Community Connectors: What’s new in August 2026
New Community Connectors in August 2026
Vapi
New
Vapi is a platform for building, testing, and deploying AI voice agents that can make and receive phone calls.
Use this connector to:
Get record — retrieve Assistant or Call by ID.
Search records — list Assistant, Call, or Phone number.
Create record — create Assistant, Phone number, or Tool.
Update record — update Assistant.
Delete record — delete Call.
Start outbound call — place an outbound phone call; returns a Control URL for live control.
Send live call control — speak, add a message, transfer, or end an in-progress call.
Additional resources:
Install and start using Vapi connector
Keeper Secrets Manager
New
Keeper Secrets Manager (KSM) is a zero-knowledge, cloud-based platform for securing infrastructure secrets such as API keys, database passwords, access keys, certificates and other confidential data. This connector wraps the Keeper Secrets Manager Java SDK behind a Workato On-Prem Agent (OPA) extension, so machine-to-machine access to scoped secret records is handled entirely inside your network.
Retrieve a secret record and its fields by UID at runtime for downstream recipes
Search or list the secret records shared with your Secrets Manager application
Create, update, or delete secret records in a shared folder
Generate a secure password, or rotate the password stored on a record
Install and start using Keeper Secrets Manager connector
Learn more about OPA extensions: On-prem agent – Extensions | Workato docs
Tanium
New
Tanium is a converged endpoint management platform. This connector uses the Tanium Core Platform REST API (OpenAPI 3) so you can search, create, update, and delete platform objects, and run arbitrary API operations from recipes.
Get, search, create, update, and delete Tanium records (actions, sensors, computer groups, users, packages, saved questions, and more)
Execute any Core Platform operation exposed in the OpenAPI document
Build a custom HTTP action against Tanium using the same connection
Trigger recipes when selected records are created or updated (where the OpenAPI schema supports polling)
Install and start using Tanium connector
Azure Event Hub
New
Azure Event Hub is a fully managed, real-time data ingestion service from Microsoft Azure. It lets applications publish and stream millions of events per second from any source to any destination for analytics, storage, or downstream processing.
When an order is placed in an e-commerce system, send the order event to an Event Hub for analytics pipelines.
Batch telemetry readings from IoT or application logs and publish them to Event Hubs in a single request.
Route events to a specific partition or publisher identity when downstream consumers require ordered processing.
Install and start using Azure Event Hub connector
Email (Custom) OPA
New
Email (Custom) OPA is a utility connector enabling seamless email management via SMTP, IMAP, and POP3 protocols through the Workato On-Prem Agent (OPA). It provides the same actions and triggers as Email (Custom), but routes all protocol communication through an OPA Java extension so it works with secure tunnel / on-prem deployments.
Start a workflow when a new email is received
Send emails with attachments using SMTP protocol
Search and retrieve emails using IMAP or POP3 protocol
Install and start using Email (Custom) OPA connector
Clay
New
Clay is a go-to-market data platform with a proprietary database of companies and people. This connector provides read-only lookups and filtered searches against Clay’s Public API for prospecting, research, and ICP qualification.
Look up a company profile by domain for pre-call research
Retrieve funding range signals for ICP qualification
Find stakeholders at a target account by title, seniority, and location
Search companies by industry, size, funding amount, and geography
Install and start using Clay connector
Airtop
New
Airtop provides cloud browser sessions for AI agents and automation. Use it to browse the web, scrape pages, query content with LLMs, and interact with pages using natural language — without running your own browser infrastructure.
Get / Search / Create / Delete record — manage Session and Window objects (start or end browser sessions, open or close windows).
Load URL in window — navigate an existing window to a new URL.
Scrape page content — extract the current page as markdown.
Query a page — ask natural-language questions about the current page.
Extract paginated list — traverse pagination or infinite scroll and extract structured list data.
Click element — click an element described in natural language.
Type text — type into the active field or a described input.
Install and start using Airtop connector
AssemblyAI
New
AssemblyAI provides speech-to-text, speech understanding, and LLM Gateway APIs for voice AI workflows. Use it to upload audio, transcribe, export subtitles, run LLM prompts over transcripts, and receive webhook notifications when jobs complete.
Get / Search / Create / Delete record — manage Transcript objects (submit jobs, list, fetch, delete).
Upload audio file — upload raw audio bytes and receive an upload URL for transcription.
Transcribe and wait — submit a transcript and poll until completed.
Export subtitles — download SRT or VTT captions for a completed transcript.
Apply LLM to transcript — call the LLM Gateway chat completions API with transcript context.
Generate speech understanding — run translation, speaker identification, or custom formatting via the LLM Gateway.
Completed transcript — static webhook when a transcript finishes.
Install and start using AssemblyAI connector
Connector Enhancements/Bug Fixes
Google Pub/Sub
Enhancement
Google Pub/Sub works as a messaging middleware for traditional service integration or a simple communication medium for modern microservices.
Enhancements made:
Added secure tunnel support, enabling users to route all connector traffic through an On-Prem Agent (OPA) group
Install and start using Google Pub/Sub connector
Telegram
Enhancement
Telegram is a globally accessible fremium, cross-platform, cloud-based instant messaging app with a focus on security & speed.
Added 3 new actions: Send chat, Send message with buttons or voice, Get chat member.
New event trigger: Added new events to the subscribe list. Deprecated the old trigger to allow granular selection of events to subscribe to via a multiselect picklist.
Enriched the output schema for the New event trigger.
Introduced a shared error handler.
Exposed previously missing output datapills.
Updated parse_mode picklist.
Install and start using Telegram connector
Employment Hero
Enhancement
Employment Hero provides a cloud-based solution that offers various tools and features to streamline HR processes, manage employee data, and handle payroll tasks. Some of the key features of Employment Hero include employee onboarding, performance management, time and attendance tracking, and compliance management.
Enhancements made:
Added mandatory PKCE (S256) support to Employment Hero OAuth authorization
Added
page_indexfor Search pagination -
Added employee
statusas an output field
Install and start using Employment Hero connector
Qualtrics
Enhancement
Qualtrics is a survey management platform with many inbuilt tools for greater insights into your survey data.
Enhancements made:
Migrated the Create mailing list and Get mailing list details actions from the deprecated Qualtrics Research Core API to the new XM Directory API
Install and start using Qualtrics connector
Veeva Vault
Enhancement
Veeva Vault is the cloud-based content and data management platform built for the life sciences industry. It powers clinical, regulatory, quality, commercial, and CRM operations for pharma, biotech, and medical device companies.
Enhancements made:
Fixed upload file corruption for streams/binary/CSV (stop always base64-decoding).
Converted Content type field to a picklist under File content.
Converted Product field to a picklist via VQL.
Install and start using Veeva Vault connector
Looker
Enhancement
Looker is a business intelligence software and big data analytics platform that helps you explore, analyze and share real-time business analytics easily.
Enhancements made:
Added OAuth 2.0 (authorization code + PKCE) as an authentication option alongside the existing API3 credentials
Install and start using Looker connector
Workato Embedded
Enhancement
Workato Embedded allows programmatically creating and managing customer accounts and assets, such as recipes and connections.
Enhancements made:
Fixed Export package to use Embedded API endpoint
Deprecated Get package by ID and Download package (no Embedded equivalents)
Added Get export status action (provides download URL)
Install and start using Workato Embedded connector
OData
Enhancement
The OData connector is a universal connector that can be used to work with any application that describes its API endpoints using OData EDMX. To learn more, refer to this OData Documentation.
What is OData?
OData is a specification that acts as a machine-readable interface for describing, producing, consuming, and visualizing RESTful web services.
Enhancements made:
Scoped output data pills to the fields chosen in $select, and surfaced $expand navigation/association entity fields as nested pills for OData v2.
Install and start using OData connector
SmartRecruiters
Enhancement
SmartRecruiters is a cloud-based talent acquisition platform that offers a comprehensive set of recruitment tools and features. It is designed to streamline and optimize the hiring process for organizations of all sizes. SmartRecruiters provides a centralized platform where recruiters and hiring managers can manage job postings, applicant tracking, candidate communication, and collaboration.
Enhancements made:
Search Jobs Status is now multi-select, so you can filter by more than one job status. Existing recipes that send a single Status keep working.
Job output now includes Location → Hybrid
Install and start using SmartRecruiters connector
HiBob
Enhancement
Hibob is a distinctive and innovative people management platform that offers fast-growing companies powerful tools to creatively manage a modern workforce, increase productivity, and improve employee experience.
Enhancements made:
Search/Get employees: Fields to retrieve are now a hierarchical tree (grouped by category), and the action output schema only includes the fields you selected
Search time-off by date range: Added private, pending, and working-pattern filters, and expanded the output schema to cover the time-off types documented in the HiBob API (days, hours, portionOnRange, and related variants)
Install and start using HiBob connector
Ironclad
Enhancement
Ironclad is a platform for contract lifecycle management which streamlines the creation, management and analysis of digital contracts. This connector allows you to automate your users, workflows and comments on contracts with Ironclad.
Enhancements made:
Added the built-in Custom action to call any Ironclad API endpoint with your existing connection. The previous custom action is deprecated; existing recipes keep working.
Connection validation no longer uses a SCIM (admin-only) endpoint. It uses a workflows endpoint instead, so non-admin users can connect successfully.
Connections now request only
public.workflows.readWorkflowsby default. The previous admin-only SCIM scope is no longer forced; selectscim.users.readUsersonly if you need User read actions. Ensurepublic.workflows.readWorkflowsis enabled on your Ironclad OAuth app. -
Fixed an issue where end-user/runtime OAuth connections could fail because the client secret wasn’t retained. OAuth token errors now show clearer details from Ironclad.
Install and start using Ironclad connector
OpenAPI
Bugfix
The OpenAPI connector is a universal connector that can be used to work with any application that describes its API endpoints using OpenAPI. To learn more, checkout the official Documentation and this Video.
Bug fixes made:
Fixed OpenAPI
anyOfschema generation when an object schema is combined with a primitive type (for example, string), so object fields render correctly instead of a corrupted schema -
Preserve existing behavior for object+object and all-primitive
anyOfcompositions
Install and start using OpenAPI connector
Azure DevOps
Bugfix
Azure DevOps provides version control, reporting, requirements management, project management, automated builds, testing and release management capabilities. It covers the entire application lifecycle and enables DevOps capabilities.
Bug fixes made:
Fixed Azure DevOps Service Principal connections failing after the access token expires, including when recipes run again after a long idle period
Automatically refresh the token when Azure DevOps returns a sign-in redirect instead of an unauthorized error
Install and start using Azure DevOps connector
SOAP
Bugfix
Workato’s SOAP connector is a universal connector that can be used to connect to any web service through the use of WSDL descriptions.
Bug fixes made:
Fixed
DateTimeStringAdapter.unmarshalto parse offset-less/local date-times (e.g.0001-01-01T00:00:00, .NETDateTime.MinValue) viaformatter.parseBest(ZonedDateTime → LocalDateTime → LocalDate)and normalize to ISO, instead of failing to parse and returning the raw string -
Fixed
OutputConverter.dumpInstancegetter fallback to matchisX()/getX()(zero-arg) accessors, so nillableBooleanfields (e.g.isBlocked()) are no longer dropped from the unmarshalled response object
Install and start using SOAP connector
