Once all connections are established, select
Next
to continue.
Your app connections are already established!
Select
Next
to continue.
Preparing your recipe
{{ schemaRefreshStatus.linesRefreshed }} of {{ schemaRefreshStatus.totalLines }} lines complete
Customize this recipe based on your needs.
This recipe was created by someone else. To make sure it will work for you, review the following data fields and customize to your apps.
Select
Next
when you're done.
Loading recipe details …
This recipe needs input from you.
Input parameters help customize the behavior of a recipe to your specifications. E.g. An input parameter can specify what type of customers to move from Salesforce to Zendesk.
Once all parameters are entered, select
Next
to proceed with the installation.
Recipe parameters
You’re almost done!
Before you start your recipe, it is best to test it. Testing it will process
just one trigger event,
which will make sure your recipe works for you.
Please make sure you have a trigger event ready.
You can edit and test this recipe.
To start the recipe,
Upgrade
When you test, the recipe processes a single trigger event and stops. Make sure you have a trigger event available for the recipe to work
