Community Connectors: What’s new in July 2025
New Community Connectors in July 2025
Azure File Storage
New
Azure File Storage is a fully managed, cloud-based file shares that can be accessed using standard protocols like SMB and NFS. This connector allows you to create, read and update files in Azure File Storage.
Use this connector to:
Create new files in Azure File Storage when new data is received in a data warehouse
Update existing files in Azure File Storage when new data is received in a data warehouse
Delete files in Azure File Storage when a file is deleted in a data warehouse
Additional resources:
Install and start using Azure File Storage connector
Oracle Object Storage
New
Oracle Object Storage is a cloud-based object storage service that provides a scalable, secure, and cost-effective way to store and access data. This connector allows you to automate the management of objects in Oracle Object Storage, such as creating, deleting, and downloading objects.
Create and manage new buckets, objects, and preauthenticated requests in Oracle Object Storage
Download large files from Oracle Object Storage using file streaming
Upload large files via multipart upload to Oracle Object Storage using file streaming
Install and start using Oracle Object Storage connector
AuthHub
New
AuthHub is a policy-driven authentication and authorization service used in Broadcom security tools like SiteMinder. It manages user authentication flows and supports integration with multiple authentication methods.
Search and retrieve specific users registered with broadcom.
Add users to a group.
Remove users from a group.
Install and start using AuthHub connector
VerifiedFirst
New Private
VerifiedFirst is a screening tool that allows organizations to run comprehensive background checks on individuals, ensuring that they meet the required standards and are trustworthy. This connector automates the background check process, saving valuable time and allowing teams to focus on creating a more engaging and seamless experience.
Automate the background check process for new hires
Screen customer details to prevent fraud in e-commerce or retail sales
Connector Enhancements/Bugs Fixes
Ironclad
Enhancement
Ironclad is a platform for contract lifecycle management which streamlines the creation, management and analysis of digital contracts. This connector allows you to automate your users, workflows and comments on contracts with Ironclad.
Enhancements made:
Deprecated API Key auth
Implemented OAuth2 Auth code and Client credentials auth types
Install and start using Ironclad connector
UKG Ready
Enhancement
UKG Ready is a cloud-based human capital management (HCM) suite that helps organizations manage their workforce. It includes modules for HR, payroll, time and attendance, and talent management.
Enhancements made:
Added additional authentication method – Oauth2 client credentials grant type
Modified batch employee processing logic to distinguish fully successful records from partially failed ones
Updated
Records Ingestedto include only records where all 5 API calls succeeded (Self,Demographics,Pay Info,Badges,Compensation) -
Updated
Records Failedto include:-
Records with any failed API call
Successful data blocks for partial processing
Install and start using UKG Ready connector
MYOB Business
Enhancement
MYOB provides comprehensive accounting software designed to streamline financial management for businesses of all sizes. With features for invoicing, expense tracking, payroll, and more, it offers a user-friendly solution to efficiently manage finances.
Enhancements made:
Made Company File ID field configurable in connection/action/triggers to support multi-tenancy
Install and start using MYOB Business connector
SOAP
Enhancement
Workato’s SOAP connector is a universal connector that can be used to connect to any web service through the use of WSDL descriptions.
Enhancements made:
Added support for “Enable MTOM” and “MTOM threshold (bytes)” in the connection configuration, which can be used to enable the MTOM support. When enabled:
Large binary attachments are transmitted more efficiently using MTOM (Message Transmission Optimization Mechanism).
Binary data larger than the specified threshold (default: 1024 bytes) is sent as an MTOM attachment, while smaller data is sent inline.
Added an option to choose between Parsed and Raw response modes.
When Parsed is selected, the response is processed using the schema defined in the WSDL.
When Raw is selected, the connector skips parsing and returns the raw SOAP envelope as-is. In this mode, even if the response contains an error or fault, it will still be returned directly, and the job will be marked as successful.
Added the ability to send receive SOAP headers
Bug fixes made:
Updated the code to dynamically inherit the namespace context from parent class annotations, ensuring elements correctly follow their inheritance hierarchy. This prevents the generation of empty namespaces for any fields.
Install and start using SOAP connector
AuthHub
Enhancement
Enhancements made:
Improved subdomain connection field to allow configuration of base URL.
Azure Service Bus
Enhancement
Azure Service Bus is a cloud messaging service provided by Microsoft Azure. It enables communication between applications and services in a decoupled manner, allowing them to exchange messages and events. Azure Service Bus supports both asynchronous messaging patterns and publish/subscribe messaging.
Enhancements made:
Added support for custom properties in send message and send message(batch) actions.
Install and start using Azure Service Bus connector
Skilljar
Enhancement
Skilljar is the external LMS to drive product adoption, increase net retention, and lower the cost to support customers and partners.
Enhancements made:
Deprecated List Records action.
Created Search Records action, which supports 7 object types for filtering.
Install and start using Skilljar connector
Sage Intacct (Custom)
Enhancement
Sage Intacct is a provider of cloud-based accounting software. Sage Intacct’s applications are suitable for small and midsize companies and can provide real-time financial and operational insights as well as the ability to automate critical processes.
Enhancements made:
Converted new/updated ap_bill trigger to batch trigger
Install and start using Sage Intacct (Custom) connector
CloudSign
Enhancement
CloudSign(クラウドサイン)はウェブ完結型の契約締結クラウドアプリケーションです。契約締結の他に保管・管理にもご利用可能です。発注書・請書・納品書・検収書・ 請求書・領収書など、さまざまな対外的なやりとりにご利用いただけます。
Enhancements made:
Added actions:
Add participant,Add reporter,andSend document -
Added
'X-Application-ID'header for improved request identification
Install and start using CloudSign connector
Microsoft Fabric
Enhancement
Microsoft Fabric is a unified analytics platform that brings together data engineering, data integration, data warehousing, etc. into a single platform. This connector allows you to interact with Microsoft Fabric’s lakehouses, livy sessions, and tables, enabling you to create and manage lakehouses, run table maintenance jobs, and load data into lakehouses from various sources.
Enhancements made:
Added support for custom action
Included new actions for Data pipelines endpoints
Install and start using Microsoft Fabric connector
Microsoft Dynamics Finance And Operations
Enhancement
Microsoft Dynamics Finance and Operations is one of Microsoft’s enterprise resource planning software products. It is part of the Microsoft Dynamics family.
Enhancements made:
Added new record trigger
Added new/updated record trigger
Install and start using Microsoft Dynamics Finance And Operations connector
Jira Assets
Bugfix
Jira assets encompass a diverse range of resources, including issues, projects, and workflows, centralizing project management, issue tracking, and collaboration within organizations. These assets serve as foundational elements within Jira’s ecosystem, facilitating efficient task management, communication, and project tracking for teams across various industries.
Bug fixes made:
Fixed the can_poll_more variable
Install and start using Jira Assets connector
Notion
Bugfix
Notion is a project management and note-taking software. Notion is a software designed to help members of a company or organization coordinate deadlines, objectives, and assignments for the sake of efficiency and productivity.
Bug fixes made:
Fixed formula type fields in Query Database action
Install and start using Notion connector
Cornerstone
Bugfix
Cornerstone is a cloud-based software company that provides human capital management solutions, including tools for learning and development, performance management, recruiting, and compliance. Their software helps organizations manage and develop their employees effectively.
Bug fixes made:
Standardized environment options by changing
Stagevalue fromstagetostg. -
Enhanced auth error detection by adding support for HTML-based unauthorized responses.
Install and start using Cornerstone connector
HiBob
Bugfix
Hibob is a distinctive and innovative people management platform that offers fast-growing companies powerful tools to creatively manage a modern workforce, increase productivity, and improve employee experience.
Bug fixes made:
Fixed Reports To datapills to display complete nested structure instead of only showing email address
Fixed Payment datapills to show proper nested format with separate Base salary and Currency code fields
Install and start using HiBob connector
GlobalMeet Webcast
Bugfix
GlobalMeet Webcast is the global standard for live webcasting and video streaming for Enterprise. The cloud-based SaaS webcast solution provides businesses with an easy-to-use, secure and scalable environment to produce high-profile, engaging webcasts for thousands of attendees worldwide.
Bug fixes made:
Deprecated the old trigger.
Created a new batch trigger with a maximum batch size of 1000.
Install and start using GlobalMeet Webcast connector
Log Insight
Bugfix
Log Insight is a log management and analytics platform designed to enhance visibility and troubleshooting capabilities within virtualized environments. It integrates seamlessly with various VMware products, providing a unified platform for comprehensive log management, analysis, and proactive monitoring.
Bug fixes made:
Removed control type from Constraints field
Install and start using Log Insight connector
Tiktok Shop
Bugfix
Tiktok Shop is an e-commerce feature in the app that lets users discover and buy products without leaving the platform. It allows businesses and creators to sell directly to users. Use this connector to track orders placed by users.
Bug fixes made:
Fixed custom action
Install and start using Tiktok Shop connector
