Community Connectors: What’s new in June 2026
New Community Connectors in June 2026
GitHub (Custom)
New
GitHub (Custom) is a development platform for version control and collaboration. It lets you host and review code, manage projects, and build software alongside millions of developers.
Use this connector to:
Create a repository and initialize it with a README
Create, read, update, and delete files in a repository with commit messages
Create and manage branches for feature development and content versioning
Create pull requests and assign reviewers for code review workflows
Merge branches programmatically via merge commit
Compare commits and branches to detect divergence and changed files
Search repositories, branches, and directory contents
Poll for new or updated files on a branch on a schedule
Receive push events via webhooks for real-time triggering
Additional resources:
Install and start using GitHub (Custom) connector
A2A Protocol
New
A2A Protocol (Agent-to-Agent) is an open standard for AI agent interoperability, enabling agents built on different frameworks to discover each other, delegate tasks, and exchange results over HTTP.
Send a task to an AI agent and wait for the result
Send a task and retrieve the result asynchronously
Resume a task when the agent requests additional input (INPUT_REQUIRED state)
Check the current status and artifacts of any previously sent tasks
Install and start using A2A Protocol connector
dbt Cloud
New
DBT Cloud is a hosted platform for running DBT projects and managing data transformations.
Trigger a DBT job run.
List jobs and runs for monitoring.
Receive run event notifications via webhook.
Install and start using dbt Cloud connector
XML Creator
New
XML Creator helps generate XML documents from a sample XML template.
Generate XML payloads from a sample XML message and mapped datapills
Preserve XML namespaces, attributes, and element order when needed
Install and start using XML Creator connector
GCP BigLake Iceberg
New
GCP BigLake Iceberg connector enables seamless integration with Apache Iceberg tables managed by the BigLake Metastore on Google Cloud. It is the GCP equivalent of the S3 Data Lake connector, empowering users to discover, register, and process Iceberg tables across their lakehouse infrastructure. The connector manages tables directly through the BigLake API and loads or queries data through the BigQuery Jobs API, automatically handling long-running jobs with built-in polling. It authenticates using a Google Cloud service account with a JWT bearer token, making it ideal for organizations building governed, cloud-native data pipelines and running analytics on large Iceberg datasets with high reliability.
Create a new Iceberg table in the BigLake Metastore pointing at metadata in Cloud Storage
Retrieve table definitions and schema information for data governance and cataloging
List all tables in a BigLake Metastore database to discover available datasets
Import data from Cloud Storage files into a BigLake-managed Iceberg table using a BigQuery LOAD DATA job
Query Iceberg tables with custom GoogleSQL and return the resulting rows
Install and start using GCP BigLake Iceberg connector
Veeva Vault
New
Veeva Vault is the cloud-based content and data management platform built for the life sciences industry. It powers clinical, regulatory, quality, commercial, and CRM operations for pharma, biotech, and medical device companies.
Retrieve, create, or update documents and data records stored in Veeva Vault.
Streamline workflows by integrating Vault actions into approval, review, or data submission processes.
Track audit logs, system events, or record changes to help meet regulatory requirements.
Synchronize or exchange information between Vault and other applications such as CRM, ERP, or cloud storage.
Install and start using Veeva Vault connector
Allure TestOps
New
Allure TestOps is a test management platform by Qameta Software that provides end-to-end test management capabilities including test case management, test plan creation, launch execution, and result tracking.
Create and update test cases with project custom fields
Search custom fields for a project or globally (root) via Search records → Custom field
Search custom field values via Search records → Custom field value
Create test plans, launches, and test results; update and delete records across the test workflow
Install and start using Allure TestOps connector
Connector Enhancements/Bug Fixes
Positional File Tool
Enhancement
The Positional file tool is a versatile Workato connector designed to parse complex flat files into structured JSON outputs. It supports a broad range of parsing use cases, accommodating both fixed-width (Delimiter) and dynamic-width (Position-Length) formats with single or multiple schemas, and handling linear as well as hierarchically nested data structures for the flat files.
Enhancements made:
Fixed nil crash in single_dynamic_schema_parser when row is shorter than column spec
Added preserve_whitespace toggle to all parsers for preserving leading spaces in fixed-width fields
Added new action: Trim CSV file (streaming)
Install and start using Positional File Tool connector
HiBob
Enhancement
Hibob is a distinctive and innovative people management platform that offers fast-growing companies powerful tools to creatively manage a modern workforce, increase productivity, and improve employee experience.
Enhancements made:
Enhanced the output fields for the Search company list action.
Install and start using HiBob connector
UKG Pro
Enhancement
UKG Pro is a comprehensive human capital management (HCM) suite, designed for enterprise organizations, efficiently manages personnel data, handles robust payroll tasks, boosts scheduling efficiency, and helps attract, nurture, and grow your talent — all in one experience.
Enhancements made:
Added search user-defined fields action
Install and start using UKG Pro connector
Gmail (Custom)
Enhancement
Gmail is a free email service developed by Google. Users can access Gmail on the web and using third-party programs that synchronize email content through POP or IMAP protocols.
Enhancements made:
Added message ID for the Get message content action
Install and start using Gmail (Custom) connector
JAMF
Enhancement
JAMF is a software company that specializes in helping organizations manage and control their Apple devices, such as Macs, iPhones, and iPads. It simplifies tasks like device setup, application management, security enforcement, and remote troubleshooting for IT administrators. Essentially, Jamf makes it easier for organizations to handle and maintain their Apple device infrastructure.
Enhancement made:
Removed Basic Authentication support, as Jamf Pro version 11.17.0 no longer allows Basic Authentication except for obtaining the auth token.
Migrated Computer Inventory APIs to Jamf Pro API v3 endpoints.
Removed the legacy computer object and replaced it with the computer inventory object.
Install and start using JAMF connector
Freshdesk
Enhancement
Freshdesk is a helpdesk system and Customer Relationship Management (CRM) solution that simplifies customer service for your team and helps them provide a great customer experience.
Enhancements made:
Added support for new objects in List records action: ticket, unassigned_ticket, overdue_ticket, ticket_conversation
Added support for new object in Get record action: group
Get record action: auto-fetches authenticated agent when ID is blank
Enhanced Search contact action: Added requester_id (direct lookup), name (autocomplete) search paths alongside existing email/phone/company_id
Create / Update / Get / List records actions – Added map_values toggle: Returns readable labels for status, priority, source, and association_type instead of raw integers
Install and start using Freshdesk connector
Azure File Storage
Enhancement
Azure File Storage is a fully managed, cloud-based file shares that can be accessed using standard protocols like SMB and NFS. This connector allows you to create, read and update files in Azure File Storage.
Enhancements made:
Added Search files and directories, Create directory, Delete directory, and Rename directory actions
Install and start using Azure File Storage connector
Odoo
Enhancement
Odoo provides a comprehensive suite of business applications and allows businesses to manage and automate key business processes across various departments such as sales, CRM, inventory, accounting, and more. Leveraging this connector, you can easily interact with Odoo’s modules, enabling efficient data management and automation to streamline your business operations.
Enhancements made:
Added Search quote expiration action
Added new/updated trigger for Price list rule and Inventory
Updated all actions and triggers to support v19
Install and start using Odoo connector
Youtube
Enhancement
YouTube is a video-sharing platform that allows users to upload, view, and share videos. This connector allows you to search and get analytics for your YouTube videos and channels.
Enhancements made:
Added YouTube playlist management actions: Create playlist, Add to playlist, Remove from playlist
Added Reply to comment action for responding to comment threads
Added Download caption track action to retrieve caption file content
Added List records action consolidating channel videos, playlist items, comment threads, thread replies, playlists, and caption tracks into one action
Extended Get record and Update record to support playlist, channel, and video metadata object types
Added video statistics (views, likes, comments) to the listing and get record output fields
Install and start using Youtube connector
Canva Connect
Enhancement
Canva Connect is an online template editor application to help businesses create social media graphics and presentations. It also offers collaboration in team workspaces which allows users to contribute their ideas and comments.
Enhancements made:
All objects under
Search recordsare enhanced with new input filters -
New
Get recordobjects: Design export formats, Asset upload job, URL asset upload job, Brand template dataset, Design autofill job -
New actions:
Create design export job,Upload asset from URL,Create design autofill job -
Added missing output fields in existing actions
Install and start using Canva Connect connector
Wiz
EnhancementBugfix
Wiz provides a platform that helps organizations secure their cloud environments by identifying and addressing critical risks across different cloud systems.
Enhancements made:
Added Issues V2 object on New record trigger
Bug fixes made:
Fixed parsing for Search issues parameter: filterBy
Install and start using Wiz connector
Azure DevOps
Bugfix
Azure DevOps provides version control, reporting, requirements management, project management, automated builds, testing and release management capabilities. It covers the entire application lifecycle and enables DevOps capabilities.
Bug fixes made:
Fixed duplicate label for work item ID in the New event trigger output schema
Install and start using Azure DevOps connector
Cornerstone
Enhancement
Cornerstone is a cloud-based software company that provides human capital management solutions, including tools for learning and development, performance management, recruiting, and compliance. Their software helps organizations manage and develop their employees effectively.
Enhancements made:
Added static webhook trigger with API key and HMAC-SHA256 authentication support
Install and start using Cornerstone connector
SOAP
Enhancement
Workato’s SOAP connector is a universal connector that can be used to connect to any web service through the use of WSDL descriptions.
Enhancements made:
Fixed “type: ‘number'” to “type: ‘string'” and added toggle_field for XSD string enum fields in methods.generate_field_schema, enabling datapill mapping and “Use custom value” toggle in the Workato UI
Install and start using SOAP connector
A2A Protocol
Enhancement
Enhancements made:
Added OPA support
Backlog
Enhancement
Backlog is a project management and collaboration tool developed by Nulab, a software company known for creating productivity tools for teams. Backlog is designed to help teams manage their tasks, track progress, and collaborate effectively on projects. It offers features such as task management, issue tracking, version control, wikis, and team collaboration tools. Backlog is particularly popular among software development teams, but it can be used by any team or organization that needs to manage projects and tasks efficiently.
Enhancements made:
Enhanced pick lists to handle multi-project IDs
Fixed typo in priorityId/assigneeId field
Install and start using Backlog connector
Gitlab
Enhancement
GitLab is an open source end-to-end software development platform with built-in version control, issue tracking, code review, CI/CD, and more.
Enhancements made:
Project identifiers work as numeric IDs or namespace/project paths in API URLs.
Added pagination fields in Search Action output.
Extended Search Records Action to support Global Search
Added Note object in Create Action for Merge & Issue Note.
Added New Action : Get Pipeline Status
Added New Action : List Records with object User & Discussion
Added Authorization code flow connection type
Install and start using Gitlab connector
Aconex
Enhancement
Aconex is a cloud-based project management and collaboration platform for the construction and engineering industries. Part of Oracle Construction and Engineering, Aconex helps manage documents, workflows, and communications across project teams globally.
Enhancements made:
Added new action: Register document (manual chunked upload) via streaming
Install and start using Aconex connector
Personio
Enhancement
Personio offers a comprehensive HR software solution that streamlines processes, enhances employee experience, ensures compliance and data security, provides insights for decision-making, supports scalability and customization, and promotes integration and collaboration. By leveraging the benefits of Personio, organizations can optimize their HR operations and support their overall business goals.
Enhancements made:
Migrated Personio attendance and projects endpoints from v1 to v2 API
Removed new_employee(deprecated) and new_updated_record(deprecated) triggers
Moved the Project object from List records to Search records action.
Added the Timeoff object to the New/updated trigger.
Updated Authentication – Query params to body
Install and start using Personio connector
Monday
Enhancement
Monday is a cloud-based platform that allows users to create their own applications and work management software.
Enhancements made:
Attach the Monday API token only to api.monday.com requests, instead of skipping for specific URLs.
Upgraded the country.io lookups (country code/name pick lists and enrichment) from HTTP to HTTPS.
Fixed data type typo in the Limit field.
Fixed the time_zone pick list URL (removed the stale
tz/path segment that returned a 404).
Install and start using Monday connector
Tableau
Enhancement
Tableau is a Business Intelligence software that helps people see and understand their data. Anyone can analyze data with intuitive drag & drop products.
Enhancements made:
Added OAuth 2.0 authentication (Entra ID and Okta) to the Tableau connector via multi-auth, alongside the existing Basic, Personal Access Token, and JWT options.
Install and start using Tableau connector
Apollo.io
Enhancement
Apollo.io Founded in 2015, Apollo is a leading data intelligence and sales engagement platform trusted by 40,000 paying customers, from rapidly growing startups to some of the largest global enterprises. Its community-based approach to crowdsourcing data gives users maximum coverage while ensuring data accuracy.
Enhancements made:
Add contact object schema in people enrich action output
Install and start using Apollo.io connector
Google Meet
Enhancement
Google Meet is a video conferencing platform that allows users to participate in virtual meetings through audio, video, chat, and screen sharing, accommodating up to 100 participants without any time restrictions.
Enhancements made:
New Actions:
Get record: conference record, space, participant, participant session, recording, transcript, transcript entry, smart notes
List records: conference records, participants, participant sessions, transcripts, transcript entries, smart notes
Create record: space
Update record: space
Enhanced Action
Search Record: recordings — updated input/output fields
Error handling: parses Google’s error envelope (
code/status/message)
Install and start using Google Meet connector
Calendly
Enhancement
Calendly automates meeting scheduling, reminders, and streamlines workflow in a few clicks. By eliminating back-and-forth emails and messages, time is easier to secure.
Enhancements made:
Added List records (event type available times, scheduled events, event invitees, event type availability schedules)
Added Get record (event types, scheduled events, event invitees)
Added Create record (event invitees, scheduling links)
Added Update record (event type availability schedules)
Added Cancel event (scheduled events)
Install and start using Calendly connector
Canva Connect
Bugfix
Bug fixes made:
The JPG quality and MP4 quality fields in the Export Design action are now always visible to support static use cases.
Google Slides
Bugfix
Use Google Slides to create online slideshows. Make beautiful presentations together with secure sharing in real-time and from any device.
Bug fixes made:
Fixed Update Presentation action, undefined method error, when a slide has nil page elements
Install and start using Google Slides connector
Filevine
Bugfix
Filevine is a legal practice management platform that helps law firms manage cases, documents, and client communications in a centralized workspace.
Bug fixes made:
Fixed dynamic Data object schema in input and output fields.
Aligned form response structure with the output schema
Normalized Person and Document field names to match API payloads
Allowed updates to locked fields in Update record action
Supported partial updates by making inputs optional
Install and start using Filevine connector
