You need to connect one or more apps.
Let’s connect to the apps your recipe works with.
Once all connections are established, select Next to continue.
Your app connections are already established!
Select Next to continue.
Preparing your recipe
{{ schemaRefreshStatus.linesRefreshed }} of {{ schemaRefreshStatus.totalLines }} lines complete
Customize this recipe based on your needs.
This recipe was created by someone else. To make sure it will work for you, review the following data fields and customize to your apps.
Select Next when you're done.
Loading recipe details …
This recipe needs input from you.
Input parameters help customize the behavior of a recipe to your specifications. E.g. An input parameter can specify what type of customers to move from Salesforce to Zendesk.
Once all parameters are entered, select Next to proceed with the installation.
Recipe parameters
You’re almost done!
Before you start your recipe, it is best to test it. Testing it will process just one trigger event, which will make sure your recipe works for you.
Please make sure you have a trigger event ready.
{{ flow.name }}
By {{ flow.user_name }} | {{ flow.copy_count | abbrNumber }} user{{flow.copy_count === 1 ? '' : 's'}} |
How it works
Apps needed
{{app.title}}
{{ flow.name }}
{{ flow.job_succeeded_count }} Completed {{ flow.job_failed_count }} Failed
This is a community recipe that is free
to copy, modify and use.
Restore to Version {{ flow.version_no }} Are you sure want to restore version {{ flow.version_no }}? No
Copy
Delete Cancel Are you sure you want to delete this recipe?
New version available
Started Stopped Never active
You can edit and test this recipe. To start the recipe, Upgrade
When you test, the recipe processes a single trigger event and stops. Make sure you have a trigger event available for the recipe to work
How it works
Apps you will need
Updated
on
Author
{{ ::flow.user_name }} {{ ::flow.user_location }} Workato Expert
Loading connections …
