See where every second went: Native OpenTelemetry tracing for Workato
Send traces from your APIs, recipes, and AI agent tools to Datadog, Splunk, Dynatrace, and other OpenTelemetry-compatible platforms.
It’s 2 a.m. and your partner-facing API is slow. Is it your app, Workato, or a downstream system? Until now, answering that meant opening a second console and piecing together job histories by hand.
Workato runs the processes you can’t afford to slow down: customer-facing APIs with strict SLAs, order and payment flows that span a dozen systems, and, increasingly, AI agents acting on enterprise data. For workloads like these, a status of “succeeded” or “failed” isn’t enough. You need to know where the time went, which step caused a failure, and how a request moved across every system it touched, in the tools your team already uses.
That’s why we’ve launched native OpenTelemetry tracing for Workato.
In this release
  • See where the time went. Each API call becomes a trace that breaks response time down by request handling, recipe execution and every connector call.
  • Follow a process across every recipe it touches. A main recipe and the recipe functions it calls share one trace.
  • Understand what your AI agents’ tools are doing. Every MCP server tool call is traced from the moment it is invoked to each downstream system.
  • Works with the stack you have. Datadog, Dynatrace, Splunk and other platforms that accept OpenTelemetry traces over OTLP/HTTP.
  • Availability. Generally available for Workato Enterprise plans and above.
How it works
Workato’s runtime exports traces in the OpenTelemetry (OTel) format, the open standard for observability data. Every API call, recipe step and AI tool call is recorded as a span with its timing, status, and context, then sent to your platform.
Coverage includes API recipes; recipe jobs and recipe functions; control flow such as loops, conditions and error monitors; MCP server tool calls; and Workato assets like decision models and data tables.
Monitor API latency against your SLAs
When a Workato API endpoint takes orders from partners or connects business-critical systems, its response time is part of a commitment, often a contractual SLA. With native OTel, you can:
  • Find the slow step fast. See whether a spike came from the recipe logic, a slow third-party API or a long loop, without opening job history.
  • One trace, end to end. Send your caller’s trace context in the X-Workato-Customer-Traceparent header and Workato’s spans join your application’s own trace. One request reads straight through your app, Workato and back.
  • Monitor every endpoint on its own. Set latency and error-rate monitors per API in your platform and get alerted before an SLA is missed.
Well-built automations are modular: a main recipe calls reusable recipe functions, which call others in turn. Until now, each recipe produced its own job record, and tracing one business event meant stitching job IDs together. Now the whole chain shares one trace.
  • See the full execution path. Every recipe function a process calls appears in the same trace, with its timing and status, so you can see which one ran, in what order and for how long.
  • Go from step-level to process-level timing. Spot when the slowdown isn’t inside a step but between recipes, or in one function called by many processes.
  • Asynchronous calls stay connected. Recipe functions called asynchronously run in their own trace and link back to the caller, so long-running work doesn’t get lost.
When agents reach enterprise systems through Workato MCP servers, every tool call becomes part of the agent’s response time and risk profile. An agent is only as fast and reliable as the slowest tool it calls.
  • Know whether it’s the agent, Workato or the app. Each tool call is traced from the moment the MCP server receives it, through the recipe behind it, to each downstream system.
  • Monitor every tool out of the box. Latency, error rate and call volume are available per tool in your platform, with no log-parsing pipelines to build.
Get started in four steps
  1. Choose your observability platform and copy its OTLP/HTTP endpoint.
  2. Add the endpoint to Workato.
  3. Send your caller’s trace context in the X-Workato-Customer-Traceparent header to join Workato spans to your own traces.
  4. Open a trace in your platform and find the slowest span.
Questions you may be asking
  • Does tracing slow down my recipes?
    • No, enabling tracing has no impact on job execution performance.
  • What data is in a span?
    • Spans contain metadata from your job execution such as connector actions, workspace context, and step durations. No input and output data are sent.
  • How is the connection secured?
    • Connections to your trace destination are managed via an authorization token that you manage on your observability platform.
  • Does sampling apply, and what will this cost on my platform?
    • 100% of traces are streamed from Workato to your observability platform when you enable OpenTelemetry tracing. You may configure your own sampling and retention filters according to your needs.
  • What isn’t covered yet?
    • You can learn more about current limitations here
  • Which plans include this? Native OTel is available for Workato’s Enterprise plans and above.
Try it today
Point Workato at your platform’s endpoint and traces start flowing.
Was this post useful?
