Platform Connectors – December 2025
DocuSign
Enhancement
We’ve implemented a new method for managing signer and date tabs on DocuSign documents with multiple signers. Users can now more easily place signer and date tabs for each signer.
File Connectors
Enhancement
We’ve added support for ASCII-8BIT encoding in file-related connectors. Users can now select ASCII-8BIT from the encoding picklist, and benefit from improved validation and consistent error handling for unsupported encodings during recipe design. This ensures smoother file processing and reduces the risk of invalid input.
SharePoint
Enhancement
Schema designer is now supported when a datapill is used in the list ID input for the following actions:
  1. Add row in SharePoint list
  2. Create rows in SharePoint list
  3. Update a row in SharePoint list
  4. Update rows in SharePoint list
  5. Search list items in SharePoint list
Users can now use datapills for list ID inputs, making it easier to manage list IDs when deploying from development to production environments. This provides greater flexibility and efficiency in SharePoint integrations.
NetSuite REST
Bug Fix
We’ve updated the NetSuite REST Create Action to ensure the ‘quantity’ field is now an array in formula mode, allowing for object input. Users can now input values as a string or as an array containing a mappable field, aligning with NetSuite’s accepted formats and improving compatibility.
S3
Bug Fix
We’ve increased the buffer time for the AWS S3 connector trigger from 2 minutes to 5 minutes. The increased time ensures complete capture of all files during scheduled uploads. This enhancement ensures more reliable file processing.
Oracle Fusion
Bug Fix
We’ve refined and consolidated the SOAP payload logic for three Oracle Fusion Cloud actions that interact with UCM/import pipelines. Users can now import bulk data via zip or CSV files with  a consistent document structure and improved handling of empty values. This results in reliable bulk data imports.
Asana
Bug Fix
We’ve improved the Asana New Event webhook trigger to monitor all changes related to a project by default. Users can track any project events and have the flexibility to select specific events to monitor. This provides more comprehensive and customizable event tracking.
Coupa
Bug Fix
We’ve optimized the Coupa Search Action to automatically handle pagination parameters (offset and limit) when using search_by: query. This ensures reliable data retrieval and consistent pagination support across both query and field-based searches, giving you greater flexibility in your Coupa integrations.
IDP by Workato
Bug Fix
We’ve updated the schema for objects/arrays in IDP by Workato to no longer allow null values when the object exists in the schema, ensuring consistent and accurate schema validation and improving data integrity.
File Tools
Bug Fix
We’ve enhanced the “Uncompress File” action in File Tools to support all encoding types for file names and content. Users can now uncompress files, regardless of encoding, for a smooth file management experience.
Was this post useful?
