The MCP Trap Every Team Falls Into
The question most teams ask is: which MCP server should we use?
It’s the wrong question to start with.
Before you can choose between a native first-party server, a pre-built catalog server, or something your team builds from scratch — you need a way to evaluate whether any given server is actually good enough for what you’re trying to do.
Most teams don’t have one.
They adopt servers based on availability, vendor familiarity, or the path of least resistance. Then they discover — in production, with real agents, in front of real users — that the server they chose has gaps they didn’t anticipate.
This post proposes a framework for evaluating MCP server quality before you commit to a path.
It applies equally to native servers, pre-built servers, and anything you build yourself.
Why Evaluation Is Harder Than It Looks
MCP servers are not traditional APIs.
With a conventional API, evaluation is relatively straightforward. You look at endpoint coverage, documentation quality, rate limits, authentication model, and SLA. A developer reads the docs, writes a test call, and gets a reasonable signal about whether the integration will work.
MCP servers introduce a different problem: they are invoked by LLMs, not by code.
That changes what “good” means.
A server can be technically correct — returning accurate data, handling errors without crashing — and still fail in production because the LLM cannot reason from it reliably. The tool names may be ambiguous. The responses may return too much data, flooding the context window with noise. The error semantics may be meaningful to a developer reading logs but opaque to a model deciding what to do next.
An MCP server that works in a demo and breaks in production usually has a design problem, not an implementation problem.
Evaluating MCP servers requires a different lens than evaluating APIs. Here is a framework built around that lens.
The Five Dimensions
LLM Effectiveness
This is the foundational dimension. Everything else depends on it.
An MCP server exists to enable an LLM to take action reliably. If the server’s design makes correct reasoning difficult, no other quality — breadth of coverage, governance model, extensibility — compensates for it.
- Context load. How many fields does a typical response return? A server that returns a full API payload — sometimes hundreds of fields — forces the LLM to parse irrelevant data before it can reason about the task. This wastes tokens, slows responses, and increases the probability of the model reasoning from noise rather than signal. Evaluate this empirically: run a representative task and count what comes back.
- Tool selection accuracy. Given only the tool name and description, can an LLM reliably choose the right tool for a user’s request? This is not a hypothetical — it is the primary mechanism through which agents work. Tool names that are generic, overlapping, or inconsistently structured force the model to guess. Test this directly: present varied phrasings of the same intent and observe whether the model selects consistently.
- Error semantics. When something goes wrong, does the server communicate meaning or just status? There is a significant difference between a response that says “not found” and one that distinguishes between “no records match this query” and “this record does not exist.” The first tells the model nothing useful about what to do next. The second gives it enough to reason from. Evaluate whether the server’s failure modes are semantically distinct and actionable.
A server that scores poorly on LLM effectiveness should not be dismissed as “needs tuning.” In most cases it reflects design decisions that are difficult to change after the fact.
Capability
A server that cannot complete your actual workflows is not a useful server, regardless of how well-designed it is.
- Use case coverage. Can the primary workflows you need to support complete end-to-end within the server’s tools? This sounds obvious but is frequently underestimated. Map your three to five most important agent workflows against the server’s tool set before you commit. Gaps discovered during implementation are significantly more expensive than gaps discovered during evaluation.
- Read and write balance. Many servers are heavily weighted toward reads. That is appropriate for some use cases and insufficient for others. If your agent needs to update records, create objects, or trigger state changes, verify that write operations are available, not just reads, and that they are scoped correctly to the actions your workflows require.
- Object coverage. Does the server support the specific objects your use cases depend on? A CRM server that covers opportunities but not custom objects, or an HRIS server that covers standard employee fields but not the extensions your organization has added, has a capability gap that will surface in every workflow that touches those objects.
Customizable and Extensible
This dimension separates servers that can fit your business from servers that were built for someone else’s.
- Field-level customization. Every enterprise has customized its core systems. Custom fields on Salesforce opportunities. Extended attributes in Workday. Domain-specific objects in your project management tool. A server built for the generic data model does not see those customizations. Evaluate whether the server can be configured to surface the fields your workflows actually depend on — not just the vendor’s default schema.
- Business logic extensibility. Beyond data, your organization has accumulated institutional knowledge that generic servers cannot have: which queues a ticket should route to, which projects correspond to which business functions, what “priority” means in your specific context. Evaluate whether that logic can be embedded in the server’s behavior or whether it will have to live elsewhere — in the LLM’s system prompt, in the agent’s orchestration layer, or nowhere at all.
- Tool extensibility. As your AI program matures, your use cases will expand beyond what any server ships with on day one. Evaluate whether net-new tools can be added to the server as those needs emerge, or whether the server’s tool set is fixed at whatever the builder chose to ship.
The distinction between customizable and extensible matters. Customization adapts what exists. Extension adds what doesn’t.
Both are necessary for a server that remains useful over time.
Composable
Enterprise workflows rarely live inside a single system. An agent that can only operate within one application is an agent with a narrow range of useful tasks.
- LLM-driven composition. When your agent needs to chain actions across multiple servers — retrieve a customer record, look up their open support tickets, pull their recent usage data — it needs those servers to speak a compatible language. If parameter names, identifier formats, and return structures differ significantly across servers, the LLM has to bridge those gaps through inference. That inference is error-prone and compounds across multi-step workflows. Evaluate whether the servers you are considering use consistent conventions or require translation at every boundary.
- Developer-driven composition. Beyond what the LLM can chain automatically, evaluate whether tools from multiple servers can be deliberately assembled into a purpose-built composite server for a specific use case. A Customer 360 server that draws from CRM, support, and data warehouse tools is more capable and more coherent than three separate servers the LLM has to orchestrate independently. The ability to build that composite cleanly — without redundancy, without conflicting contracts — is a meaningful differentiator.
- The cross-system question. No single vendor can provide a consistent composition layer across their competitors’ systems. This is structural, not a gap that first-party servers will close over time. Evaluate composition honestly: if your use cases require it, verify that the infrastructure to support it exists before you are dependent on it.
Governance
As AI agents move from experimentation to production, governance stops being optional.
- Authentication model. Does the server use the actual identity of the user on whose behalf it is acting, or does it use a service account? This is not merely a security question — it affects what data the agent can access, what actions it can take, and what the audit trail shows. Service accounts with broad permissions are a common shortcut in early implementations. They become a liability as agents take consequential actions on behalf of specific users.
- Access control granularity. Is access control available at the tool level, or only at the server level? Controlling whether a user can access a server at all is the floor. Controlling which specific tools within that server they can invoke — whether they can read but not write, whether they can access sensitive objects but not administrative functions — is what production governance actually requires. Evaluate this before you are in a position where granting access to one tool means granting access to all of them.
- Unified observability. Can you see, from a single place, what your agents did across all connected systems? Audit trails that are fragmented across vendor portals are not auditable in any meaningful enterprise sense. If something goes wrong — an agent takes an incorrect action, a sensitive record is accessed unexpectedly — you need to be able to reconstruct what happened and why. Evaluate whether the observability model scales across your full catalog, not just a single server.
Applying the Framework
Run these five dimensions against any server you are considering — native, pre-built, or custom-built — before you commit.
Not all dimensions will be equally important for every use case. A server supporting a narrow, read-only research workflow has different requirements than one supporting a multi-system operational agent. Weight the dimensions accordingly.
What the framework surfaces is trade-offs, not verdicts.
A native first-party server may score well on capability and poorly on customization. A custom-built server may score well on business logic extensibility and poorly on LLM effectiveness — because most teams building their first MCP servers have not yet developed the design expertise that dimension requires. A pre-built catalog server starts from a different baseline on each dimension.
The goal is not to find a perfect server. It is to know exactly what you are getting and what gaps you are taking on.
What This Means For The Build vs. Buy Question
One implication of this framework is worth stating directly.
“Pre-built” and “custom-built” are not alternatives on the same dimension.
Pre-built answers the question of where you start. Custom-built answers the question of what you add on top.
A pre-built server that scores well on LLM effectiveness, supports field-level customization, allows tool extension, and maintains consistent data contracts does not constrain what you can build. It gives you a higher baseline to build from.
The teams that get the most value from their AI programs fastest are not the ones who build everything or the ones who accept whatever ships out of the box. They are the ones who start from a strong foundation on the dimensions that are hardest to build well from scratch — and invest their own capacity in the dimensions that are unique to their business.
In the next posts in this series, we will apply this framework to specific server types and examine where the patterns emerge.
This post is part of a series on building effective enterprise AI agent programs using MCP. Earlier posts in the series covered MCP server design principles including scope, tool design, and the importance of determinism in LLM-facing interfaces.
