AI-driven, Intent-based, Real-time Orchestrator, is an AI copilot that helps you improve operational processes. You can ask AIRO to generate, troubleshoot, and modify data pipelines using natural language, and therefore reducing ramp time and accelerating time to value.
Looking ahead, Workato customers can expect deeper ecosystem integrations, expanded support for log-based CDC, and more advanced observability, security, and governance capabilities. AI-assisted build and operations, through copilots and agentic experiences, will further streamline pipeline development, troubleshooting, performance and data quality optimization, and data discovery.
Find out how to simplify operations, improve data quality, and reduce cost and complexity in “From Data Chaos to AI Confidence: Simplifying Enterprise Data at Scale” with Avinash Deshpande, Field CTO, Data and Sai Krishnan, Senior Product Manager.
Where the data integration market is headed
The IDC MarketScape is clear about what’s next:
“AI readiness is no longer optional — data integration platforms must deliver trustworthy, governed, multimodal dataflows to support enterprise strategy transformation and fuel autonomous intelligence in an agentic AI future.”
We believe data leaders can no longer evaluate data integration platforms based solely on throughput or connectivity. To meet the current needs of the business, we believe they must also consider how well the platform enables AI-ready data with governance, observability, and automation as key capabilities.
Workato’s roadmap aligns directly with these priorities.
We see Workato’s IDC MarketScape recognition as validation of our approach: a single platform where organizations bring data, applications, and processes together, so data is not only integrated, but continuously put to work across the business.
To learn more, download your excerpt of the IDC MarketScape: Worldwide Data Integration Software Platforms 2025 Vendor Assessment.
