Platform Connectors – September 2026
DocuSign
Enhancement
We’ve added a Create Template action to the DocuSign connector. Users can now create templates from recipes using commonly used fields such as name, documents, roles, and custom fields, and supply additional optional template properties through the Advanced JSON input. This makes it easier to manage templates as part of automated workflows.
We’ve added a Get Template Document Tabs action to the DocuSign connector. Users can now retrieve all tabs for a specified document within a template, including prefill tabs and tab groups. This gives recipes full visibility into how a template document is configured.
We’ve expanded the DocuSign List Envelope Recipients action with optional extended information, metadata, and anchor tab location parameters. Its output schema now covers the full DocuSign v2.1 recipients response. Users can now use more recipient details in recipes without building custom actions.
We’ve added configurable include values and an advanced_update flag to the DocuSign Get Envelope action. Recipients remain included by default for backward compatibility, and any additional selected data is returned alongside them. This lets users retrieve more envelope data in a single step without changing existing recipes.
We’ve made the include parameter in the DocuSign Get Template action configurable, with support for selecting multiple values. Documents remain included by default, and any additional selected values are appended. This preserves existing recipe behavior while giving users access to more template data.
We’ve added a configurable, multi-select “Include” input to the DocuSign List Envelopes action. Users can now return selected related objects with each envelope, and those objects are added to the action’s output schema for use in later recipe steps. Existing recipes remain unchanged unless options are selected.
NetSuite REST
Enhancement
We’ve added create, update, upsert, delete, get by ID, and search actions for custom records to the NetSuite REST connector. Users can now select from automatically discovered custom record types when configuring these actions. This brings custom records into the same workflows as standard records.
We’ve added support for attaching and detaching records in the NetSuite REST connector with four new actions:
- Attach contact to record
- Attach file to record
- Detach contact from record
- Detach file from record
Users can now attach contacts and files to records and detach them when they are no longer needed.
Bug Fix
We’ve fixed the NetSuite REST Search Records action so filter fields are populated for read-only record types, including Terms. Users can now filter with supported operators such as IS_NOT, even when the connected NetSuite role does not have create or update access. This makes searches on read-only record types work as expected.
We’ve fixed NetSuite REST create and transform record actions so custom reference fields are left blank when a formula returns an empty value. This prevents “Invalid value” errors caused by sending a null internal identifier. Users can now rely on these actions to handle empty values cleanly.
Salesforce
Bug Fix
We’ve fixed Salesforce bulk upsert-from-CSV actions that use automapping so they no longer require internal UserPreferences fields. Users can now copy, configure, and start recipes that use the User object without design-time errors caused by fields that are not in the CSV. This removes an unnecessary blocker for bulk user management.
We’ve fixed the Salesforce “Search records in bulk using SOQL query API 2.0” action so it handles authentication failures correctly. Users now see the relevant authorization error instead of a misleading “no implicit conversion of String into Integer” error. This makes authentication problems easier to diagnose.
We’ve improved Salesforce connector resilience by automatically retrying intermittent SSL/TLS and TCP connection failures. Users should see fewer recipe job failures caused by temporary network interruptions. This helps keep Salesforce workflows running smoothly.
SharePoint
Enhancement
We’ve added support for the Sites.Selected permission model to Microsoft SharePoint connections that use client credentials. Connection tests now validate Microsoft Graph access to the configured site. Users can now grant site-specific, least-privilege access without requiring broader SharePoint permissions.
HubSpot
Enhancement
We’ve expanded the HubSpot CRM MCP server with actions to list object properties, pipelines and stages, record activities, and valid association types. Record searches now support free-text queries, configurable sorting, dynamic filter groups, and flexible output fields, and record retrieval supports selectable fields and associations, including custom values. Schema handling is improved for dynamic inputs and plural object names, and create and update actions now provide a JSON editor for object properties.
We’ve updated several HubSpot actions to use HubSpot’s latest APIs. “Delete record” now replaces “Delete contact” and can archive contacts and other HubSpot objects, including resolving identifiers such as email addresses, and updated actions are available for retrieving contacts associated with a company and for creating notes, emails, calls, meetings, and tasks. The previous versions are now deprecated, so users are encouraged to move to the updated actions.
Okta
Enhancement
We’ve added a List assigned applications action to the Okta End-User MCP package. Users can now return the applications assigned to the current user, including application labels, SSO launch URLs, logos, and the total number of results. This action is not supported for OAuth 2.0 client credentials connections.
We’ve added support for additional OAuth 2.0 scopes in the Okta connector, including authenticator and device read and management permissions. Users can now work with a broader range of Okta APIs through OAuth connections. Users who bring their own OAuth app need to add these scopes to their Okta API scopes configuration.
Asana
Enhancement
We’ve added 14 actions to the Asana connector for MCP and agentic workflows, covering memberships, projects, sections, status updates, stories, custom field settings, task counts, subtasks, user task lists, typeahead, and workspace task search. The new actions let users select response fields dynamically to tailor outputs to each workflow. Task creation and updates now support assignee GIDs, start times, custom fields, memberships, and parent tasks, and section retrieval supports limit and offset pagination.
We’ve added actions to the Asana connector to create, update, and retrieve goals. Users can now manage goals within automated workflows. This brings goal tracking into the same automations as tasks and projects.
Enhancement
We’ve upgraded the LinkedIn connector to Marketing API version 202607. Users can now keep their integrations aligned with LinkedIn’s latest supported API. This helps existing integrations continue operating as older versions are retired.
File Tools by Workato
Enhancement
We’ve updated the Uncompress file action in File Tools by Workato to fully extract multi-member .tar.gz archives, the format commonly produced by Java libraries and SaaS exports such as Veeva Vault. Previously, only the first gzip member was read, which caused the rest of the archive to be dropped and the action to fail with a generic “Internal error.” Users can now extract all members correctly.
SAP RFC
Enhancement
We’ve added an optional “Maximum startup retry delay (seconds)” setting to SAP RFC connections that use cloud profiles. It maps to the JCo jco.server.max_startup_delay property and controls the maximum wait between JCo Server startup attempts after failures such as SAP downtime. Users can now set this value without editing the OPA config.yml file.
OAuth and Data Centers
Enhancement
We’ve added support for connectors to require a custom OAuth profile during connection setup when a shared OAuth app is unavailable. The requirement is validated consistently in the connection interface and in embedded widgets, and it can vary by data center. Non-OAuth connection methods are unaffected, and Square connections now require a custom OAuth profile.
Dropbox, Stripe, and Facebook Lead Ads connections in the UK, South Korea, and TME data centers now require a custom OAuth profile. This lets connections use organization-managed OAuth credentials while standard credential registration is being processed. Users in these data centers need to configure a custom OAuth profile to connect these apps.
Bug Fix
We’ve fixed an issue in the UK data center that caused invalid redirect URI errors when creating OAuth connections for the Zoom, Trello, and Microsoft Teams bot connectors. These connectors now use the appropriate regional redirect URI. Users can now create these connections without errors.
Coupa
Enhancement
We’ve expanded the Coupa connector with actions to submit requisitions for approval, search requisition lines and user groups, request and retrieve purchase order changes, hold approvals, create comments, and retrieve the current user. Requisition, purchase order, approval, catalog, and budget searches offer additional filters, and record searches support sorting and offset-based pagination. Requisition creation now supports dynamic custom fields, additional receipt and need-by-date information is available, and invalid search filters that could cause Coupa to reject requests have been corrected.
Marketo
Enhancement
We’ve enhanced the Marketo connector for bulk MCP use cases. Users can now map JSON fields at runtime for bulk program member imports, choose to return the batch ID immediately instead of waiting for completion, and use a new action to retrieve import job status and row counts by batch ID. Programs can also be retrieved by ID, searched by updated date range without additional filters, and updated with a name, description, start date, or end date where Marketo supports it.
Google BigQuery
Enhancement
We’ve expanded the Google BigQuery connector for MCP use cases. Users can now list and retrieve datasets and tables, preview table rows, estimate query costs, run and execute SQL, and retrieve or cancel jobs. Batch row insertion and retrieval of row batches by job ID have also been enhanced.
Jira Service Desk
Enhancement
We’ve added MCP-focused actions to the Jira Service Desk connector to get the current user, search and retrieve knowledge base articles, list request types and their fields, list and retrieve customer requests, and view or perform request transitions. Create customer request now supports dynamically selected service desks and request types through JSON request field values, List comments adds pagination, and comment actions provide a correctly typed Created date field while retaining the existing deprecated field for compatibility. Existing connections must be reauthorized before the new knowledge base actions can be used, and existing recipes remain compatible.
BambooHR
Enhancement
We’ve added self-service actions to the BambooHR connector to search employees, view time-off balances and eligible time-off types, list employees who are out, and submit time-off requests for the connected user. Employee details can include mapped custom field aliases, time-off requests can be filtered by view, personal requests, or approvals, and employee directory results include supervisor information when available. Existing recipes remain compatible without configuration changes.
Bug Fix
We’ve added a new BambooHR action that retrieves custom employee reports using BambooHR’s current API, which resolves 404 errors for newly created or updated reports. Legacy report IDs are automatically mapped to the current ID format, and paginated report rows are supported. Recipes that use the existing report action are not affected.
Google Cloud Storage
Bug Fix
We’ve fixed an issue in the Google Cloud Storage connector where file content downloaded through an on-prem agent connection could bypass the configured secure gateway and return a 403 Forbidden error. All Download object requests, including streamed file content, now use the configured gateway. Users with on-prem agent connections can now download objects reliably.
Box
Bug Fix
We’ve fixed the Box New/updated file in folder trigger so it correctly detects deleted files located directly in the monitored folder when “File deleted” is selected. The trigger no longer creates jobs for files deleted from unrelated folders. Files deleted from nested subfolders cannot be detected when Box omits their folder ancestry from the event.
Outlook
Bug Fix
We’ve removed the hardcoded scopes line from the hint of the Outlook custom action, which could display misleading OAuth scopes. This aligns Outlook with Excel and OneDrive, where the connection settings page is the single source of truth for OAuth scopes. Users now see consistent scope information in one place.
