See every step, from API call to AI agent
Workato runs the processes you can’t afford to slow down: customer-facing APIs with strict SLAs, order and payment flows that span a dozen systems, and, increasingly, AI agents acting on enterprise data. As these workloads become critical, a status of “succeeded” or “failed” isn’t enough. You need to know where the time went, which step caused a failure, and how a request moved across every system it touched.
You also need that answer in the tools they already use. Operations teams run on Datadog, Splunk, and similar platforms. When an API slows down at 2 a.m., you shouldn’t have to switch to a second console to find out whether the cause is their app, Workato, or a downstream system.
Today we’re launching native OpenTelemetry tracing for Workato, bringing the platform into the same view as the rest of your stack.
What we’re launching
Workato’s runtime now exports traces in the OpenTelemetry (OTel) format, the open standard for observability data. Every API call, recipe step and AI tool call is recorded as a span with its timing, status, and context, then sent to any platform that accepts OpenTelemetry over HTTP.
- Built in: nothing to install. Point Workato at your platform’s endpoint and traces start flowing.
- Works with your stack: Datadog, Dynatrace, Splunk, and other OpenTelemetry-compatible platforms that accept traces over the OTLP protocol.
- Covers the runtime: API recipes, recipe jobs and recipe functions, control flow such as loops, conditions and error monitors, MCP server tool calls, and Workato features like decision models and data tables.
- Available on: Enterprise plans and above.
Monitor API latency against your SLAs
When a Workato API endpoint takes orders from partners or connects business-critical systems, its response time is part of a commitment, often a contractual SLA. Each API call now appears in your observability platform as a trace that breaks the response time down: time spent receiving the request, running the recipe, and in each connector call to a downstream system.
- Find the slow step fast. See whether a spike came from the recipe logic, a slow third-party API, or a long loop, without opening job history.
- One trace, end to end. Send your caller’s trace context in the X-Workato-Customer-Traceparent header and Workato’s spans join your application’s own trace. One request reads straight through your app, Workato and back.
- Monitor every endpoint on its own. Each endpoint is tracked separately, so you can set latency and error-rate monitors per API in your platform and get alerted before an SLA is missed.
[Screenshot: Datadog waterfall of an API call, from the partner portal’s span through the Workato API call, recipe job and connector steps]
Follow a process across every recipe it touches
Well-built automations are modular: a main recipe calls reusable recipe functions, which call others in turn. That’s good design, but until now each recipe produced its own job record, and tracing one business event across them meant stitching job IDs together by hand.
With OpenTelemetry, the whole chain shares one trace:
- See the full execution path. Every recipe function a process calls appears in the same trace, with its timing and status, so you can see which one ran, in what order, and for how long.
- Go from step-level to process-level timing. Spot when the slowdown isn’t inside a step but between recipes, or in one function called by many processes.
- Asynchronous calls stay connected. Recipe functions called asynchronously run in their own trace and link back to the caller, so long-running work doesn’t get lost.
Understand what your AI agents’ tools are doing
As teams give AI agents access to enterprise systems through Workato MCP servers, every tool call becomes part of the agent’s response time and its risk profile. An agent is only as fast and reliable as the slowest tool it calls.
- Know whether it’s the agent, Workato or the app. Each tool call is traced from the moment the MCP server receives it, through the recipe behind it, to each downstream system. If a tool takes seven seconds, you’ll see exactly where those seconds went.
- Monitor every tool out of the box. Each tool is tracked separately, so latency, error rate and call volume per tool are available in your platform without building log-parsing pipelines.
