Back to browse Review and start using this recipe.
You need to connect one or more apps.
This recipe requires connections to the apps indicated below. To create the connection, select each app and provide your app login credentials (some apps require API access credentials).
Once all connections are established, select Next to continue.
Your app connections are already established!
Select Next to continue.
Preparing your recipe
{{ schemaRefreshStatus.linesRefreshed }} of {{ schemaRefreshStatus.totalLines }} lines complete
Customize this recipe based on your needs.
This recipe was created by someone else. To make sure it will work for you, review the following data fields and customize to your apps.
Select Next when you're done.
Loading recipe details …
Trigger
Actions
This recipe needs input from you.
Input parameters help customize the behavior of a recipe to your specifications. E.g. An input parameter can specify what type of customers to move from Salesforce to Zendesk.
Once all parameters are entered, select Next to proceed with the installation.
Recipe parameters
You’re almost done!
Before you start your recipe, it is best to test it. Testing it will process just one trigger event, which will make sure your recipe works for you.
Please make sure you have a trigger event ready.
{{ flow.name }}
{{ flow.job_succeeded_count }} Completed {{ flow.job_failed_count }} Failed
This is a community recipe that is free
to copy, modify and use.
Restore to Version {{ flow.version_no }} Are you sure want to restore version {{ flow.version_no }}? No
Copy
Delete Cancel Are you sure you want to delete this recipe?
New version available
Started Stopped Never active
When you test, the recipe processes a single trigger event and stops. Make sure you have a trigger event available for the recipe to work }
Checking for new events… Please wait a moment.
Test success! One job processed. If it looks right, start.
Something’s not right. No event was processed because of an error. Review the error and test again.
No event found. Make sure you have an event ready and test again.
Description
Edit Description
Version {{ flow.version_no }}   |   View history
Updated
on
This recipe is active
To install the update, stop recipe first
When you install:
Any changes made to your recipe will be lost. Your recipe job history will be maintained.
Installing new version Install > Are you sure want to install the new version? No
Save
Last saved {{ getLastSavedDate() }}
Description
Apps you will need
Updated
on
Author
{{ ::flow.user_name }} {{ ::flow.user_location }} Workato Expert
Trigger
Actions
Save
If a schema was changed in your app, you need to refresh
Configuration
{{ paramsSchemaError }}
The recipe config can be used to set an action input. The input fields are shown under your name in the data tree. Values for these fields are collected before running the recipe. The schema should be entered in the JSON format. {{$showParametersSchemaExample ? "Hide" : "Show"}} example
    "label": "Status",
    "name": "status",
    "type": "string",
    "control_type": "text",
    "hint": "new/completed etc"
    "label": "Birth date",
    "name": "birth_date",
    "type": "date_time",
    "control_type": "date_time",
    "optional": true
    "label": "Gender",
    "name": "gender",
    "type": "string",
    "control_type": "select",
    "pick_list": [
      ["Male", "M"],
      ["Female", "F"]
