Sync Salesforce with Xero in minutes
Bi-directional syncs in a few clicks. Zero lines of code.
Want your integrations live in about a week?
Contact our managed services experts at +1-844-469-6752 for a quote.
CLICK AND RUN
Use our pre-built integrations to take care of your customer, item and opportunity records between Salesforce and Xero.
BI-DIRECTIONAL SYNC
Keep your data always up-to-date and consistent by syncing your apps automatically.
NO DATA DUPLICATES
Eliminate data duplication for good. We check if your records exist before deciding what gets created or updated.
WORRY-FREE AUTOMATION
Set your integrations with Workato just once. Integrations require no manual intervention, until you turn them off.
CUSTOMIZE WITH EASE
Connect any Salesforce custom object and field with Xero. Easily extend your integrations to connect with 100+ apps.
HAVE IT YOUR WAY
Create your own business logic to suit your business needs. Easily change data mappings, or manipulate them if needed.
Cort Kinker
Realize Drinks Supplier Advisory
“Sales reps hate manually re-entering data into different systems. Eliminating this is a huge opportunity to get into the field more, close deals, and get more customers.”
Comprehensive Integrations for Salesforce & Xero
Get these integrations when you sign up from the button below.
What’s in Salesforce-Xero Connect?
This App contains 5 ready-to-go integrations (we call them recipes) for keeping Salesforce and Xero in sync. Select the recipes you want to sync and start the integration. Or, tweak them easily to suit your business needs. With Workato, you can also connect up to 100+ other apps.
With Workato, you can also connect up to 100+ other apps.+This App contains 5 ready-to-go integrations for keeping Salesforce and Xero in sync
What is Xero?
Xero is easy to use online accounting software that's designed specifically for small businesses.
  • It's all online, so you can work when and where you want to. Just login with your PC, Mac or mobile.
  • Your bank statements are automatically imported and categorized, letting you see your cashflow in realtime.
  • Invite your team and work together on financials. You can collaborate over your uptodate numbers.
  • Xero has all you need to run your business - including invoicing, paying bills, sales tax returns, reporting and much more.
Find out more or try Xero Accounting Software for free.
Scott Hollrah
Managing Partner,
Venn Technology
“This is the sort of integration tool I have been dreaming of! If you hit a wall try smashing through it with Workato.”
Start with a Workato Free Trial.
No credit card needed.
Want to get a guided tour of Workato? Get a quick demo.
