Platform Connector Releases in February 2025
Platform Connector Updates: Enhancements and Bug Fixes
RPA by Workato
Enhancement
- Introduced the RPA Connector v0.1 with actions to start jobs, retrieve job logs, list departments, and manage process details.
Bug fix
- Corrected labels for Department and Process fields.
- Ensured full job status is returned for completed jobs.
Oracle Fusion
Enhancement
- Added JWT authentication support, allowing users to authenticate with JWT in addition to the default Basic authentication.
Bug Fix
- Fixed batch triggers for New Classification Records and New/Updated Custom Records to ensure accurate batch size and record count.
Google Drive
Enhancement
- Introduced file format conversion for Upload File and Export File actions, allowing seamless conversion to different MIME types such as PDF, Plain Text and JPEG.
Microsoft SharePoint
Enhancement
- Introduced the “New/updated file in folder hierarchy (large site)” trigger to support SharePoint sites with over 5,000 files, improving performance for enterprise customers.
Bug Fix
- Resolved an issue where updating file metadata returned a “Tag is invalid or not used” error. The system now correctly searches for valid tags, ensuring seamless updates.
Wrike
Enhancement
- Added a “Modify User” action, allowing modification of Wrike Users, including custom fields. There is also a known issue with updating the People type custom field, which is being addressed.
Facebook & Facebook Lead Ads
Enhancement
- Migrated to Facebook Graph API and Marketing API version 22.0, ensuring continued compatibility with the latest platform updates.
Enhancement
- Updated the connector to use the latest LinkedIn API version 202501, ensuring continued compatibility and performance improvements.
NetSuite
Enhancement
- Added support for request level preferences to set value for runServerSuiteScriptAndWorkflowTriggers on the connection level for it to be effective for create, update and upsert actions.
Pipedrive
Enhancement
- Introduced a “New or Updated Objects” batch trigger, enabling more efficient task consumption.
Zoho CRM
Enhancement
- Added “New or Updated” batch triggers for Contacts and Leads, optimizing task usage and improving performance.
Salesforce
Bug Fix
- Resolved an issue where “Retry objects bulk job from CSV file” only retried the first chunk. Now, all failed records are properly retried.
- Fixed the “New Platform Event” trigger to ensure EventUUID is correctly returned in the output.
Dynamics 365
Bug Fix
- Resolved batch update failures by correcting metadata schema discrepancies, ensuring accurate entity parsing for Update and Create batch actions.
Shopify
Bug Fix
- Improved the “New Order” trigger to prevent missing records by adding a Next_page feature, refining since_id handling, and removing after_dispatch blocks. Enhancements apply to “New Customer”, “New Order”, and “New Product” triggers for improved reliability during high order volume.
HubSpot
Bug Fix
- Optimized the “New/Updated Contact” trigger to handle over 10,000 records with the same timestamp by switching to ID-based sorting, ensuring smooth pagination and avoiding response limits.
Amazon S3
Bug Fix
- Fixed the “New CSV File” trigger to prevent missing records and outdated file pickups by fixing the way the last modified stamp in the trigger closure is updated.
Jira
Bug Fix
- Standardized datetime field formatting in “Create Issue” and “Update Issue” actions to ensure compatibility between Jira Server and Jira Cloud.
- Improved the “Assign User to Issue” action by updating the hint of the “Enter Assignee Username” field. This is to guide users with the correct configuration of the field
- Improved the “”Update Issues” action by updating the hint of the “Sample Project Issue Type” field. This is to add clarity to the custom population behaviour based on the picklist selection of the field.
SFTP
Bug Fix
- Enhanced the Download Action to handle unexpected errors during file size stats calls, ensuring reliable file retrieval.
- Resolved the FTPTempError, improving overall stability and eliminating temporary disruptions.
