Community Connectors: What’s new in October 2026
New Community Connectors in October 2026
Mindee
New
Mindee turns documents such as supplier invoices, receipts, and custom document types into structured JSON on Mindee API V2.
Use this connector to:
Extract document — enqueue an HTTPS URL or file bytes against an extraction model.
Get job status — read
Processing,Failed, orProcessedfor a job ID. -
Get inference result — fetch a completed extraction by inference ID.
Extract raw text — OCR an HTTPS URL or file bytes with an OCR model.
Search models — list models on the account. Filter by name or model type.
Additional resources:
Install and start using Mindee connector
OneTrust
New
OneTrust is a privacy, security, and data governance platform. Teams use it to run assessments, manage respondents, and track privacy program work.
Search assessments, including ones that are not completed yet
Get an assessment export, its workflow stages, and the assigned respondent
Get a user and the user’s email address
Change assessment details such as the reminder days
Reassign an assessment to another respondent
Launch a new assessment
Install and start using OneTrust connector
TRADACOMS EDI
New
TRADACOMS EDI is the UK retail electronic data interchange standard (UN/GTDI syntax) used for orders, invoices, credit notes, deliveries, and related transmission files.
Parse any TRADACOMS document into STX/MHD/MTR/END segments, messages, and an integrity report
Parse a typed transmission file (orders, invoices, credit notes, deliveries, utility bills, and others) into named fields, with optional partner-specific custom schemas
Generate a TRADACOMS document from raw segments, with MHD/MTR/END counts built automatically
Generate a typed transmission file from named header, document, VAT, and trailer fields
Look up ANA TRADACOMS code list values (transaction codes, VAT categories, priorities, and more)
Install and start using TRADACOMS EDI connector
Vercel
New
Vercel is a frontend cloud platform for deploying web applications. This connector uses the Vercel REST API to list and inspect deployments, cancel or promote them, run deployment checks, assign aliases, and listen for deployment events.
Search deployments by project, state, target, branch, and date range
Get a deployment by ID or URL
Cancel an in-progress deployment
Promote an existing deployment to production without rebuilding
Register a deployment check on a project
Create a check run on a deployment
Report a check run’s status, conclusion, and output
Assign an alias to a deployment
Trigger a recipe when a new deployment event happens.
Install and start using Vercel connector
Patreon
New
Patreon is a membership platform where creators offer tiers and patrons pledge for access.
Read the connected creator with Get identity.
Get or list campaigns and members, including tiers on a campaign and the member’s current entitlement.
Start a recipe with the New event trigger when the membership or pledge events you select (create, update, delete) occur.
Install and start using Patreon connector
NocoDB
New
NocoDB is an open-source no-code platform that turns Postgres, MySQL, MariaDB, SQL Server, or SQLite tables into editable grids. This connector reads and writes table records over the NocoDB REST Data API v2, lists tables in a base, manages linked records, and triggers recipes when rows change.
Get, search, create, update, and delete records in a NocoDB table (create/update/delete send a batch of rows in one request).
Count records with an optional
wherefilter. -
List tables in a base using the Meta API.
List, link, or unlink related records on a link field.
Trigger a recipe when records are inserted, updated, or deleted (webhook), or via polling.
Install and start using NocoDB connector
Exa
New
Exa is an AI-powered search API that retrieves high-quality web content using neural and keyword search, page content extraction, and AI-generated answers with citations.
Search the web and return page text, highlights, or a summary.
Get text, highlights, or a summary for URLs or document IDs.
Ask a question and get an answer with cited sources (exa, exa-pro, exa-research, or exa-fast).
Create a scheduled search that posts results to a webhook. Save the secret — it is returned only once.
List a monitor’s runs, newest first.
Delete a monitor.
Run a recipe when a monitor run completes. Start sets the webhook to Workato; stop leaves it. Use the secret to verify deliveries.
Install and start using Exa connector
Superhuman Docs
New
Superhuman Docs (formerly Coda) is a collaborative docs platform for building tables, automations, and team workflows in one place.
Get, search, create, update, and delete table rows
List and get tables and columns in a document
Push an in-doc button on a row
Trigger an inbound Superhuman Docs automation hook
Poll for new or updated rows in a table
Install and start using Superhuman Docs connector
Redmine
New
Redmine is an open-source project management and issue tracking application. This connector works with Redmine accounts hosted on Planio and exposes issues through standard Workato CRUD actions using the Redmine REST API.
Retrieve issues with their journals, attachments, relations, watchers and reactions
Find issues by project, tracker, status, assignee, custom fields and dates
Create issues in a project, with watchers, custom fields and file attachments
Update issue fields, attach files, or add notes to an issue
Upload files from other apps and attach them to issues
Install and start using Redmine connector
Google Maps and Places
New
Google Maps and Places provides Places API (New) and the Geocoding API for finding places, reading place details, and converting addresses to coordinates.
Retrieve place details, including addresses, coordinates, contact information, ratings, and opening hours.
Search for places by name, category, or free-form text.
Find nearby businesses and services around a specified location.
Convert addresses to coordinates and coordinates back to readable addresses.
Install and start using Google Maps and Places connector
Oura
New
Oura is a smart ring that records sleep, readiness, heart rate, and other daily biometrics.
Watch for a new daily readiness score and, when temperature is up and HRV and resting heart rate look off, clear training from a calendar Oura cannot see.
Pull the raw overnight HRV and heart rate behind those scores when a recipe needs milliseconds and beats per minute.
Bring in sleep, activity, blood oxygen, stress, or resilience for the same day before deciding what to move.
Read a heart-rate series or the member profile when the recipe needs more than the daily score.
Install and start using Oura connector
Gumroad
New
Gumroad is an e-commerce platform that lets creators sell digital products, memberships, and subscriptions directly to their audience.
Sync new Gumroad sales into your CRM or accounting system
Revoke content access automatically when a dispute or refund occurs
Deliver and manage software licenses by verifying, enabling, or disabling license keys
Notify your team when a subscription is cancelled, updated, or restarted
Install and start using Gumroad connector
Lemlist
New
Lemlist is an AI-powered sales engagement platform for outbound. It finds leads, enriches contact data, and personalizes outreach. Teams run one campaign across email, LinkedIn, phone, WhatsApp, and SMS, then read every reply in a single inbox.
Search campaigns, or the leads in a campaign
Get a campaign, or a lead by email or lead ID
Create a campaign
Add a lead to a campaign, then update, pause, resume, remove, or unsubscribe that lead
Poll new campaign activities, or receive them from a webhook
Install and start using Lemlist connector
MYOB Practice Manager
New
MYOB Practice Manager helps accounting practices manage clients, contacts, staff, expenses, and timesheets.
Sync clients, contacts, and groups with your CRM or other business apps
Keep client details, addresses, and user-defined fields up to date across systems
Create and update employees and manage their security groups
Log expenses and timesheet entries, and submit expense claims and timesheets
Record client AML verifications, notes, services, and trade names
Start recipes when clients, contacts, employees, groups, or AML verifications are created or updated
Install and start using MYOB Practice Manager connector
Kit
New
Kit (formerly ConvertKit) is an email marketing platform built for creators. It helps creators grow and engage their audience with subscriber management, tags, custom fields, forms, landing pages, broadcasts, and automated email sequences.
Look up a subscriber by ID and search subscribers by email, state, and created or updated time.
Create or update a subscriber. Create matches an existing subscriber by email address.
List and create tags, and add a tag to a subscriber.
List custom fields and use their keys when writing subscriber field values.
Receive subscriber events in real time from a signed webhook.
Poll for new or updated subscribers in every state.
Install and start using Kit connector
Resend
New
Resend is an email API that supports sending transactional email from your own domain. It provides functionality for managing sending domains, scheduling emails, and tracking delivery activity such as bounces and complaints.
Send an email to one or more recipients, or send a batch of up to 100 emails
Schedule emails, update their scheduled time, or cancel them before delivery
Retrieve an email or list emails and sending domains
Trigger workflows when an email bounces, is complained about, is delayed, or fails
Install and start using Resend connector
Deepgram
New
Deepgram is a research-driven, foundational AI company focused on building voice technology that transforms human-to-machine interactions. Its platform also provides audio intelligence, and runs in real time or batch, in the cloud or self-hosted.
Transcribe call recordings, meetings, and voicemails from a URL or uploaded file
Identify speakers and split transcripts into paragraphs and utterances
Summarize audio and text, and detect topics, intents, and sentiment
Convert text to natural-sounding speech with Aura voices
List available speech-to-text and text-to-speech models
Install and start using Deepgram connector
YNAB
New
YNAB (You Need A Budget) is a popular personal budgeting application built on zero-based budgeting.
It helps individuals and households plan their spending by giving every dollar a job, tracking expenses, and keeping budgets up to date in real time.
Retrieve budget categories and their balances for any month
Track how much is left to assign (Ready to Assign) for a budget month
Move money between categories by updating budgeted amounts
List and filter transactions, including uncategorized and unapproved ones
Update transaction details such as category, payee, memo, and cleared status
Monitor scheduled transactions across your budget
Trigger recipes whenever a transaction is created or updated
Install and start using YNAB connector
Connector Enhancements/Bug Fixes
Azure Service Bus
Enhancement
Azure Service Bus is a cloud messaging service provided by Microsoft Azure. It enables communication between applications and services in a decoupled manner, allowing them to exchange messages and events. Azure Service Bus supports both asynchronous messaging patterns and publish/subscribe messaging.
Enhancements made:
Added support for secure tunnel connection via OPA.
Install and start using Azure Service Bus connector
A2A Protocol
Enhancement
A2A Protocol (Agent-to-Agent) is an open standard for AI agent interoperability, enabling agents built on different frameworks to discover each other, delegate tasks, and exchange results over HTTP.
Enhancements made:
Added Custom header authentication so agents that require a named header (e.g. api-token) can authenticate.
Install and start using A2A Protocol connector
UKG Ready, UKG Pro, UKG Pro (Onboarding), UKG Pro (Recruiting), UKG Pro (SOAP), UKG Dimensions
Enhancement
UKG offers a suite of solutions to manage various aspects of human capital management.
Enhancements made:
Added custom header support under Advanced settings in Connection
Install and start using UKG Ready connector
Install and start using UKG Pro connector
Install and start using UKG Pro (Onboarding) connector
Install and start using UKG Pro (Recruiting) connector
Install and start using UKG Pro (SOAP) connector
Install and start using UKG Dimensions connector
Salesforce Account Engagement (Pardot)
Enhancement
Salesforce Account Engagement (Pardot) is a marketing automation platform by Salesforce for B2B sales and marketing organizations. This connector supports searching, retrieving, creating, updating, and deleting supported records, sending custom API requests, and triggering recipes when supported records are created or updated.t
Enhancements made:
Added new OAuth2 authentication methods: Authorization Code with PKCE and Client Credentials flow
Replace the split host picklists with a required Environment field (Production, Developer Org, Sandbox) and kept the legacy host fields for saved connections (backwards compatibility)
Rebranded the connector from Pardot to Salesforce Account Engagement
Install and start using Salesforce Account Engagement (Pardot) connector
OpenAPI
Enhancement
The OpenAPI connector is a universal connector that can be used to work with any application that describes its API endpoints using OpenAPI. To learn more, checkout the official Documentation and this Video.
Enhancements made:
Added an Include null properties checkbox under the OpenAPI connection’s Advanced settings.
Install and start using OpenAPI connector
DeepL
Enhancement
DeepL provides neural machine translation for text and documents, plus multilingual glossaries to keep product and brand terminology consistent across languages.
Enhancements made:
New actions: Seven new actions: Translate document (uploads a file, waits for DeepL to finish, then downloads the translated copy), Retrieve languages, and five for glossaries: Create glossary, List glossaries, Retrieve glossary entries, Replace glossary dictionary and Delete glossary.
Improved actions: Translate text has new options: context, custom instructions, model type, multiple glossaries, style ID, translation memory and billed-character reporting. Get usage now shows API key usage, characters remaining, speech minutes, the billing period and a per-product breakdown.
Install and start using DeepL connector
Linear
Enhancement
Linear is a project management and issue-tracking tool for software development teams. This connector automates creating and tracking issues, helping your team organize and manage work more efficiently.
Enhancements made:
New actions: Delete record and Archive record, for issues.
Create record: now supports Project status updates, Documents and Issue relations.
Get record: now supports Team, User, Cycle, Initiative, Document and Viewer.
Search records: now supports Teams, Users, Workflow states, Issue labels, Initiatives, Documents, Project statuses and Cycles.
Issue search: keyword (full-text) search, plus include archived and include comments options.
Custom filter: accepts JSON, which is converted to a Linear filter.
Nested objects: Get issue and Search issues return nested objects by default.
Fields to retrieve: Select all now includes nested fields.
Comment triggers: better default fields.
OAuth: token refresh fixed, because it was calling the revoke endpoint.
API key: field is now masked.
Labels and typos: field and picklist labels cleaned up, including AI and SLA.
Install and start using Linear connector
Microsoft Fabric SQL
Enhancement
Microsoft Fabric is a unified analytics platform that brings together data engineering, data integration, data warehousing, etc. into a single platform. This connector allows you to interact with Microsoft Fabric’s database, warehouse and other resources using direct SQL capabilities.
Enhancements made:
Improved hints on the connection string
Improved OPA logs
Install and start using Microsoft Fabric SQL connector
Latest extension: https://workato-opa-extensions.s3.us-east-1.amazonaws.com/fabric-sql-extensions/fabric-sql-extension-latest.jar
Microsoft Graph API
Enhancement
Microsoft Graph API allows you to access Microsoft Cloud service resources. This ranges from creating new users in Microsoft Office to creating calendar events.
Enhancements made:
Added a Client certificate option to the Authentication type picklist, alongside Authorization code grant and Client credentials.
Install and start using Microsoft Graph API connector
Microsoft Entra ID
Enhancement
Microsoft Entra ID allows enterprises to provide scalable and secure identity management services.
Enhancements made:
Install and start using Microsoft Entra ID (Azure Active Directory) connector
Kickflow
Enhancement Bugfix
Kickflow is a cloud workflow system that enables companies to improve productivity and business efficiency through the approval process.
Bug fixes made:
Fixed Create record and Update record for workflows that only have slip sections, so Inputs is no longer shown as required and those tickets can be created and updated.
Enhancements made:
Master, user, team, and ticket picklists and lists now load all items instead of just the first 25. You can also enter a Workflow ID directly when choosing a workflow.
Added automatic retry on intermittent “Connection reset by peer” error, up to 3 attempts, 10 seconds apart.
Install and start using Kickflow connector
SOAP
Bugfix
Workato’s SOAP connector is a universal connector that can be used to connect to any web service through the use of WSDL descriptions.
Bug fixes made:
Fixed intermittent “ObjectFactory collision” errors when compiling WSDLs.
Install and start using SOAP connector
Latest OPA extension: https://workato-opa-extensions.s3.amazonaws.com/soap-extensions/soap-extension-latest.zip
