Platform Connectors in October 2025
Shopify
Enhancement
We’ve expanded the Shopify connector’s Search capabilities. Now search supports Inventory Item and Order objects. Product, Product Variant, and File objects. This enhancement allows for pagination, sorting, and query filtering for Order objects, and pagination and query filtering for Inventory Item objects.
SharePoint
Enhancement
We’ve enhanced the SharePoint connector to support Microsoft Graph API in custom actions. Users can now select between SharePoint REST API and Graph API during Client Credential authentication. This update enables broader integration options and simplifies authentication management for custom actions.
RPA
Enhancement
We’ve added support for output arguments in the Robotiq API Start job endpoint, allowing users to override initial values and access output arguments as data pills. The connector now always displays input and output arguments for relevant processes, and descriptions have been added for each argument to improve clarity.
Azure Monitor
Enhancement
We’ve introduced a new action, “Inject Logs into Azure Monitor,” and a new authentication type, “Client Credentials.” This replaces the legacy HTTP Data Collector API, which will be deprecated in September 2026. This upgrade ensures continued compatibility and improved log ingestion capabilities.
Workfront
Enhancement
We’ve upgraded the default API version in connection settings to v19.0. All APIs used in actions, triggers, and picklists work with v16.0 and above.
MS Dynamics 365
Bug Fix
We’ve resolved a pagination issue in the Search Objects action. This update ensures all necessary output fields are included when inserting records from MS Dynamics 365 to SQL Server.
SAP Concur
Bug Fix
We’ve resolved an issue that was preventing spendApprover and spendDelegate information from updating correctly in Concur. Due to changes in the Concur USER API, we’ve updated how our system handles spendApprover and spendDelegate data across all user-related actions (Get user profile, Create user, Update user, Create batch user, and Update batch user). The system now automatically formats data correctly when you select spendApprover values (report, request, invoice, cashAdvance, purchaseRequest, statement, budget) or spendDelegate values (expense, payment, purchaseRequest), ensuring updates process successfully.
Jira
Bug Fix
We’ve updated the connector to dynamically select the appropriate endpoint based on Jira version, ensuring webhook registration works seamlessly for both on-premises and cloud-hosted Jira instances. This fix restores reliable operation for Jira Webhook-based recipes.
Workday
Bug Fix
We have enabled runtime connections support for the Workday connector. This has restored the connection override options, allowing users to use their own connection.
Bug Fix
We’ve also corrected the XML mapping for job reference fields in the Put Applicant action. This resolves validation errors and supports accurate hiring workflows.
Quickbase
Bug Fix
We’ve added refresh logic to the Quickbase adapter’s custom action, automatically fetching a new active ticket when the existing one expires. This prevents 401 unauthorized errors and ensures uninterrupted operation with Quickbase’s XML APIs.
IDP
Bug Fix
We’ve improved the IDP output to always include confidence scores. This helps ensure consistency and reliability in responses.
