Easy access to trigger and action step outputs
What’s New?
We have added an artificial datapill at the root level of every trigger and action in a recipe. The step_output datapill is accessible in the datatree and acts as a ‘root’ level pill that contains the full output schema of a trigger/action.
When in formula mode, the step output of an entire step in a recipe (triggers and actions) will be available as a datapill in the datatree. This works the same way as our current object/list datapills. The pill can then be dragged and dropped into a field, and it can be used in conjunction with a .to_json for formatting, or with .pluckto access data within.
Links
Was this post useful?
