Community Connectors: What’s new in September 2026
New Community Connectors in September 2026
Baserow
New
Baserow is an open-source no-code database. This connector lets you create, update, search, and delete table rows, list tables and fields, and trigger recipes when rows change. Baserow has a free forever plan (no credit card) with 3,000 rows per workspace and 2 GB of storage.
Use this connector to:
Create or update a row in a Baserow table from another app.
Batch-update up to 200 rows in one request.
Search rows with pagination, search, order by, JSON filters, or field filters (max 200 rows per page).
Get, list, or delete rows, and list tables or fields.
Trigger a recipe when rows are created, updated, or deleted (register the static webhook URL in Baserow).
Additional resources:
Install and start using Baserow connector
Firecrawl
New
Firecrawl turns websites into clean, AI-ready data. Use it to scrape a page to markdown or HTML, extract fields with a prompt or JSON schema, crawl a domain, map a site to its URLs, search the live web, and track whether a page changed since the last scrape.
Scrape one URL to markdown, HTML, JSON, or a full-page screenshot.
Run an Agent job with a prompt and optional URLs or schema, then wait for results.
Look up an Agent extraction job by ID to check status or retrieve data.
Start a crawl on a domain and wait until it finishes.
Look up crawl status, totals, page data, and pagination by job ID.
Return all discovered URLs for a domain.
Search web, news, or image results from the live internet.
Detect whether a page changed since the last scrape.
Install and start using Firecrawl connector
Creatomate
New
Creatomate is a programmatic media generation service. It renders finished videos, images, and GIFs from reusable templates or from a JSON scene description called RenderScript.
Create a render from a template and wait until the hosted output URL is ready
Create a render from raw RenderScript JSON
Get the status of a render created in another recipe or system
List templates to find a template ID
Get a template, including its RenderScript source, to learn modification keys
Create or update a template from RenderScript
Delete a template you no longer need
Install and start using Creatomate connector
Retell AI
New
Retell AI is a platform for building phone-based conversational voice agents. This connector lets Workato recipes place outbound AI calls, look up call status, transcript, and post-call analysis, list agents and phone numbers, and buy Retell numbers.
Create phone call — place an outbound phone call with dynamic variables so the agent greets the lead by name.
Get record (Call) — retrieve call status, transcript, recording URL, and post-call analysis after the conversation ends.
Search records (Call) — list calls filtered by agent, status, and time window.
Get / Search records (Voice agent) — look up the agent ID and webhook URL to use on outbound calls.
Search records / Buy phone number — list owned numbers and buy a new number to use as
from_number. -
Call ended or analyzed — fire when Retell posts
call_endedorcall_analyzedto the recipe webhook URL. -
Custom action — build your own authenticated HTTP request against the Retell API.
Install and start using Retell AI connector
Bluesky
New
Bluesky is a decentralized social network built on the AT Protocol. People use it to share posts, follow others, and send direct messages — similar to other microblogging apps, but with an open protocol so accounts and data are not locked to a single provider. Connect with a free Bluesky account and an app password — no paid API plan required.
Create a post, optionally with up to 4 images (upload each image first; max 2 MB each)
Create a multi-post thread
Upload an image for use in posts, or delete a post
Get a user profile or post engagement (likes, replies, reposts)
List likes on a post, or list a user’s followers
Send a direct message (requires an app password with DM access; the recipient may need to follow you)
Trigger recipes when new notifications arrive, with optional filters by reason
Install and start using Bluesky connector
CoinGecko
New
CoinGecko is an independent cryptocurrency data aggregator providing prices, market data, historical charts, and metadata for thousands of coins.
Get the latest price of one or more coins in one or more currencies
List coins ranked by market data such as market cap and volume
Retrieve the full list of supported coins to resolve coin IDs
Search coins, exchanges, categories and NFTs by free text
Get detailed data for a single coin, including market data, rank and links
Retrieve historical price, market cap and volume charts over time
Get the top trending coins, NFTs and categories
Install and start using CoinGecko connector
Tavily
New
Tavily is a search engine built for LLMs and AI agents, providing real-time web search, content extraction, site mapping, crawling, and deep research through a single REST API.
Search web — execute a web search with control over depth, topic, date range, country, language, domains, and an optional LLM-generated answer.
Extract page content — retrieve the raw content of one or more URLs in markdown or text.
Map website — traverse a site and return a list of discovered URLs.
Crawl website — traverse a site and return extracted page content (defaults stay small to avoid the Workato HTTP timeout).
Run deep research — submit a research task and wait for the completed report and its sources.
Get research result — fetch the status and result of a research task by its request ID.
Install and start using Tavily connector
Jina
New
Jina AI provides Search Foundation APIs for reading web pages into LLM-friendly markdown, web search, text segmentation, embeddings, reranking, classification, and DeepSearch research.
Read URL — convert a web page into clean Markdown/JSON.
Search web — search the web and return LLM-friendly results.
Segment text — tokenize and chunk text.
Generate embeddings — create vector embeddings.
Rerank documents — score documents by query relevance.
Classify text — zero-shot or few-shot text classification.
Deep research — run DeepSearch chat completions (non-streaming).
Install and start using Jina connector
TikTok
New
TikTok is a short-form video platform. This connector uses the TikTok Content Posting API and Display API so recipes can read a creator’s profile and videos and publish posts.
Get user’s profile or creator info from TikTok
List user’s videos, or fetch specific videos by Video IDs
Publish a video or photo carousel to TikTok
Install and start using TikTok connector
PhantomBuster
New
PhantomBuster is a cloud automation platform for social and web Phantoms (agents). Use it to launch scrapers and outreach bots, poll run status, and pull structured result objects into Workato recipes.
Get / Search / Create / Update / Delete record — Agent (full CRUD), Container (get/search a run), Agent output (get). Create saves an agent; it does not launch a run.
Launch agent — queue a Phantom run by agent ID and return the container ID. Does not wait for the run to finish.
Get container result object — fetch and parse the structured result JSON for a container ID. Row fields vary per Phantom; add them as result object fields.
Stop agent — abort a running Phantom by agent ID, with optional soft abort.
Launch agent and wait — launch a Phantom and poll until it finishes, then return the parsed result object.
Install and start using PhantomBuster connector
Serper
New
Serper is a Google Search API that returns structured SERP data as JSON. Search web, places, and news on google.serper.dev, and scrape webpages on scrape.serper.dev.
Search Google web results, including knowledge graph and answer box
Search local businesses with Places
Search Google News
Scrape a webpage
Install and start using Serper connector
Ghost
New
Ghost is a content management system built specifically for blogging, newsletters, and membership. It allows users to write articles, manage a subscriber list, and lock content. Writers publish from Ghost Admin, and newsletters are sent to subscribers by email.
Get record — get a post (by ID or slug) or a member (by ID)
Create record — create a post or a member
Update record — update a post
Search records — list posts or members with filters and pagination
Upload image — upload an image and get a hosted URL
New event — fires when the selected post or member webhook event occurs
Install and start using Ghost connector
Supabase
New
Supabase is an open-source Postgres platform with an auto-generated REST API (PostgREST), object storage, and database webhooks. This connector lets you query and mutate table rows, call RPC functions, search and download storage objects, and receive INSERT/UPDATE/DELETE webhook events in Workato recipes.
Query rows with select, filters, order, limit, and offset.
Insert or upsert rows into a Data API table (optional conflict target).
Update rows or delete rows with a required filter (full-table changes blocked).
Call database function (for example, custom RPCs or pgvector helpers).
Search objects in a Storage bucket and download object for authenticated or public files.
Trigger recipes on Database Webhook INSERT/UPDATE/DELETE payloads. Row columns come from the Data API schema.
Install and start using Supabase connector
Upload Post
New
Upload Post is a social publishing API that posts video, photos, and text to connected social accounts. Posts can be published immediately or scheduled. You can check analytics for your connected platforms. Supported platforms include Instagram, TikTok, YouTube, LinkedIn, X, Facebook, Threads, and others.
Create and list Upload-Post user profiles
Generate a 48-hour URL so a user can connect social accounts
Publish video, photos, or text to one or more connected platforms
Schedule posts, poll async upload status, or search upload history
Trigger recipes when an upload completes (webhook)
Install and start using Upload Post connector
Qdrant
New
Qdrant is a vector database for storing embeddings with payloads and running similarity search at scale. Use this connector to upsert, query, scroll, retrieve, and delete points, and to list, inspect, or create collections — useful for RAG, semantic search, and recommendations in Workato recipes.
Upsert points (id + vector + payload) into a collection.
Query nearest points using an embedding from an upstream step.
Scroll points with pagination support.
Retrieve points by ID, or delete by IDs or filter.
List collections, get collection details, and create collections.
Install and start using Qdrant connector
Connector Enhancements/Bug Fixes
Veeva Vault
Enhancement
Veeva Vault is the cloud-based content and data management platform built for the life sciences industry. It powers clinical, regulatory, quality, commercial, and CRM operations for pharma, biotech, and medical device companies.
Enhancements made:
Added Create document version action
Added Create document relationship action with picklists for source type and relationship type
Install and start using Veeva Vault connector
OData
Enhancement
The OData connector is a universal connector that can be used to work with any application that describes its API endpoints using OData EDMX. To learn more, refer to this OData Documentation.
What is OData?
OData is a specification that acts as a machine-readable interface for describing, producing, consuming, and visualizing RESTful web services.
Enhancements made:
Added On-prem NTLM as a new authentication method alongside existing auth types
Get and Search records now let you pick fields on expanded related objects, not only on the main record.
Install and start using OData connector
Email (Custom) OPA
Enhancement
Email (Custom) OPA is a utility connector enabling seamless email management via SMTP, IMAP, and POP3 protocols through the Workato On-Prem Agent (OPA). It provides the same actions and triggers as Email (Custom), but routes all protocol communication through an OPA Java extension so it works with secure tunnel / on-prem deployments.
Enhancements made:
Improved SMTP send-failure reporting to include the server response, failed recipient, and SMTP command instead of a generic error message.
Install and start using Email (Custom) OPA connector
Latest OPA extension: https://workato-opa-extensions.s3.us-east-1.amazonaws.com/email-opa-extensions/email_opa-extension-latest.zip
Learn more about OPA extensions: On-prem agent – Extensions | Workato docs
SAP Sales Cloud
Enhancement
SAP Sales Cloud is SAP’s cloud CRM for managing accounts, contacts, and sales processes across the customer lifecycle.
Enhancements made:
Scope Search objects output pills to $select
Add $expand input and nested navigation pills
Install and start using SAP Sales Cloud connector
Google Vertex AI
Enhancement
Google Vertex AI is a machine learning (ML) platform that lets you train and deploy ML models and AI applications, and customize large language models (LLMs) for use in your AI-powered applications. Vertex AI combines data engineering, data science, and ML engineering workflows, enabling your teams to collaborate using a common toolset and scale your applications using the benefits of Google Cloud.
Enhancements made:
Replaced the deprecated Get prediction (PaLM 2) action with Generate content, so you can call Gemini models via generateContent API.
Install and start using Google Vertex AI connector
Amplify
Enhancement
Amplify is a strategy execution software that helps organizations manage strategic projects, align them with goals, and track progress through analytics and reporting. Use this connector to fully engage with the initiatives, projects, and actions needed to realize the benefits.
Enhancements made:
Added Create records (batch) action for Raid item, Initiative, Cost, and Benefit.
Install and start using Amplify connector
OpenAPI
Enhancement Bugfix
The OpenAPI connector is a universal connector that can be used to work with any application that describes its API endpoints using OpenAPI. To learn more, checkout the official Documentation and this Video.
Enhancements made:
Preserve Client secret in the runtime connection for VUA (preserve_in_runtime_connection: true)
Added an opt-in Advanced setting (default: off) so OpenAPI job errors can include HTTP status and the full API response body
Bug fixes made:
Fixed a failure when custom request headers used numbers or other non-text values by converting them to text so the request can run successfully.
Install and start using OpenAPI connector
UiPath
Enhancement Bugfix
Telegram is a globally accessible fremium, cross-platform, cloud-based instant messaging app with a focus on security & speed.
Start Job(s): You can now choose Serverless as a Job Type when starting jobs in modern folders.
Start Job(s) (modern folders): Starting a job with a specific user/robot and machine now targets them correctly, so jobs no longer fail with an “Invalid RobotID” error.
Install and start using UiPath connector
SAP Business One
Bugfix
SAP Business One is an all in one solution for small businesses. Gain greater control over your business or subsidiary, and connect and streamline your processes — and grows along with you.
Bug fixes made:
Fixed Search action reliability by preserving the object name so retries consistently return correctly structured results.
Install and start using SAP Business One connector
AWS Secrets Manager
Bugfix
Amazon Secrets Manager helps you protect secrets needed to access your applications, services, and IT resources. The service enables you to easily rotate, manage, and retrieve database credentials, API keys, and other secrets throughout their lifecycle.
Bug fixes made:
Send Secret string as plain text on create/update secret (no longer JSON-encoded).
Install and start using AWS Secrets Manager connector
Azure File Storage
Bugfix
Azure File Storage is a fully managed, cloud-based file shares that can be accessed using standard protocols like SMB and NFS. This connector allows you to create, read and update files in Azure File Storage.
Bug fixes made:
Fixed Upsert file so large uploads no longer stop after the first 4 MB and leave the rest of the file empty.
Install and start using Azure File Storage connector
