Community Connectors: What’s new in Jan 2026
New Community Connectors in January 2026
Microsoft Fabric SQL
New
Microsoft Fabric is a unified analytics platform that brings together data engineering, data integration, data warehousing, etc. into a single platform. This connector allows you to interact with Microsoft Fabric’s database, warehouse and other resources using direct SQL capabilities.
Use this connector to:
Execute SQL queries on fabric databases and warehouses.
Execute batch SQL operations on fabric databases and warehouses.
Execute stored procedures on fabric databases
Additional resources:
Install and start using Microsoft Fabric SQL connector
Brevo
New
Brevo is a cloud-based communication platform that supports customer messaging across multiple channels. It provides functionality for creating campaigns, automating workflows, managing contacts, and tracking communication activity.
Send transactional emails.
Delete a contact.
Create a contact.
Update contact details.
Install and start using Brevo connector
AWS Glue
New
AWS Glue is a fully managed extract, transform, and load (ETL) service that makes it easy to prepare and transform data for analytics. It provides a serverless environment to run ETL jobs, automatically discovers and catalogs your data, and generates ETL code to transform your data from source to target. AWS Glue simplifies the process of building, running, and monitoring data pipelines at scale.
Start AWS Glue ETL jobs with custom parameters and configurations
Stop running Glue jobs when needed
Monitor job run status and retrieve detailed execution information
Get job details including configuration, scripts, and execution properties
Trigger workflows when new files are added to S3 buckets
Monitor job run status changes for automated pipeline management
Install and start using AWS Glue connector
IFS
New
IFS is an enterprise resource planning (ERP) platform that helps organizations manage complex business processes including project management, manufacturing, supply chain, and field service operations. This connector allows you to automate business workflows, synchronize data across systems, and streamline operations so your team can focus on delivering value to customers.
Create new business leads when opportunities are identified in a CRM system
Update customer records when account information changes in other business applications
Trigger workflows when new projects or tasks are created in project management systems
Synchronize contact information between IFS and marketing automation platforms
Monitor new leads and business opportunities for real-time sales reporting
Automate customer onboarding processes by creating records across multiple systems
Install and start using IFS connector
Connector Enhancements/Bug Fixes
Microsoft Graph API
Enhancement Bugfix
Microsoft Graph API allows you to access Microsoft Cloud service resources. This ranges from creating new users in Microsoft Office to creating calendar events.
Enhancements made:
Added a new create shareable link action
Fixed get detected app action’s output schema.
Merged List managed devices and get detected app, and created list records action.
Deprecated old list managed devices action.
Install and start using Microsoft Graph API connector
Aconex
Enhancement
Aconex is a cloud-based project management and collaboration platform for the construction and engineering industries. Part of Oracle Construction and Engineering, Aconex helps manage documents, workflows, and communications across project teams globally.
Enhancements made:
New trigger to get new/updated emails.
Register document action for both small & large files.
Create, Get metadata, & delete draft email actions.
Download mail attachments in Download records action
Check the large file register background async job action
List Projects, Documents, Mails and Drawings in List Record action.
Install and start using Aconex connector
Microsoft Entra ID
Enhancement Bugfix
Microsoft Entra ID allows enterprises to provide scalable and secure identity management services.
Enhancements made:
Added new/updated member webhook trigger
Bug fixes made:
Fixed “404 not found” error for the new deleted user trigger
Install and start using Microsoft Entra ID (Azure Active Directory) connector
Conga
Enhancement
Conga is a leading platform for Contract Lifecycle Management (CLM) and Document Automation, empowering organizations to streamline, automate, and optimize their commercial operations. Conga provides end-to-end capabilities for generating documents, managing contracts, enabling eSignatures, and supporting revenue lifecycle processes. By centralizing contract and document workflows, Conga helps reduce manual effort, improve accuracy, accelerate deal cycles, and ensure compliance across business operations.
Enhancements made:
Support all objects by retrieving the picklist using API endpoints
Update object definitions and sample output
Added support for multipicklists, and other remaining data types
Added payload cleaning to remove null values
Install and start using Conga connector
Google Vault
Enhancement
Google Vault is a cloud-based tool that helps organizations manage and retain their Google Workspace data. It’s designed for large organizations that need to search, hold, and retain data for compliance and litigation purposes. This connector allows you to automate Google Vault workflows by managing Matters and Holds.
Enhancements made:
Added custom action
Fixed broken link in hint for “Private key”
Install and start using Google Vault connector
Amazon DynamoDB
Enhancement
Amazon DynamoDB is a key-value and document database that delivers single-digit millisecond performance at any scale.
Enhancements made:
Improved validation logic: values are now rejected only when they are blank and not false.
Install and start using Amazon DynamoDB connector
Amazon Seller Central
Enhancement
Amazon Seller Central is a web-based platform that allows sellers to manage their businesses on Amazon. It provides sellers with a variety of tools and resources to help them list their products, track sales, and manage inventory. Seller Central also offers a variety of fulfillment options, including Fulfillment by Amazon (FBA), which allows sellers to ship their products directly to Amazon’s warehouses for storage and shipping.
Enhancements made:
Added support for Auth-code authentication.
Added action to fetch the selling partner ID.
Install and start using Amazon Seller Central connector
Monday
Enhancement
Monday is a cloud-based platform that allows users to create their own applications and work management software.
Enhancements made:
Full compatibility with Monday API versions up to 2025-10
Four new real-time webhook-based triggers for instant workflow execution:
New Item
New moved item to group
Updated any column value
Updated specific column value
New polling trigger: New activity log (fetches activity log records)
Enhanced error handling for Get and Search actions to better handle empty responses
Updated field mappings with newly added fields from the latest Monday API
Install and start using Monday connector
SOAP
Enhancement
Workato’s SOAP connector is a universal connector that can be used to connect to any web service through the use of WSDL descriptions.
Enhancements made:
Added support for parsing inherited date and timestamp fields.
Added support for proper property name conversion, especially for properties with uppercase names.
Install and start using SOAP connector
SAP Ariba
Enhancement
SAP Ariba is a cloud-based software platform designed to assist companies in managing their procurement, spending, and supply chain processes.
Enhancements made:
Added new/updated batch records trigger
Install and start using SAP Ariba connector
Highspot
Bugfix
Highspot is a sales enablement platform that reps love. Highspot empower companies to elevate customer conversations that drive strategic growth.
Its intuitive platform combines intelligent content management, training, contextual guidance, customer engagement, and actionable analytics. Go-to-market teams use Highspot to deliver a unified buying experience that increases revenue, customer satisfaction, and retention.
Bug fixes made:
Fixed incorrect payload mapping of ‘linkEmbedCode’ in create item as web link action
Install and start using Highspot connector
AWS Secrets Manager
Bugfix
Amazon Secrets Manager helps you protect secrets needed to access your applications, services, and IT resources. The service enables you to easily rotate, manage, and retrieve database credentials, API keys, and other secrets throughout their lifecycle.
Bug fixes made:
Updated help text for IAM role authorization
Install and start using AWS Secrets Manager connector
OpenAPI
Bugfix
The OpenAPI connector is a universal connector that can be used to work with any application that describes its API endpoints using OpenAPI. To learn more, checkout the official Documentation and this Video.
Bug fixes made:
Fixed an issue where the Trigger object picklist was not loading correctly.
Resolved data format validation errors by preventing date-time schemas from being applied to non–date-time string values.
Install and start using OpenAPI connector
