Platform Connectors – November 2025
NetSuite SOAP
Enhancement
We’ve improved the NetSuite Initialize Operation action to support additional record transformations. Users can now initialize more record types from related records. This enables broader automation scenarios and greater flexibility.
Enhancement
We’ve introduced an action-level override for the “runServerSuiteScriptAndWorkflowTriggers” setting. Users can now set this parameter at the action level, which takes precedence over the connection-level setting. This provides more granular control over workflow triggers.
Enhancement
We’ve added support for including “FileSearchBasic” in the “TransactionSearch” criteria. Users can now use “File join: Internal ID” as a search field. This enables more comprehensive and precise search capabilities.
Jira
Enhancement
We’ve added support for change detection in the “New/Updated Issue” actions and triggers. Users can now track and manage updates more efficiently, resulting in a more comprehensive and user-friendly experience.
NetSuite REST
Bug Fix
We’ve improved the Create Record action to ensure a smoother design-time experience when working with Assembly Item, Inventory Item, Kit Item, Non-inventory Sale Item, and Non-inventory Purchase Item record types. You can now create these records seamlessly during recipe design.
QuickBooks
Enhancement
We’ve added support for Workato’s Custom OAuth Profile feature. Users can now set up their own OAuth Profile for QuickBooks connections, providing enhanced security, control, and branding flexibility.
Oracle Fusion Cloud
Bug Fix
We’ve corrected the mapping for the “jobOptions” field in the “Import Bulk Data” action. This ensures successful bulk data imports and enables smoother integration migrations.
Workday
Bug Fix
We’ve updated the Submit Project action to include the “External_Project_Reference” field for Schema v44.1, enabling reliable project submission and seamless integration with Workday.
Data Tables
Bug Fix
We’ve improved the Data Tables triggers to ensure compatible parameter usage when calling the changelog API, enabling reliable checks for new jobs.
IDP by Workato
Bug Fix
We’ve updated schema handling in IDP by Workato to support documents with previously unsupported schema structures. Users can now process PDFs from FileStorage more reliably, improving workflows for document processing.
Dropbox
Enhancement
We’ve optimized large file uploads to Dropbox. Users can now upload files larger than 1 GB efficiently, with improved memory usage and support for resuming or retrying uploads as needed.
XML Tools
Bug Fix
We’ve improved the XML Tools connector to generate more accurate schemas from XSD files, including support for ID element attributes to enable precise data mapping.
Amazon SQS
Bug Fix
We’ve enhanced error handling for the AWS SQS queues picklist. Users will now see an empty picklist instead of an error and can switch to “Enter Queue URL” mode when needed to ensure a smooth setup experience.
Airtable
Bug Fix
Airtable search now fully supports Single Select fields, delivering more accurate and expected results.
FTP
Bug Fix
We’ve updated the FTP connector to support uploading 0 byte files. Users can now upload empty files, supporting a wider range of file management scenarios.
Zuora
Bug Fix
We’ve improved custom action response handling to ensure UTF-8 encoding with safe character replacement, including better support for Japanese text.
Google Cloud Storage
Bug Fix
We’ve clarified the hint messages for bucket and object name fields in the Upload file action.
Azure Blob Storage
Bug Fix
We’ve implemented case-sensitive handling for custom metadata headers. Users can now upload blobs with metadata properties like “OriginalName” retaining their exact casing for better synchronization.
Excel
Bug Fix
We’ve added support for non-ASCII characters in column names. Users can now map datapills accurately, even when column names include special characters, improving compatibility and usability.
CSV Parser
Enhancement
We’ve introduced a ‘liberal_parsing’ option to the CSV parser. Users can now process CSV files with minor non-critical inconsistencies, ensuring that data ingestion is more flexible.
Was this post useful?
